  1. Jan 18, 2024 at 7:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I worked in a feed store in high school. Sometimes you get lucky and the string comes off as it's supposed to. Other times, you're pulling on the wrong side.
    https://youtu.be/Q-NHxRwds4g?si=9lAZmlVUHU0xRU7J
  2. Jan 18, 2024 at 8:07 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    damn she made that look easy!
    :boom:
  3. Jan 18, 2024 at 8:19 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Drift truck just grind it off
  4. Jan 18, 2024 at 8:49 PM
    VR6T
    KingSequioa007 likes this.
  5. Jan 19, 2024 at 4:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    oscardog86 likes this.
  6. Jan 19, 2024 at 5:34 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Im able to reach my hand through the drain hole in the Skid plate and install the tubing on the nipple, remove the lock clip and slide the valve open. Im assuming the stock skid plate doesnt have an access hole like that? I bought the Skid Row plate years ago so dont remember if the stock plate gave me access like that.
  7. Jan 19, 2024 at 5:40 AM
    Before you start shopping, please do yourself a favor. There's a "Suspension wheel and tire" section in this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    This point is taken from that thread:
    • When buying new upper control arms, There are a few types, know what you're getting, read more here to help you decide.
    I recommend checking that before you start digging in too deep.
  8. Jan 19, 2024 at 6:40 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have the skid rows. I haven't changed my own oil in a few years though. IIRC my hand berely fit in the hole to thread the plug back on.
    oscardog86[QUOTED] likes this.
  9. Jan 19, 2024 at 7:00 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I have the jba uca. No complaints at all.
    edit** except they only come in red
  10. Jan 19, 2024 at 7:02 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  11. Jan 19, 2024 at 7:03 AM
    daveeasa
    I have the TC’s on my ‘05 and I don’t love the handling. Pretty happy with the SPC’s on the other trucks. Not sexy at all though. I covet the Taco Pro UCA’s but can’t stomach the price tag. May go SPC on the ‘05 eventually and sell the TC, probably not a major cost delta there, just labor unless I DIY.
    455h0le_dachshund and oscardog86 like this.
  12. Jan 19, 2024 at 7:16 AM
    I mean, they are (or at least were, haven't looked lately) great bang vs. buck. And it's bonus they use a more-standard style of booted balljoint for comfort, durability, ease of swap. I'm just not a fan of the welded-tube-to-plate BJ cradle configuration. That's purely my OCD though, and is probably not founded in reality. SPC probably would have similar weaknesses given they're welding to cast BJ cradle.
    SPC may not be attractive but they're beefy and more configurable than any other option on the market, and the BJ is sealed, and easy to swap. The pros far outweight the cons. Trying to find someone who knows how to properly utilize them on an alignment seems to be difficult though.
  13. Jan 19, 2024 at 7:19 AM
    VR6T
    I'm going to question you in the same way I question my customers from a gunsmith's standpoint. Are you saying that because the jba's cost more and obviously if it costs more it's better? Or have you had Real World experience with the other brand and they're just actual crap. I don't mean second or third hand stories I'm talking verified purchase I use these they broke two miles down the road..
  14. Jan 19, 2024 at 7:25 AM
    The link in my bullet point above will answer this question. There's a reason Freedom has a bad reputation around here.
    455h0le_dachshund likes this.
  15. Jan 19, 2024 at 7:43 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I know some people hate on the SPC's but I love em.
  16. Jan 19, 2024 at 7:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    They're easy enough to configure yourself once you understand them.
    https://youtu.be/v1RXnk7b2Bs?si=zhnYpQLKpp_xRMNj
  17. Jan 19, 2024 at 7:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No personal experience with either. Anecdotal at best. However JBA is a well known, respected brand. I do own their long tube headers on both my trucks and have no complaints though. Freedumb on the other hand were literally eBay uppers, likely made in China. They have a website now. But they started on eBay. And I bet they're a cheap knock off of someone else's hard work. Like the Alibaba TRD pro knock off grills and the Allpro knock off bumpers sold on eBay.
    VR6T[QUOTED] likes this.
  18. Jan 19, 2024 at 8:53 AM
    VR6T
    I DMd you
  19. Jan 19, 2024 at 11:07 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Sorry if I missed it, but are you lifted? If not and the UCA bushings are good, just replace the ball joint. Aftermarket UBJ is fine, but the cost difference wasn't much so I went with OEM.
    LBJ isn't quality issue with aftermarket, it's a design issue. The cup around the ball isn't as big so the ball pulls through eventually. They aren't designed to be pulled like Toyota has them (bad design on 1st gen tundra/sequoia and 3rd gen 4runner)
    oscardog86 and VR6T[QUOTED] like this.
  20. Jan 19, 2024 at 11:26 AM
    VR6T
    I am on the 2 inch leveling "lift kit".
  21. Jan 19, 2024 at 11:36 AM
    rock climber
    Should be fine on stock UCA, rule of thumb is 2.5 or higher needs aftermarket UCA. Are the alignment specs good?
  22. Jan 19, 2024 at 11:52 AM
    VR6T
    When theure done theyre fine. But the truck always throws a negitive camber over time. I replace the camber adjustment bolts with new factory ones in 2020. Still keeps doing it, and i have to make the periodic adjustment. The alignment shop sid the leveling kit was most likely the cause with factory co from arms. But in tbe 3 years I've had the truck its never had a ball joint issue like I posted a few pages back.
  23. Jan 19, 2024 at 12:00 PM
    rock climber
    That's weird. The arms shouldn't cause it to lose alignment. Are you sure the adjustment bolts are torqued? if you do get adjustable UCA's and it keeps happening, i'd look into these
    https://333fabrications.com/products/cam-eliminator-kit?variant=40920756486320
  24. Jan 19, 2024 at 12:52 PM
    When you say "levelling kit", do you mean strut spacers?
  25. Jan 19, 2024 at 2:39 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Awesome. Thanks guys!
  26. Jan 19, 2024 at 3:19 PM
    inv3ctiv3
    inv3ctiv3 New Member
    Jim Bob
    bmf4069, oscardog86, JasonC. and 6 others like this.
  27. Jan 19, 2024 at 3:29 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    inv3ctiv3[QUOTED] likes this.
  28. Jan 19, 2024 at 3:54 PM
    Pawpa cap problems! image.jpgtomorrow is gear day, where I’m dropping off this unit at
    bmf4069, oscardog86, Voss and 5 others like this.
  29. Jan 19, 2024 at 4:00 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
  30. Jan 19, 2024 at 4:45 PM
    Azblue
    The Dirty T ( ^_^)_且
    Shit ain't going anywhere. That fake grass on the tailgate will hold it like velcro.
