  1. Jan 18, 2024 at 1:34 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @shifty`
    did you cycle your suspension loose? Clamp the LCA bushings at full droop or rideheight? I wanna take some measurements at full stuff, and beau's lca stayed tight, and we didnt take the time to fiddlefuck around. Pretty sure we did the tape measure alignment afterwards.
    my cv's and strut tool are supposed to be here tomorrow.
  2. Jan 18, 2024 at 2:18 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    These are the times where I feel like I've done all my research and made sound decisions with my truck, but then I read something like this... and my entire existence is brought into question.
    But honestly @Mr.bee I don't know if just using jacks & jack stands without tires will get the full range of motion. Seems like most of what I've read online is all done with the wheels on.
    Alright, edit is needed... Apparently I need to relearn how to search the internet. Found some good videos, for the back of a vehicle, not as much for the front.
    oscardog86 likes this.
  3. Jan 18, 2024 at 2:34 PM
    Drove to the car wash, saw a line 5 cars deep, turned around and went home.
    I’ll try again tomorrow.
    dirtnsmores likes this.
  4. Jan 18, 2024 at 2:35 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    How do you open the valve with the skid plate on? That's been the reason I haven't bought one
  5. Jan 18, 2024 at 3:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    life is a string of questions. Gonna loosen everything to play with travel. Probably try to set the bushings at ride height.
    metalpete[QUOTED] likes this.
  6. Jan 18, 2024 at 3:24 PM
    I didn't. @alb1k had inspired me to eventually do that, but I haven't gotten there.
  7. Jan 18, 2024 at 3:37 PM
    metalpete
    ID
    Deep thoughts, right there. Mr. Jack Handy is more like it..
    Definitely something I need to do. Front and rear stops. Those extra washers on the front aren't going to cut it, when I start doing some off-road business.
  8. Jan 18, 2024 at 3:39 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Runnin the baja1000? Slow is fast, freedom is control.
  9. Jan 18, 2024 at 4:38 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Gave my Ferd a break so I used my DC to swing by the post office to pick up a package they supposedly tried to deliver but couldn't. Lyin' bastids. My security cameras show no attempt whatsoever was made. It was the swing out toolbox I grabbed from scAmazon for my Ferd. Not heavy just a large bulky box. Will throw it on this weekend in between OT shifts at work.
    oscardog86 and VR6T like this.
  10. Jan 18, 2024 at 4:38 PM
    metalpete
    ID
    With the way some of the roads are to/around the reservoir, I might not be able to resist.
    Trails riding? Slow is how you go.
  11. Jan 18, 2024 at 4:40 PM
    artsr2002
    'Yonder
    Dayum.
  12. Jan 18, 2024 at 4:45 PM
  13. Jan 18, 2024 at 4:46 PM
    Why’s it coming out of his stomach?
  14. Jan 18, 2024 at 4:47 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Can anyone post a picture of their upper ball joints, 2wd preferably, parked on a level surface. I just replaced mine not 3000 miles ago, Moog HD upper and lower, and well the pass side is blown out and the druver sides about to. I have a 2 inch leveling kit, and its the OEM upper control arms in both sides.
  15. Jan 18, 2024 at 4:48 PM
    Super boner can’t be contained to just a pelvis
  16. Jan 18, 2024 at 5:04 PM
    Ooof you lucky dog. Everyone knows never to use Moog lowers. Or Napa. Or anything other than OEM.
    Hold up and I'll get you a pic of 4WD at least, on level surface.
    oscardog86 and VR6T[QUOTED] like this.
  17. Jan 18, 2024 at 5:09 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Not even Sankei 555? Asking for a friend :anonymous:
    Sorry OP, I can’t help as I have upper unis
  18. Jan 18, 2024 at 5:09 PM
    Ok, aftermarket here but I love how it looks. And the above is all I had from pre-upgrade days.
  19. Jan 18, 2024 at 5:10 PM
    Sankie triple 5s are supposed to be on par with OEM. I'm not sure I'd be sweating those if I were you.
  20. Jan 18, 2024 at 5:10 PM
    VR6T
    Thanks. Also ive used Moog my whole life, never had an issue, well aside from their water pumps.
  21. Jan 18, 2024 at 5:11 PM
    Man, someone needs to tell the guy his camber is way neg up front. :rolleyes:
  22. Jan 18, 2024 at 5:12 PM
    The Black Mamba
    DFW
    Imma keep it stock
  23. Jan 18, 2024 at 5:13 PM
    We’ve seen a few people on here with failed Moog lower ball joints.
    The Black Mamba and VR6T[QUOTED] like this.
  24. Jan 18, 2024 at 5:14 PM
    I was a Moog lifer also, but ever since they had that huge fucking recall on LBJs for our trucks in 2020/2021 that resulted in lots of dead Tundras, I started looking into it, and Moog isn't the company it was 10,15, 20 years ago. They don't make their own parts anymore. They outsource a fair amount from mainland China and the quality has basically gone to shit. I won't buy their products anymore, and many of my hardcore die-hard GM family won't purchase them either, after half a century of swearing by their product.
    Companies change. They get bought up, merge, sell, start catering to shareholders more than consumers, it happens. Moog jumped the shark.
    If you want a link to the NHTSA recall doc for Moog's LBJ, I can find it for you. It was ugly. It hit NAPA brand and one other major store brand too. All sourcing parts from the same mainland China warehouse that starts with a "T", IIRC.
  25. Jan 18, 2024 at 5:15 PM
    VR6T
    Marked and noted. Im gonna see if rock auto will warentee these, this is unacceptable in my opinion. Theres like 23xx miles on them all on good to decent pavement.
  26. Jan 18, 2024 at 5:17 PM
    VR6T
    Any brand I should go with or just OEM it?
    metalpete likes this.
  27. Jan 18, 2024 at 5:17 PM
  28. Jan 18, 2024 at 5:17 PM
    OEM, and for the reasons in that video ^^^
    And get new bolts while at it. At least threadlock blue, if not red, when installing the bolts. I go blue.
    oscardog86 and metalpete like this.
  29. Jan 18, 2024 at 5:21 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Speaking of…
    oscardog86, metalpete and VR6T like this.
  30. Jan 18, 2024 at 5:28 PM
    metalpete
    ID
    Okay that last picture kinda freaked me out. I thought it was my truck for a second.
