2021 JBL subwoofer output wire color question
Discussion in 'Audio & Video' started by BoyHowdy, Jan 18, 2024.
  1. Jan 18, 2024 at 3:57 PM
    BoyHowdy
    BoyHowdy [OP] New Member
    2021 Tundra
    Hello, it’s me again. I’m sure I missed a thread that discussed this but I wanted to ask about the color of the wires if the JBL sub on the 2021 tundra. I noticed they are black/green. Is it fair to assume the green is positive and the black is negative?
    BlueRibbon4x4 likes this.
  2. Jan 21, 2024 at 8:39 AM
    Dago52
    Dago52 New Member
    2020 Silver 1794 Crewmax 4x4
    BoyHowdy[OP] likes this.
  3. Jan 21, 2024 at 8:48 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  4. Jan 21, 2024 at 9:28 AM
    BoyHowdy
    2021 Tundra
    Thank you for this. I can grab a cheap DMM from harbor freight or Home Depot to be sure.
  5. Jan 21, 2024 at 9:42 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    BoyHowdy[OP] and BlueRibbon4x4 like this.
  6. Jan 21, 2024 at 12:18 PM
    BoyHowdy
    2021 Tundra
    That’s interesting! But yeah the wires and plug going to the sub are green/black, at least in my case. I do appreciate the help though!
  7. Aug 20, 2024 at 5:10 PM
    Bergy24
    Bergy24 New Member
    Did you ever confirm these colors?
  8. Aug 20, 2024 at 8:38 PM
    BoyHowdy
    2021 Tundra
    I just assumed the green was positive and black was negative. It’s been fine although I probably should’ve busted the multimeter on it for good measure but never did.
  9. Aug 21, 2024 at 3:34 AM
    Bergy24
    Bergy24 New Member
    You may want to check into this more.
    I installed mine based on the info below, which is based on JRT info.
    Refer to post 341. This is in alignment with a what came from JMT as well.
    "As you can see, white now goes to green and blue goes to black. With that being said now the green goes to the black connector on the sub and the black wire goes to the red connector."
    https://www.tundras.com/threads/now-closed-10-jbl-sub-box-from-tech12volts-group-buy.37273/page-12
