  1. Jan 31, 2024 at 10:27 AM
    And we’ll go deeper yet. Basically have the block, rotating assembly and oil pan left when it’s torn all the way down. Cam has to come out.
    BroHon[QUOTED] likes this.
  2. Jan 31, 2024 at 12:21 PM
    May as well get some high flow heads and toss 'em in. Hello Summit, hello more HP.
    des2mtn, KNABORES[QUOTED] and bmf4069 like this.
  3. Jan 31, 2024 at 12:36 PM
    It's because it's a chevy.
  4. Jan 31, 2024 at 12:39 PM
    He just wants his truck back sans DOD. The 6.2 is 420hp, he’s happy.
  5. Jan 31, 2024 at 3:10 PM
    Who’s ready for fuckit February?!? That’s a thing right?
  6. Jan 31, 2024 at 3:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is that what you do after Dry January?
  7. Jan 31, 2024 at 7:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  8. Jan 31, 2024 at 7:11 PM
    Wait, we have Dry January? We already have No Lube November. What do people have against moist?
    BroHon likes this.
  9. Jan 31, 2024 at 7:14 PM
    tpope, BroHon, artsr2002 and 2 others like this.
  10. Jan 31, 2024 at 7:15 PM
  11. Jan 31, 2024 at 7:17 PM
    He always sounds like he sauced and whining about his old lady beating him up or something. And he rambles. Good golly does he ramble.
    tpope, BroHon, FirstGenVol and 2 others like this.
  12. Jan 31, 2024 at 7:31 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
  13. Jan 31, 2024 at 8:14 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
  14. Jan 31, 2024 at 8:16 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    This is why I sold my ‘17 GMC Sierra at 85,000 miles!
    That and the 4L60E transmission grenading.
    KNABORES[QUOTED] likes this.
  15. Jan 31, 2024 at 8:43 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    NUDRAT[OP], Sunnier, BroHon and 3 others like this.
  16. Jan 31, 2024 at 9:16 PM
    Doesn't look like it. If you look at the plaster outline around it it looks like it was cut in. I'd say probably in the 80s.
  17. Jan 31, 2024 at 9:19 PM
    ToyotaDude
    ToyotaDude Member
    That makes sense. Think PO remodeled around then.
  18. Jan 31, 2024 at 9:24 PM
    It looks like your standard Broan cheapie fart fan. Coulda been 90s. The ones they make today still look like that. Can't find a picture of the insides but it looks like this:
  19. Feb 1, 2024 at 3:04 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those little shaded pole motors haven't changed a lot. Outside of the bearings getting trashed a new one won't be much different.
    If it's quiet after oiling that's good enough.
  20. Feb 1, 2024 at 3:38 AM
    I did the same thing with my 1991 fart fan last year. I wanted to replace it but didn't feel like cutting the ceiling to make one fit and couldn't find an exact match in size.
  21. Feb 1, 2024 at 3:58 AM
    It's the hand waving that does it for me. One of the most animated speakers I've seen. He's like a real life caricature drawing.
    FrenchToasty and BroHon like this.
  22. Feb 1, 2024 at 4:04 AM
    ToyotaDude
    ToyotaDude Member
    Yep. I also wrapped the edges of the sheet metal insert with black tape to reduce noise from vibration at the mating surfaces. The blower wheel isn't very balanced.
    Festerw[QUOTED] likes this.
  23. Feb 1, 2024 at 5:54 AM
    Panasonic makes great low-noise high-CFM fans. I've replaced all fans in my house with them except 1.
    @ToyotaDude isn't the date of manuf'er or other details stamped into the steel right here, maybe including the voltage, model# and patent#?
    daveeasa and FrenchToasty like this.
  24. Feb 1, 2024 at 6:00 AM
    Did you find exact fits or make the ceiling hole bigger to fit? I'd like to replace all 3 of ours when I have the time.
  25. Feb 1, 2024 at 6:31 AM
    Three total, for one I was relocating the fan during remodel. Another was new construction. The last one was in the kids' bathroom and I had to open the hole a bit. You may be able to find exact fits.
    YMMV, but most of those fans are either nailed between studs, or with ones I've replaced in my house and previous houses, they used the manuf'er brackets to tie them between two standard width studs. If you have one with attic access, I recommend doing one of those first to see what your builder chose to do, and you'll know what to expect on other fans where you may not have access from the back side. Install is pretty straight forward. Make sure the power is off, pull the old, enlarge hole if needed, bolt it in, wire it up.
    The big aha/gotcha is the vent diameter. Check to see if your current vent is a 3", 4" or 6" (I think are the three common sizes, check first). Also, check the vent at the wall of the house to see what size it is, in case the builder adapted up/down for some reason. Like, my house is only 20yrs old, but the builder used a 4" exit vent, and the original Broan "builder special" exhaust fan was 3". Fortunately he adapted at the fan and ran 4" hard line to the vent ... but you may not be so lucky. Not a lot of variables to feck up here.
  26. Feb 1, 2024 at 6:34 AM
    You may be able to use Build.com's system to find what you need, size wise, using the filters on the left here: https://www.build.com/panasonic-bath-fans/c112758
    I think "Housing length" may be what you're looking for? Possibly. X-ref the specs to Panasonic's site.
    And be careful, not all have a light integrated.
  27. Feb 1, 2024 at 7:08 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I just redid a bathroom in my house and didn't want to deal with replacing the fan so I just cleaned mine up. Looks similar to yours. My house was built in 1992.
    VR6T likes this.
  28. Feb 1, 2024 at 7:19 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    my friend use to do his insurance for him when he worked at State Farm. Dudes from Houston.
    edit: was from Houston I think he mentioned moving in one of his videos
  29. Feb 1, 2024 at 7:20 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yep. I think he's in Tennessee (TS) now.
    bmf4069 likes this.
  30. Feb 1, 2024 at 7:27 AM
    :( Damn it.
