2022+ Tundra Battery Swap
Discussion in '3rd Gen Tundras (2022+)' started by Markysharky, Nov 26, 2023.
  1. Feb 9, 2024 at 4:48 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Walmart offers a 94r H7 AGM Battery with a 4 year warranty for $179 and they install for free...the great thing about them is near zero warranty hassles...less than 4 years since purchase? Here's your new battery. 800 CCA 140 min reserve capacity. I have 2 of these in service right now and they have been flawless performers.
  2. Feb 12, 2024 at 7:59 AM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    this is at 64mph on a 55 mph back road. The voltage increases during deceleration, braking, and idle.
    Tundrastruck91 likes this.
  3. Feb 12, 2024 at 9:58 AM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Going 65 or so. My guess it depends if the battery needs charge or not.
    I just picked up a Group 27F x2 and plan to modify the battery strap to fit the extra height. It has 92ah and 190 minutes of reserve.IMG_9311.png
    Black widow TRD and KroppDuster like this.
  4. Feb 12, 2024 at 12:42 PM
    Black
    2014 Tundra Limited CrewMax
    Much ado about nothing.
    Had AGM X2 Power batteries in a 2015 Ford Expedition, 2012 Highlander and currently in a 2015 Suburban and 2014 Tundra.
    No diodes, no charging issues, no premature battery failures.
    All the internet had me worried at first but My emails with the X2 power folks said no issues and no diode needed on modern alternators.
  5. Feb 12, 2024 at 3:43 PM
    Markysharky
    Markysharky [OP] New Member
    The alternator allows the voltage to get lower than some older cars with a constant output as a function of rpm. When coasting or engine braking the voltage goes to 14+ volts. Under medium throttle it’s usually just a tick under 13v. It’s supposed to help exercise the battery and save a little due to efficiency losses under normal use. Similar to how an electric car uses engine braking to charge the battery, but to a much smaller extent.
    Jettster likes this.
  6. Feb 12, 2024 at 3:56 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Same experience for me,My 2019 Mustang has had an AGM battery for about 3 years now. It’s been flawless, with an audio system hooked up to a t as well.
  7. Feb 12, 2024 at 5:12 PM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    @PapaDave418 Though from what remember running an AGM in my previous truck you’ll shorten its lifespan considerably by letting it run repeatedly down to <50% charge. So in real world application that “80 ah” AGM battery gets you about 40 ah when camped/parked, whereas lithium isn’t harmed by repeated discharges to near zero. Food for thought for those who like to get off grid for multi-day/week adventures.
  8. Feb 12, 2024 at 5:26 PM
    Black
    Standard AGM yes.
    The X2 power is a dual purpose battery both a cranking and deep cycle battery.
    It is meant to be nearly discharged frequently without consequence.
  9. Feb 12, 2024 at 5:56 PM
    Cassidy1866
    That’s a game changer. Thanks for the clarification.
  10. Feb 12, 2024 at 7:49 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah 92AH isn’t 92 but 50% of, that’s why 190 minutes reserve capacity helps me a little more. If the battery is plugged into a draw of 25 amps it will last for 190 minutes (3 hrs 10 mins) till it reaches 10.5v, or flat. 25A discharge is the standardized rate of measurement to judge reserve capacity by manufacturers.
    So if you have a 1 amp draw it will take roughly 75 hours to discharge my 92AH battery. My Dometic fridge uses @1.3A an hour if it’s running (depending on outside temps), my heater 1.3A or so when it turns on and off through the night, and I don’t usually sit in one spot more than a day or two. So it’s a good solution for me. Lithium will get you more power for sure but finding a cranking battery with high reserve gets $$$$
    Cassidy1866 likes this.
  11. Feb 14, 2024 at 3:49 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    AND, 22whatwedo and Black widow TRD like this.
  12. Feb 14, 2024 at 3:51 PM
    vorkuta775
    vorkuta775 New Member
    whats wrong with the oem battery ? why spend more money? peace of mind?
  13. Feb 14, 2024 at 3:54 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    For me off grid camping running a fridge, lights, and heater. 22% more reserve and AGM’s bounce back better than flooded acid batteries
    ADF95F9B-D308-47B2-B48B-CD37F8CC97B1.jpg 50FCB656-EE74-45C5-83FD-A2A52162473C.jpg
  14. Feb 15, 2024 at 12:14 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Longevity. AGM batteries last forever. I traded my last Ram with the original 8 year old Mopar AGM still under the hood doing it's job. Most OEM non AGM batteries I have had fail at 3 years on the dot
  15. Feb 15, 2024 at 12:27 PM
    JayDee
    JayDee New Member
    It has a guage. LOL (would be good to have some actual numbers on it) My truck idles at about 14v but drops to around 12.5v when driving.
    An advantage to the SR5 gauges is that they are analog and are easier to read than the digital versions.
  16. Feb 15, 2024 at 2:17 PM
    Markysharky
    I’ve had corrosion issues and a little leakage from an acid battery in my 2018 Tacoma I had that was a pain. I would rather swap and not have to worry about that making a mess down the road.
  17. Feb 15, 2024 at 4:03 PM
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    I noticed the same thing, voltage actually increases off the throttle, deceleration, etc. It's kind of opposite of the old school where you would see a voltage dip at idle and deceleration then an increase as the RPM's increase. I'm inclined to think that the alternator has a built in clutch on the pulley. VW has had this for years. It's designed to supply power on demand which reduces the load on the engine when power is not needed vs a constant output of power regardless of load needed. It's another way to gain any increment of mpg for fuel economy.
  18. Feb 16, 2024 at 11:02 AM
    AND
    AND New Member
    Washington, PNW
    PapaDave418[QUOTED] likes this.
  19. Feb 20, 2024 at 6:39 AM
    22Tundraplat253
    22Tundraplat253 New Member
    Chanh
    2022 Tundra Platinum
    Wheels,lift,air level std stuff
    Did you have to put a diode in for charging?
  20. Feb 20, 2024 at 7:17 AM
    #50
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Curious if you or anyone on here knows if the hybrid owners would benefit from an upgraded battery ? Since the battery is next to hybrid, in the rear cab ...really don't want leaking acid and corrosion. Thanks.
  21. Feb 20, 2024 at 8:57 AM
    #51
    Jettster
    Jettster New Member
    that's the hybrid battery, starting battery is under the hood near the firewall passenger side
  22. Feb 20, 2024 at 9:20 AM
    #52
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Actually, for us Hybrid owners, both batteries are under that back seat, where your start battery is, we (hybrid) have an Inverter.
  23. Feb 20, 2024 at 9:26 AM
    #53
    Jettster
    Jettster New Member
    oh wow that's new to me...that probably helps weight distribution...duh obviously noob non-hybrid owner here...I'd def go AGM when the starting battery dies either way
  24. Feb 20, 2024 at 9:31 AM
    #54
    Maharisc
    Maharisc w/Patty
    Karl
  25. Feb 20, 2024 at 9:37 AM
    #55
    MaxPayne3
    A gel cell (Optima) or AGM battery (Odyssey) are definitely an upgrade in terms of spill and leak proof. If you're running additional accessories, lights, stereo, inverters, etc would definitely be a plus. If you are leaving stock as is, the only benefits would be longer battery lifespan and no worry or acid leaking or spilling.
  26. Feb 20, 2024 at 1:02 PM
    #56
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Nope that was more of a 4Runner and tacoma thing I think. My non-hybrid alternator pumps out up to 14.5v
  27. Feb 20, 2024 at 1:44 PM
    #57
    22Tundraplat253
    Chanh
    Sweet thanks
  28. Feb 20, 2024 at 2:10 PM
    #58
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Your wiring triggers me, just a bit lol. I was told to stay away from X2 as they’ve been historically problematic with respect to heat and longevity. No clue of any validation to that but a quick search while I was at the shop showed a lot of hits so opted for an Odyssey battery personally which was similarly priced.
  29. Feb 20, 2024 at 2:21 PM
    #59
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Haha what’s not shown are my BlueSea circuit breakers which look nice but yes over time a project here and there has added a few wires!
    Goobax[QUOTED] likes this.
  30. Dec 7, 2024 at 5:40 AM
    #60
    Jds685
    Jds685 2nd Tundra
    CT
    2024 Tundra i-Force Max 1794
    Is the OEM battery flooded or EFB?
    Anyone know if it's the exact same battery for the hybrid that's installed from the factory?
