Windshield wiper reservoir replacement
Discussion in '1st Gen Tundras (2000-2006)' started by 66chevelle, Jan 17, 2024.
  1. Jan 17, 2024 at 3:30 PM
    66chevelle
    66chevelle [OP] New Member
    Galen
    05 dc tundra rwd
    Just purchased a southern 05 SR5 DC RWD with 90k. I wanted a “rust free” tundra, rwd or 4x4 for camping fishing etc… I found a well documented example in Florida and decided to jump on it. I live in Nebraska so I reluctantly did everything online against my better judgement. I purchased from a reputable dealer who was upfront, sent lots of photos and was willing to negotiate since it was due for 90k mile maintenance. I was pleasantly surprised when I was finally able to put my hands on it, inspect it in person. It was better than described. I immediately took it to my mechanic and he ensure me that I purchased a sound vehicle. I felt very lucky! I’ve been reading the Tundra forum for awhile and very much appreciate the knowledge and valuable insight you guys bring. Most of my questions have already been addressed but will not hesitate to ask for help when needed.
    JasonC. and The Black Mamba like this.
  2. Jan 17, 2024 at 3:32 PM
    What was the question? Do you need a windshield washer reservoir?
  3. Jan 17, 2024 at 3:43 PM
    66chevelle
    Galen
    05 dc tundra rwd
    Valuable lesson learned. Replace windshield wiper fluid in a vehicle bought in Florida that now resides in Nebraska before the temps drop below zero. Replacement doesn’t look to difficult but with 9 inches of snow and single digit temps I’ll have to wait for warmer days. Any tips or anything I need to know?
  4. Jan 17, 2024 at 3:44 PM
    shifty` Animals and insects don't do drugs
    Ooof, be careful with those low-mile engines. Check all seals and gaskets!
  5. Jan 17, 2024 at 3:45 PM
    66chevelle
    Galen
    05 dc tundra rwd
    My mechanic said everything looked good but I’ll keep an eye out. Thanks
  6. Jan 17, 2024 at 3:47 PM
    66chevelle
    Galen
    05 dc tundra rwd
    It looks like I’ll need a new on but utill I have a chance to check it out im not sure
  7. Jan 17, 2024 at 3:47 PM
    Tank costs a fortune
    Some come with a level sensor pre-installed - check which you have before ordering
    I wouldn't doubt if this is one of the rare cases where it makes sense to buy the Dorman brand replacement part; wouldn't surprise me if they were the ones to make it in modern day.
  8. Jan 17, 2024 at 3:52 PM
    66chevelle
    Galen
    05 dc tundra rwd
  9. Jan 17, 2024 at 4:18 PM
    bfunke
    bfunke Tundra Curmudgeon
    It may be the pump or the grommet. Mine was leaking and the pump had split
  10. Jan 17, 2024 at 5:37 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome from Texas!
    :worthless:
    Jack McCarthy likes this.
  11. Jan 23, 2024 at 2:30 PM
    66chevelle
    Galen
    05 dc tundra rwd
    It looks like the grommet is where it’s leaking. Can I replace just the grommet or is it attached to the filler neck?
  12. Jan 23, 2024 at 2:44 PM
    66chevelle
    Galen
    05 dc tundra rwd
    I have not found the grommet by itself, wondering if it is attached to the neck or the reservoir?
  13. Jan 23, 2024 at 2:56 PM
    Using the parts system described in the bullets at the top of this sticky post (super handy info in there), I was able to pull up this exploded diagram in about 20 seconds. Without pics, I'm flying blind. Do you see your grommet in this exploded diagram? If not, there's a solid chance you can't buy it alone.
    (Note: This diagram is for my AC, you have a DC, its exploded may be different, you may want to use that post I linked to look up your own truck by its VIN to get DC-specific parts. This diagram is in the Electrics section, under 'Windshield Washer')
  14. Jan 23, 2024 at 2:58 PM
    Oh, and a spoiler. If the grommet is here, no, about a million people have asked in the past, you cannot buy that part alone. You hafta buy the entire assembly that's marked "85301", which is three pieces total.
  15. Jan 23, 2024 at 3:11 PM
    66chevelle
    Galen
    05 dc tundra rwd
  16. Jan 23, 2024 at 3:21 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Junk yard may be an option for you, OP.
  17. Jan 23, 2024 at 5:52 PM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
  18. Jan 23, 2024 at 6:13 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  19. Jan 23, 2024 at 6:21 PM
    bfunke
    I was thinking the grommet where the pump plugs in could be a leaker as well.
  20. Jan 23, 2024 at 8:12 PM
    66chevelle
    Galen
    05 dc tundra rwd
    It’s definitely where the neck connects to the reservoir. The local Toyota dealer had the neck piece for $122 but couldn’t tell me if the grommet was attached to the neck or the reservoir. Took shiftys advice and ordered the entire assembly from Dorman for $140. They only had 4 left in case you need one.
  21. Jan 24, 2024 at 3:02 AM
    I wouldn’t doubt if that’ll be a part that ultimately gets discontinued soon. Seems like, as this generation is approaching hit the 15yr-from-its-end point in 2021, a lot of parts are being discontinued. We are running up on 18yrs since the generation ended, I expect it’s only going to get worse. If/when Dorman stops making parts you know you got a problem :rofl:
    That said, I should really take mine apart, and measure the grommet with a digital caliper for OD, ID, and thickness. There has to be a rubber grommet at Fastenal or McMaster-Carr that fits and it’s probably only $2 or something. In fact you may be able to get one slightly more robust which may seat better or something.
  22. Jan 24, 2024 at 5:58 AM
    bfunke
    Wouldn’t it be nice if a company like LMC Truck started making the discontinued parts like they do for old Fords and Chevys
    shifty` and KNABORES like this.
  23. Jan 24, 2024 at 5:55 PM
    66chevelle
    Galen
    05 dc tundra rwd
    I appreciate all of your input thanks
  24. Jan 24, 2024 at 8:39 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This is the way right here!
  25. Jan 24, 2024 at 9:08 PM
    Black4X2
    Black4X2 New Member
    2007 Black Tundra Limited 4X2
    I have repaired a lot of things with JB Weld. I have repaired small plastic gas tanks with it and they didn't leak. If it was mine I would give it a try.
  26. Jan 25, 2024 at 7:05 AM
    FishNinja
    Lee
    06DC2wd
    this would be even better if he made a quick disconnect/connect. So he could just swap out bottles.
