Help Determining Aftermarket Outlet Use
Discussion in '3rd Gen Tundras (2022+)' started by awhitehouse, Feb 4, 2024.
  1. Feb 4, 2024 at 11:12 AM
    awhitehouse
    awhitehouse [OP] New Member
    Alan
    Hi. I am hoping someone out there may have an idea what this outlet is on my vehicle. I have a 2022 CrewMax 1794 I bought used from the dealer. On the front bumper I have a 3 pin (round) male outlet. I traced the wire as best I can. I can tell it is grounded to the body and may have an inline fuse on it but it doesn't appear to hook into either fuse box. It disappears into the engine area and I haven't been able to find a diagram yet as to what that part of the engine is all about. I attached my multimeter while the engine was running and off and didn't register anything. Anybody have any guesses? Pictures attached. Thanks.
  2. Feb 4, 2024 at 11:38 AM
    DRP
    DRP Old Member
    Dave
    Possibly for an electric winch on a trailer?
  3. Feb 4, 2024 at 11:41 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Engine block heater.
    That's the 120v inlet and apparently there has to be an adapter to use an 120v extention cord.
  4. Feb 4, 2024 at 12:23 PM
    awhitehouse
    Alan
    Hmmm. I would have never though engine block heater. All the engine block heaters I have seen in the past had a normal extension cord plug in. I will investigate it more.
    pwpblue[QUOTED] likes this.
  5. Feb 4, 2024 at 12:26 PM
    awhitehouse
    Alan
    A winch control had crossed my mind, but I assumed it would be for a front winch which there is no indication there ever was or that has wiring to support that.
  6. Feb 4, 2024 at 12:32 PM
    DRP
    DRP Old Member
    Dave
    I missed the "front" in your original post. Probably not a trailer winch in that case. Most likely block heater.
  7. Feb 4, 2024 at 1:31 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    If it was a winch control, you should see some evidence of a solid bumper to support a winch.
    Given that it is the female part of the outlet, it wouldn't be hot! My guess is a block heater as well. Too bad they didn't give you the cord to go with it. Any electrical store will be able to set you up with a cord to work with it. Or maybe even Toyota?
    I guess you are in a colder climate? That would make sense for the previous owner to have a block heater installed.
  8. Feb 4, 2024 at 1:48 PM
    awhitehouse
    Alan
    I am in southern Ontario. Used vehicle so I am guessing the original owner didn't include the cord when he traded in. I will contact the dealer about getting the adapter cord. Thanks everyone for the insights!
  9. Feb 4, 2024 at 2:27 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    SP3ll✔️ and Mattedfred like this.
  10. Feb 4, 2024 at 2:46 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    Can confirm this is the block heater.
    if you need the cord order from action truck. Defa is the company that makes them.
    SP3ll✔️, Mattedfred and pwpblue like this.
  11. Feb 5, 2024 at 5:02 AM
    awhitehouse
    Alan
    Thanks. Good to have a source for the cord other than the dealer where the price will be 3x as high.
    Oldandfat[QUOTED] likes this.
