  1. Feb 2, 2024 at 1:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok I took the radio into the local hardware store and found some screws. Now to wire it. Might not get to the camera and shocks today
  2. Feb 2, 2024 at 4:16 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I have come here to chew bubble gum and assault your eye holes.... Guess which Im out of Screenshots_2024-02-02-18-08-18.png
    Voss, artsr2002, CodyP and 2 others like this.
  3. Feb 2, 2024 at 5:05 PM
    Eye holes.
    RUSTYNUTS, metalpete and VR6T[QUOTED] like this.
  4. Feb 2, 2024 at 5:16 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I think the no side mirrors bothers me more than anything
    batman900 and VR6T[QUOTED] like this.
  5. Feb 2, 2024 at 5:20 PM
    VR6T
    It is disturbing isnt it.
  6. Feb 2, 2024 at 5:21 PM
    VR6T
    After seeing that youre right
    shifty`[QUOTED] likes this.
  7. Feb 2, 2024 at 5:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So I got all the interior lights buttoned up. Even changed the 03's key light to red so it all matches now.
    Got the radio installed and working.
    Still need to wire the backup camera and hands free mic.
    I got another stumper for you guys.
    My tailgate handle was floppy and didn't engage until it was pulled all the way. The tailgate also doesn't like to stay shut sometimes.
    So I replaced the tailgate handle with a camera handle combo. I tested the handle before install. It worked great. Swapped it in and now it's floppy. The old handle is working fine now that it's out. I lubed everything already
    What am I missing? Some part of the outter mechanism must be to blame.
    Any ideas?
    RUSTYNUTS, artsr2002, BroHon and 2 others like this.
  8. Feb 2, 2024 at 5:38 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Took the sway bar completely off. 1st time doing so and I think I like it. Can definitely see how it could be problematic at higher speeds, and if you're prone to over-correcting. I'll leave it off for a while and see what happens.
    As far as the clunk? It seems to be quieter, but still present. Gotta say, my lca bushings look almost non-existent... can't wait until I replace those. Motor mounts look like they've seen better days too, but they're probably fine.
  9. Feb 2, 2024 at 5:39 PM
    VR6T
    I wanna see the pretty lights
  10. Feb 2, 2024 at 5:59 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    :worthless:
    artsr2002 and BroHon like this.
  11. Feb 2, 2024 at 6:01 PM
    Yes, are the white retention clips intact? If not, it'll result in loose/floppy behavior. Same is true on regular doors. The opening rod needs to be contained to avoid floppy behavior.
  12. Feb 2, 2024 at 6:03 PM
    And @455h0le_dachshund these white clips are what I'm talking about. They need to be intact, and the rod snapped into them. There's one midway down each rail. Note the bar is popped out in this pic.
    oscardog86, artsr2002, BroHon and 3 others like this.
  13. Feb 2, 2024 at 6:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The retention clips on the handle mechanism? Yes they are new.
    Or do you mean on the outter latching mechanisms? I ran out of daylight before I could investigate those.
  14. Feb 2, 2024 at 6:05 PM
    Well both, really, but see my last pic.
  15. Feb 2, 2024 at 6:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'll have to check those tomorrow :thumbsup:
  16. Feb 2, 2024 at 6:08 PM
    If yours are cracked or missing, p/n is 69749-34010
    oscardog86, CodyP, biebs96 and 2 others like this.
  17. Feb 2, 2024 at 6:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Oops, missed that post. @B888s no tricks, i put some grease on the rings to sorta hold em centered, and a sharp shove slid em home. Didnt give me no trouble.
    B888s likes this.
  18. Feb 2, 2024 at 6:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thanks bud
    VR6T likes this.
  19. Feb 2, 2024 at 6:34 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    After she takes lead on disposing of the body, you know she's a keeper.
  20. Feb 2, 2024 at 7:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I found some other stuffs I need to check after the rain stops tomorrow. Looks like the panel being bowed is another culprit. Pretty sure mine is bowed from the PO transporting motorcycles. So ill hammer ot out with my mallet. Also looked like I can adjust the strikers.
    Tomorrow after that, I still gotta install a desert armor LED pod on the 06, wire the backup camera on the 03, unwind the RS3200 antenna from the steering column and run it up the A-pillar (for max keyless range) along with the hands free mic, remove the PA speaker, and install rear 5100's.
    KNABORES likes this.
  21. Feb 2, 2024 at 7:38 PM
    daveeasa
    Yeah my panel makes the handle work as you describe cause it’s such a thin and bent pos. Hence my desire for HDPE panel replacement w small cupholders. And some grooves for the rods.
    455h0le_dachshund likes this.
  22. Feb 2, 2024 at 7:40 PM
  23. Feb 2, 2024 at 7:42 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    If that's photo shopped it's pretty good. Not only no mirrors but the inside windows are fogged up solid... and he/she drove it to the gas station... Blind. Purple = :puke:
    RUSTYNUTS likes this.
  24. Feb 2, 2024 at 7:44 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    bmf4069, RUSTYNUTS and artsr2002 like this.
  25. Feb 2, 2024 at 7:54 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Definitely a T100 with a Camaro photochop
  26. Feb 2, 2024 at 7:57 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    He da real GoPro
  27. Feb 2, 2024 at 8:07 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Looking closer I think that's real. Pretty detailed with the moisture on the panels/front bumper, and the reflections look legit...
    I think the nose is a Charger, and why they said DODGE :rofl:
  28. Feb 2, 2024 at 8:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think the hood is the dodge part. Look at how well the front clip mates to the T100 cab. That's art.
    BroHon[QUOTED] likes this.
  29. Feb 2, 2024 at 9:08 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
  30. Feb 2, 2024 at 9:10 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    my personal favorite:
