Transmission Cooler Bracket
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jmunk, Jan 8, 2024.
  1. Jan 20, 2024 at 7:59 AM
    Jmunk
    Jmunk [OP] New Member
    2020 Tundra SR5 Crewmax
    Thanks. Since no one seems to be selling just the bracket. I may get extras cut out if I go the route of the plasma table. I think a lot of DIY people would prefer to get the bracket and a parts list of what to order in an effort to save money.
  2. Jan 27, 2024 at 5:00 AM
    Jmunk
    I’m going to be sending the CAD file off to get the brackets cut in the next week. I’m trying to gauge any interest and if I should get extras cut. Let me know if anyone sees a demand for just the brackets, the rest is an easy parts lists.
    Austintaco likes this.
  3. Jan 27, 2024 at 5:08 AM
    SandMan_1
    SandMan_1 New Member
    2021 Cement SR5
    What is the cost you estimate for the bracket?
    I have a list for the parts with part numbers and links. Cost for everything was about $700 plus tax/shipping. I’ll post it here on Sunday.
  4. Jan 27, 2024 at 5:14 AM
    Jmunk
    I can sepeculate the cost being around $100 for a raw finish and you would need to paint it. I can get it powder coated, I would have to have a conversion about that cost.
    If the demand isn’t there then I can share the name of the shop that will be doing the cutting. He will already have the file and all you will need to do is reach out to him for the bracket. If things went this route it would be cheaper as it eliminates shipping on my end and my handling charges.
    camron1039 and bulldog93 like this.
  5. Jan 27, 2024 at 6:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    bulldog93 likes this.
  6. Jan 27, 2024 at 8:47 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    What will your bracket be using for mounting points, same as GC or are you using just the two that the older brackets (the one in the pic you showed) used?
  7. Jan 27, 2024 at 4:45 PM
    Jmunk
    I’m working on a few different styles. All use the same two bolting points at the bottom. One version has a tab that comes off near the top and attaches to the bolt that the condenser mounts uses to add a second point of contact on the top. Another other uses one point of contact. The brackets are flat for simplicity, I don’t see why this won’t work. Also, the bottom bolts it seems easiest to just put some spot weld nuts on a piece of metal for the bolts to attach to. I also toyed with another style that adds a mouthing point to the hood latch support, this would require drilling a hole and I’m not big on that.
    The first few bracket are based off the Setrab cooler. I’m sure other brackets could easily be made for multiple cooler sizes and models.
    I’m not looking to get rich, I was surprised to find that no one sold just a mount. I like to DIY things as I’m sure others on this forum do. Maybe no one is interested and I’ll just make a few to for friends and people local to me.
    I don’t think it’s a huge concern but I do plan to cover the hose from the cooler to the hard lines with a UV resistant split wire loom, spiral hose wrap, or protective nylon hose sleeve. Given how open the front grill is I don’t think some UV protection wouldn’t hurt and the cost is minimal. My history with boating has taught me that the sun is hard on exposed rubber.
  8. Jan 27, 2024 at 4:51 PM
    Jmunk
  9. Feb 11, 2024 at 9:42 AM
    SandMan_1
    2021 Cement SR5
    Transmission Oil Cooler Line Clamp - Toyota (90466-16004)
    - qty 8
    - $3.28 each
    - total: $26.24
    Cooler Assembly, Transmission Oil With THERMOSTAT - Toyota (32970-34030)
    - qty 1
    - $194.04
    Automatic Transmission Oil Cooler Hose in - Toyota (32941-0C030)
    - qty 1
    - $45.77
    Automatic Transmission Oil Cooler Hose out - Toyota (32942-0C040)
    - qty 1
    - $39.49
    Automatic Transmission Oil Cooler Tube - Toyota (32907-0C020)
    - qty 1
    - $99.03
    Setrab ProLine STD Oil Coolers - 9-series
    Part No. 50-915-7612
    - qty 1
    - size 915
    - $211.31
    sūsa 9-series mounting bracket set
    Part No. 23-9002
    - qty 1
    - $48.39
    sūsa ProLine Adapter - M22 to AN
    Part No. 22-M22AN06-SE
    - qty 2
    - $9.64
    - total $19.28
    sūsa Hose Ends - AN to PL
    Part No. 22-AN06PL06-45
    - qty 1
    - $14.56
    Part No. 22-AN06PL06-30
    - qty 1
    - $14.56
    400 series hose 9.6mm W.P. 250 psi
    - 6 ft total
  10. Feb 11, 2024 at 10:02 AM
    Jmunk
    Very helpful, thank you. I’m surprised that it only took 6ft of hose. For some reason I was thinking I’d need 8ft. I should be getting some brackets in the mail this week to test fit.
  11. Feb 24, 2024 at 5:00 PM
    Jmunk
    I was able to get most of the transmission cooler kit installed today in a few hours. The Gates brand transmission cooler hose I bought was very stiff and didn’t want to go onto the hard line that runs from the thermostat to the front of the engine. The Gates hose is 3/8 but just stiff. I lubricated the hose and hardline but still it would only go about halfway. Gates hose part number is 27059 with a max pressure of 400 PSI.
    I went to Autozone and they had 3/8 transmission cooler hose which online said it was made by Continental but that same part number was printed on a hose that also had Duralast on it when I went it it the store. The hose had writing showing the J1532 rating with a max working pressure of 145 PSI. Will this be strong enough?
    The OEM short lines that run from the thermostat to the hard lines didn’t seem as robust as the Gates or the Duralast and went into the hardline with too much trouble.
    I considered putting the end of the Gates hose in some hot water to soften it up but not sure if it will split eventually since it would be so tight?
    Radarninja likes this.
  12. Feb 25, 2024 at 9:03 AM
    SandMan_1
    2021 Cement SR5
    This is a pic of the hose that comes in the Transmission cooler KIT. Not sure where it's sourced from.
    Here is a link that looks to be as good if not better.
    3/8 inch 10ft
    KT07122S1BK-3.05-AMZ1
    https://www.ievilenergy.com/products/transmission-oil-cooler-hose
  13. Feb 25, 2024 at 10:12 AM
    bflooks
    bflooks New Member
    Metrowest MA
    At $100, I'd be curious if you'd support a 20-row Setrab. IIRC, it was something like 1/2" extra in width. All to the left would make the most sense to me, but that is how I intended to do it if I cut/extend/weld the GCS bracket I have for the 15 row.
  14. Feb 25, 2024 at 10:18 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
  15. Feb 25, 2024 at 11:32 AM
    Jmunk
    I ended up going to my local Napa, we have a distribution warehouse and few miles away. The warehouse usually have everything in-stock, just have to wait a few minutes for it to come from the back. They had bulk transmission cooler 3/8” hose by the foot. The part number was NBH N1956, $2.69 a foot. I got 7ft and had about a foot extra. The hose is made by Gates, part number 6GTHX, max temp 275 and max working pressure is 400. It was fairly pliable and I hit the end with my heat gun for a few seconds and with some ATF for lube it went on without too much of a fight.
    The cooler is on and done. Just need to keep on eye on the connections for a day or two and call it good. So far the demand for selling just the mounting bracket isn’t huge.
    I did turn a pump sprayer into a fluid pump for filling the transmission like others have done. Cheap and super easy, didn’t spill a drop.
    The brackets can be made to fit pretty much any cooler without too much work.
  16. Feb 25, 2024 at 11:46 AM
    SandMan_1
    2021 Cement SR5
    Good call on Napa. Much cheaper. Part number is different from what I could find though.
    https://www.napaonline.com/en/p/NBHH1937
  17. Feb 25, 2024 at 11:58 AM
    Jmunk
  18. Feb 25, 2024 at 2:32 PM
    Austintaco
    Austintaco New Member
    Patrick
    Austin, TX
    2021 Lunar Rock TRD Pro, 2003 Tacoma DC TRD, 1984 SR5 4runner with 1uz, 85 Supra
    285/75/18 Duratraks, 5.29’s and Powertrax in the rear, Eibach Pro lift coils, JBA UCAs, RAS and CB Plus 3, AT transmission cooler, RAGO dash plate, Boost Tow mirrors
    Just joined the Tundra Club on Wednesday with a 21 Lunar Rock. Trans cooler is top of the list for me. Count me in as one interested in a bracket. I’ll be checking this thread and making a purchase list within a week. What’s the consensus on best OBDII gauge reader for trans temps? I have a scan gauge in my Tacoma with trans temps and I’m used to it. Just curious what Tundra owners favor?
  19. Feb 25, 2024 at 2:35 PM
    Austintaco
    Patrick
    Austin, TX
  20. Feb 25, 2024 at 3:33 PM
    #50
    Jmunk
    If you get a complete kit from GCS it comes with a Veepeak now I think. I use a Veepeak and the OBD Fusion App to monitor my temps when I’m curious. It was helpful for when setting the trans fluid level when the temperature came into range.
    Here is the spacer I used for the top mount.
    https://www.ebay.com/itm/1138246898...McYd9XESkm&var=&widget_ver=artemis&media=COPY
    Here are the grommets I used.
    https://www.ebay.com/itm/1952098480...McYd9XESkm&var=&widget_ver=artemis&media=COPY
    I bought my WS fluid from Amazon. I also bought new crush washers for the trans pan drain and check bolt.
    https://www.ebay.com/itm/2954890824...ar=593584851207&widget_ver=artemis&media=COPY
    At the time I bought everything I found this seller on eBay to have the best price on the cooler, fittings, adapters, and mounts.
    https://www.ebay.com/itm/3819185823...McYd9XESkm&var=&widget_ver=artemis&media=COPY
    I bought my OEM items from Fred Anderson Toyota. They offer free shipping and a discount that is automatically applied to your order, at least they did when I ordered. I think there are several threads with the OEM part numbers, if anyone needs them let me know and I can add them.
    I do have one bracket ready to go that is powdercoated a satin black. I have a friend who was interested locally but if he’s not in a rush I can probably sell that one until I get more made in a week or so. I may just get a small batch cut and powder coated. I could sell it unfinished if anyone wanted to further save a few dollars.
    #50
  21. Feb 25, 2024 at 5:45 PM
    #51
    Austintaco
    Patrick
    Austin, TX
    I’m waiting on a tundra owner from a FB group to let me know what “cooler” he bought and did not use. I’m not sure if he bought one of the kits or just a random cooler, but he purchased it and found out his Tundra had one..OOPS…so it’s been in his shed. Thanks for doing this legwork and posting. Unsung hero. I will be interested in the bracket if this other “cooler kit” is not something I can work with.
  22. Feb 25, 2024 at 6:14 PM
    #52
    Jmunk
    I think the Automatic Wholesale kit from Cruiser Brothers is just the cooler, mounting bracket, and hose. You’d need the thermostat, hoses from thermostat to hard lines, hard lines, clamps, and mounting bolts for the hard lines.
    I sourced my bolts, nylon lock nuts, and washers for the cooler attachment to the bracket from Monster Bolts. I can get the sizes for anyone who needs them. Overall the quality was decent but I did get a few bolts that had a few bad threads that I ended up tossing. Overall for the cost I have no complaints.
  23. Feb 25, 2024 at 8:24 PM
    #53
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Austintaco[QUOTED] likes this.
  24. Mar 3, 2024 at 7:19 PM
    #54
    Jmunk
    Is the proper way to set the fluid level in the transmission pan to park the truck on level ground or have the bottom of the pan level front/back and side-to-side?
    When I did mine I had the flat part of the transmission pan level, the frame rail happened ago also be level at the same angle. In my case, I had to raise the front of the truck, this was helpful and gave me plenty of room to fill the transmission and pull the check bolt.
    Just curious what the general consensus is. Doing the check on level ground would have the pan higher in the back. On a lift I’m thinking the pan would be closer to level than not.
  25. Mar 3, 2024 at 7:37 PM
    #55
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Truck on level ground.
  26. Mar 3, 2024 at 7:45 PM
    #56
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Level ground will obviously help but the truck itself being level is more important. I usually put a magnetic level on the pan. If the truck is on a lift, it should already be level.
  27. Apr 28, 2024 at 6:45 PM
    #57
    Jmunk
    The cooler has been on for several weeks. The temperature difference at the cooler between the inlet and outlet is impressive just touching the hoses.
    Today I pulled my boat a little over an hour away. The boat and trailer are around 4,000lbs. Air temperature was 84 degrees, a mix of interstate and hilly backroads. The highest the pan temperature got was 189 degrees.
    I’m not sure one can say for sure how much the cooler helps the transmission, but I would say at the very least it will extend the life. If you piece together your kit or buy a GCS kit I think it’s a worthwhile investment.
  28. Apr 29, 2024 at 12:45 PM
    #58
    Dowloader
    Dowloader New Member
    I installed mine a year ago, at the time GCS was out of stock and also I wanted the 20 row which they discontinued so I made my own bracket using .125 aluminum, prime it and painted it and very happy with the results. I'm attaching a few photos in case you guys want to do the same.
  29. Apr 29, 2024 at 12:54 PM
    #59
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Just make your own. It's not rocket science but it does require some effort. I made my own and it's holding up just fine after 3 years.
    ghott86 likes this.
  30. Apr 29, 2024 at 1:30 PM
    #60
    ghott86
    ghott86 New Member
    VA
    ‘21 Super White SR5 CM 4x4
    x2. If you've got some aluminum or even steel scrap plate lying around, a bench grinder, and a drill - its pretty simple. I made my own mount/brackets as well...but just made a top and bottom bracket vice one that encompassed the entire cooler. It's held up well so far.
