6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jan 22, 2024 at 6:14 PM
    #2221
    Savmikey47
    Savmikey47 New Member
    Looks amazing. Anymore pics?
  2. Jan 22, 2024 at 7:50 PM
    #2222
    Skolberg
    Skolberg New Member
    Chase
    2014 TRD PLATINUM
  3. Jan 23, 2024 at 5:45 AM
    #2223
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    I think you swayed me to pursue this setup. How's the ride compared to factory?
    Skolberg[QUOTED] likes this.
  4. Jan 23, 2024 at 5:55 AM
    #2224
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    Thank you so much. Posts like this help so much for the rest of us. Just curios since you said no shims, do you have the 38 gal fuel tank?
  5. Jan 23, 2024 at 7:10 AM
    #2225
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    6112 on lowest setting netted 0.75" lift over stock as advertised. Stock 2.5 gen TRD wheels. I installed these over a month ago but just now realized I haven't taken any pictures of the whole truck since then except this one! Enjoy.
  6. Jan 23, 2024 at 7:25 AM
    #2226
    Skolberg
    Skolberg New Member
    Chase
    2014 TRD PLATINUM
    @Skaufma0 The ride is considerably improved. It feels much smoother over bumpy asphalt and washboard dirt roads. It also feels less rigid than the stock Platinum suspension, better absorption and more cushioned feel without feeling sloppy. Handling feels as controlled as stock as well and it isn't sluggish at all on the 285x75's.
    @radon222 Thanks! I wanted to include all of my specs in one post, I spent too many hours searching the forum for what fits and what doesn't given lift, offset ect. Tons of good info on here though if you're willing to search for it. I actually have the small 26 gal tank (and I hate it), my rig had no driver side lean even with a full tank so I decided no shims for me.
    Skaufma0 and radon222 like this.
  7. Jan 23, 2024 at 3:11 PM
    #2227
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Wow, That turned out Nice!
  8. Jan 23, 2024 at 6:45 PM
    #2228
    Savmikey47
    Nice. Looking to install my set up this weekend
  9. Jan 24, 2024 at 9:59 AM
    #2229
    Skolberg
    Skolberg New Member
    Chase
    2014 TRD PLATINUM
    Thanks @Coachbuilder1! Your shackles are top quality and made a noticeable difference in ride.
    @Savmikey47 post up pics when you get it done! My install was anything but smooth on a 10 year old pickup, had a swaybar end link nut break off the frame, and both of my lower shackle bolts were completely seized in the inner collar of the bushing. Hopefully you have smoother sailing than I did!
    BillyB likes this.
  10. Jan 26, 2024 at 2:48 AM
    #2230
    SRQRUSTY
    SRQRUSTY New Member
    Bone stock 2018 Tundra 4X4
    Sooo.....on a 1.9 setting can I run a 285/70R18 on an 18x9 with 18 offset???
    Thanks
  11. Jan 26, 2024 at 9:24 AM
    #2231
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Yes no maybe
    Most likely yes since the common size is 295/70 on a +25. Likely just need to deal with the flaps
    SRQRUSTY[QUOTED] likes this.
  12. Jan 26, 2024 at 9:54 AM
    #2232
    SRQRUSTY
    SRQRUSTY New Member
    Thanks, I'm getting ready to pull the trigger and don't want to screw it up.
  13. Jan 26, 2024 at 10:17 AM
    #2233
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    After going back and forth for years and reading non-stop reviews (You guys are AWESOME), I finally was able to find a set of 6112 with the 5100 from ShocksSurplus.com during the Christmas season when they ran a small sale on the set. In comparison to not being able to find it on Amazon, I had them set the setting to #3, 1.9", and left the rear at stock height. From the look of it, it just leveled out the truck to make it sit even without a rake. This works for me due to the access to the bed and not having to get a ladder to get up there... LOL. I did have to put in a truck bed step to get up there.
    I went with the 5100 due to the lifetime warranty in comparison to the 5160 with only 90 days (I think). I figured I don't get to go off-road as often, so this would work best for my city/highway driving. I had my nephew put them on and do all the work; he works for Honda (not everyone is perfect), so he was able to use the shop to get it done.
    Issues: I had gone to Firestone to get it aligned (bought the lifetime alignment a while back) and to see what the noise of metal grinding is when I turn all the way left or right. They got it done, and it was off quite a bit, but they said the rub is coming from the skid plate. I had tried to turn the wheel both ways and do not see anything touching from the fender skirt or the metal skid plate under, but when I drive it slowly, it starts to grind. I wanted to find out from you guys if this really is the skid plate and if it needs to be cut, how much should I cut, and where?
    Overall: The ride is better than my stock shocks, and it takes on these stupid "speed bumps" on the VA roads like a champ. Roads are complete garbage here in the 757, and for some reason, they fix them only to be worse or deteriorate in a matter of months. Don't get me started on the Personal Property Tax and the shitty roads in VA. The ride is stiffer but not rough and feels more controlled and reactive to the steering wheel.
    My setup: 6112s @ 1.9, 5100 Rear @ Stock height, Stock UCA, Bridgestone DUELER A/T Revo 3 Sized 275/70R18.
    Attaching some pics below. PXL_20240126_161635725.jpg PXL_20240126_161726302.jpg PXL_20240126_161824016.jpg PXL_20240126_161839904.jpg PXL_20240126_161941370.jpg
  14. Jan 26, 2024 at 11:15 AM
    #2234
    radon222
    Ed
    NW Arkansas
    Stock for now
    Rubbing the skid plate is pretty common and I think most just bend it out of the way.
    If you're on Facebook look up Tidewater Tundras and come to one of the meets. I would love to check your setup.
    Norfolk757[QUOTED] likes this.
  15. Jan 26, 2024 at 11:41 AM
    #2235
    Norfolk757
    Tom
    Norfolk, VA
    I never thought of just bending it out, thanks. I will see how far back it has to bend, maybe get the wife to help with the wheel and measure the gap needed.
    No Facebook here, but i used to come out a while back but things have been busy and i don't get to do upgrades as often as i like. When is the next meet? Thanks again @radon222
  16. Jan 26, 2024 at 11:48 AM
    #2236
    radon222
    Ed
    NW Arkansas
    Stock for now
    The next meet up was just posted today. Feb 18, 2PM - Top Golf Virginia Beach
  17. Jan 27, 2024 at 7:21 AM
    #2237
    SRQRUSTY
    SRQRUSTY New Member
    Sooo am I good to go with this kit and a 275 70 18 on a 18x9 with an 18 offset???
    2018 SR5 Crewmax 4X4
    I'm ready to pull the trigger and don't want to mess it up. Are there any other parts that you would recommend??
    Norfolk757 likes this.
  18. Jan 27, 2024 at 7:27 AM
    #2238
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    How high are you going in the front? I’m assuming you’re leaving the rear stock height? With those wheels offset and 275 size tire you may have slight rubbing at full lock, maybe.
    Nice poon in your profile pic btw.
    AGTundra and SRQRUSTY[QUOTED] like this.
  19. Jan 27, 2024 at 10:07 AM
    #2239
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Get a hold of @memario1214 . He owns Hotshot Offroad and is a member here. He can take care of you.
  20. Jan 27, 2024 at 12:42 PM
    #2240
    SRQRUSTY
    SRQRUSTY New Member
    I am going to get them with the #3 setting which is 1.9"
    Love my Tarpon fishing!
    FISHN43[QUOTED] and RobertD like this.
  21. Jan 27, 2024 at 1:51 PM
    #2241
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You need to change the front mud flaps where body mount is at or take it out, it’s gonna rub no matter what.
  22. Jan 27, 2024 at 2:39 PM
    #2242
    SRQRUSTY
    SRQRUSTY New Member
    The small one in front of the tire or the one behind it???
  23. Jan 27, 2024 at 4:48 PM
    #2243
    Savmikey47
    Finally installed my set up. I went with 1.9 in front with stock height in the back. 275/70/18 wild peaks. Tires look too small now
    silverstreak16, SRQRUSTY and equin like this.
  24. Jan 27, 2024 at 7:25 PM
    #2244
    SRQRUSTY
    SRQRUSTY New Member
    What size wheels and offset are you running?
    ARGrider likes this.
  25. Jan 27, 2024 at 8:32 PM
    #2245
    Savmikey47
    im running 18s +25 offset
  26. Jan 27, 2024 at 10:44 PM
    #2246
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Front wheel rear mud flaps, where the body mounts at…cause the offset of the rims, the corner of the tire will rub against the mud flaps where the body mount.
  27. Jan 28, 2024 at 4:02 AM
    #2247
    SRQRUSTY
    SRQRUSTY New Member
    Thank you
  28. Jan 28, 2024 at 7:33 AM
    #2248
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I ran 275/70-18 with 15 offset, that factory mud flap hump is sticking so far out there’s no way around it, either cut it out, remove it or just get a new universal mud flaps that are flat.
    Just need to spend some time to make a bracket and buy some body panels plastic clips to make it work.
  29. Jan 28, 2024 at 9:37 PM
    #2249
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Found my stock mud flap, you could still see the rub marks
    Kiddnapped Tundra and SRQRUSTY like this.
  30. Feb 2, 2024 at 11:57 AM
    #2250
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    If you haven't pulled the trigger yet we have those guys over here at Hotshot Offroad, and are happy to price match as well as assemble. What I would probably recommend as well is a small carrier bearing drop as well to eliminate stop/go driveline vibrations. We could get you one of those for like $20.
    :fistbump:
