General Supercharger Thread
  1. Feb 5, 2024 at 10:08 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It may have attributed to higher cat temps but I doubt it would ruin the cat. The O2 code and towing may just be a coincidence.
  2. Feb 5, 2024 at 10:10 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes. PCV side only though. I've not seen any posts with CCV side accumulation.
    The bigger question is which can is best since Radium changed their design.
    Jeff_1974[QUOTED] and Mdl like this.
  3. Feb 5, 2024 at 10:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I can't believe all that flak on the "Amazon catch can install" thread. You can give a pro or con reply but, Man give it a rest.
    ARES35, reywcms and PolishedTRD like this.
  4. Feb 5, 2024 at 10:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    somewhere in this thread is a picture of the BUILT-IN pcv recycle system our tundras use. it's quite nice.
  5. Feb 5, 2024 at 10:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol with image proofs etc. Whatever- what do we know? lol
  6. Feb 5, 2024 at 10:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Went out to rigs and coffee Saturday but had a chance to meet up with a few fellow tundra owners. One has a gen 3 with intake, jb4 tuner thing, 37s etc. He was claiming it would be a close run lol. Ran from 40mph and I was in 2nd and on the hit pulled instantly a half car and continued to freight train away at least 15-20mph rate. Good times
    1UP, nchlsbr, snivilous[OP] and 14 others like this.
  7. Feb 5, 2024 at 10:56 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    1UP, ZPhilip, ssmokedz and 7 others like this.
  8. Feb 5, 2024 at 11:01 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    All gas engines have a PCV now, before they used to vent to atmosphere and drip the condensed oil vapor on the ground, or through a air filter on the valve cover (and drip on the engine, and then the ground), or get drawn out the valve cover into the exhaust via a one-way valve under vacuum and then burned off. They can't do this any more, obviously because of environmental harm of oil on the ground or excess hydrocarbons in the exhaust.
    99% of the manufacturers just route the PVC to the intake, so any blow-by gets burned in the combustion chamber and any hydrocarbons get caught by the cats, good to go. The problem is the oil vapor from the PCV gets burned along with your fuel, meaning your fuel isn't burned as clean and you're leaving efficiency/power on the table. So, it's not necessary, but some of us would like to filter the oil out of the combustion chamber.
    I found some old pictures from my Tacoma, NA V6. First picture is my installation and fresh fuel filter on the output of the catch can, second picture is the fuel filter after 3000 miles and third picture is how much the can caught between oil changes.
  9. Feb 5, 2024 at 12:45 PM
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
    Which ones are recommended?
    Saltyhero13[QUOTED] likes this.
  10. Feb 5, 2024 at 1:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's up to you and how much you want to spend. I'm rocking a $20 catch can that works well or you can spend up to $200. Whatever you feel is right.
  11. Feb 5, 2024 at 1:38 PM
    Jeff_1974
    Jeff
    Tennessee
    You have an Amazon one ?
    Intercooler location require changing the oil catch can’s install location ?
    Saltyhero13 likes this.
  12. Feb 5, 2024 at 2:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You could mount it on the either side of the SC or next to the intercooler reservoir. You may need to fabricate a mounting bracket. Look for catch cans that don't vent to atmosphere. Especially if you live in a wet area. Condensation/oil can accumulate in your valve covers.
    You can search catch can for some location ideas.
  13. Feb 5, 2024 at 3:34 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Forgot something hit the tree on the way.
    Didn't make any noise I hoped it was foam before forgetting about it.
    No dent but won't just wipe off.
    M3Tundra-JK likes this.
  14. Feb 5, 2024 at 6:06 PM
    Saltyhero13
  15. Feb 5, 2024 at 6:20 PM
    Saltyhero13
  16. Feb 5, 2024 at 6:31 PM
    Saltyhero13
    :mudding:
    ARES35, Mdl and reywcms[QUOTED] like this.
  17. Feb 6, 2024 at 7:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  18. Feb 6, 2024 at 8:16 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
  19. Feb 6, 2024 at 2:29 PM
    Saltyhero13
  20. Feb 7, 2024 at 6:46 AM
    blenton
    blenton New Member
    What are you guys running for plug gap? Whipple recommended switching to Denso IKH22 plugs which are gapped at .028, but notes that you could also keep the factory plugs which are gapped at .044. That’s a bit of a difference. The plugs above are .035; SCOL has a little blurb about plug gaps and generally recommends around .035 when adding a SC.
    Anybody tried stretching that .028 gap out? Any problems or benefits to running a longer gap on these SC motors?
  21. Feb 7, 2024 at 6:48 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Excellent timing of this post @blenton I'm getting ready to order plugs before I swap my Harrop 80mm pulley on.
    blenton[QUOTED] likes this.
  22. Feb 7, 2024 at 7:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's odd as a rule of thumb the higher the psi the colder the plug and smaller gap. Larger gap may increase chance of a misfire or blowout.
    I just did a change 2 months ago still using the ikh24 flavor in the IX iridium gapped to .026.
  23. Feb 7, 2024 at 7:39 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  24. Feb 7, 2024 at 7:50 AM
    blenton
    blenton New Member
    Did you really just refer me to the search bar…? o_O
  25. Feb 7, 2024 at 7:56 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yes...but only because I know we've had this discussion a few times before, not to be a dick...
    Mine are .022 per ProSpeed's suggestion, been working well at that gap for over 3 years now.
    Winks4x4Toy, e30cabrio, nags and 4 others like this.
  26. Feb 7, 2024 at 8:01 AM
    blenton
    blenton New Member
    Ha. No worries. To be fair, I did try the search bar first. I recalled some semi-recent discussion about a different plug and found jowetts post I quoted above. But I didn’t feel like reading through all 460 pages. Again..
    armyoffoo and Saltyhero13 like this.
  27. Feb 7, 2024 at 8:09 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    IKH24 @.028
    blenton and Mdl like this.
  28. Feb 7, 2024 at 8:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I messed around with gapping down to .021 and up. I settled on the .026 but whatever gets your spark off...haha
    A smaller gap could help deter a misfire. I dealt with a intermittent misfire and that happened with my plug opening up to
    030.
  29. Feb 7, 2024 at 9:08 AM
    blenton
    blenton New Member
    This was the article from SCOL I was looking at the other day. They make some rules of thumb, but do say that it is engine-dependent.
    https://superchargersonline.com/2002/10/16/the-skinny-on-spark-plugs/
    I found this from NGK on heat ranges. Still not 100% on it, but it makes more sense.
    https://ngksparkplugs.com/en/resources/understanding-spark-plug-heat-range
    I also found this from ProCharger to be informative. Hopefully I'm not being led astray..
    https://www.youtube.com/watch?app=desktop&v=ohhCoeQ2TSg
    Of course, there are reasons why I'm asking about plugs. Mainly for curiosity, but the tech notes from whipple about being able to run stock plugs had me curious. I pulled a plug with about 1000 miles on it to verify gap the other day and found it to be pretty sooty - more-so than I recall seeing plugs and definitely more than I've seen on this truck. But the insulator appeared fine, so I'm guessing that means the heat range is correct - hot enough to burn off junk from the insulator, but cool enough to not cause misfires. So I decided to look more in to the gap, wondering if perhaps I could extend the gap a little; perhaps some of the soot is from a little bit of incomplete combustion from a smaller than necessary gap. Also took a bit hit on fuel economy at cruise on the highway. Ya ya ya ya - I know, don't install a SC and complain about money at the pump... Ha.
    I'm still in the low boost range, only seeing 5.x psi at WOT. I think it blipped 6 psi once, but that's it. For reference, here's a pic of the plug. Rey and Sniv both chimed in already for me, which I appreciate. Just got me thinking a little bit and I decided to chase the rabbit hole. I've gotten so pampered just doing routine maintenance on this beast it's like I forgot how to figure out the why and how.
    armyoffoo likes this.
  30. Feb 7, 2024 at 11:54 AM
    blenton
    blenton New Member
    I decided to ask Mr Richard Holdener of Youtubedom about plugs; he got me straightened out on the hot/cold plug. Don't know why I was misunderstanding that. He also said I can run .100 plug gap and be just fine on a N/A motor... At least from a power making perspective. ;)
    nobodyintexas and Saltyhero13 like this.
