  1. Jan 14, 2024 at 12:19 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    If one of my wife's lipsticks comes up missing, I'm blaming you. :rofl:
    How does that work... asking for a friend :anonymous:
    shifty` and FrenchToasty like this.
  2. Jan 14, 2024 at 12:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yep, I had that issue on my 03 Taco too. You just need a swivel and an extension or two IIRC
  3. Jan 14, 2024 at 2:36 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    You were able to get under the intake and injector runner to the inner side valve cover bolts? Couldn't figure it out on an 04.
  4. Jan 14, 2024 at 3:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    maybe not. It's been like 10 years since then. I just remember tightening em. Might've skipped the ones I couldn't reach
  5. Jan 17, 2024 at 4:52 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I wish Falken made a 285/80/17 tire. That would be my ideal set up. Currently have Falken Wid Peaks 275/70/17. Great tire so far.
  6. Jan 17, 2024 at 6:33 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Agreed, that would be a great tire size.
    I'd run 285/75r17 if I had bought 17's instead of 16's in the first place. But now when i finally do buy 17's, I'm going for the Kenda Klever MT in 35x10.5r17
  7. Jan 17, 2024 at 10:30 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    I'm with you @455h0le_dachshund on the Kenda 35x10.5. That's probably my next tire. With the proper alignment, I think these trucks can clear that size without too much hammering and cutting :sawzall:
  8. Jan 17, 2024 at 10:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  9. Jan 17, 2024 at 1:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :redxfall:
  10. Jan 17, 2024 at 2:30 PM
    Drove my truck through Saltapalooza today. Now it’s saltier than the rim of a Margarita glass. Time for a wash tomorrow and then again when the roads are clear.
    oscardog86 likes this.
  11. Jan 17, 2024 at 2:32 PM
    Mine is the same. Pretty sure I drove through the evil liquid brine. It's going to be a while before I can wash it off too.
  12. Jan 17, 2024 at 7:59 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    My @shifty` approved clamps arrived today too! It took some restraint to not over-tighten them they work so well. The OEM clamps were loose enough so the dust boot was slipping around quite a bit. Hopefully this does the trick.
  13. Jan 17, 2024 at 9:56 PM
    ToyotaDude
    ToyotaDude Member
    Nice. How many miles you got on those OE inner boots with the lift and how high is it? I just replaced mine because they split. Yours aren't rubbing at the innermost bellow and causing a groove? Did you get the smaller 25-40 mm clamps too maybe to swap for that off centered outer one?
  14. Jan 17, 2024 at 10:37 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I havent done it yet but i got my brackets cut, lights came in, and i just need to weld the brakets on to my hitch frame. Some new 18,000 lumen under body back up lights. Apparently I'm blind at night in reverse, or it was sub optimal window design..... Either I'll be able to see now when reversing in tight spots. Going to inline fuse them and piggy back into either my hitch conection or reverse light directly.
    NiLight is the brand for those wondering, like 36 bucks, USD, on Amazon
    oscardog86 and The Black Mamba like this.
  15. Jan 17, 2024 at 11:05 PM
    albru2
    probably only about 150 miles on about a 2 in lift. It does look like it's rubbing so I'll just have to keep an eye on it. I figured this was worth a try. I didn't even notice that smaller clamp looking kind of askew until I posted the pic. will have a look at that tomorrow.
  16. Jan 18, 2024 at 7:14 AM
    shifty` Goons of Hazzard
    Note your smaller inner clamp of that boot is sitting up on the shoulder at the shaft side. I can probably get you a NORMA clamp# for that one if you intend to replace it too. I just need to dig up my post with the calipers to see what the clamp measure needs to be.
  17. Jan 18, 2024 at 9:43 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Realized now why I wasn’t getting any hvac fan on the first two settings. Cheap and easy 5 minute fix luckily. Those don’t seem to come around very often. Was even able to use the heated work bays at work while on shift so since I was getting paid to while doing this it basically makes me a professional mechanic yes? :rofl:
    bmf4069, NUDRAT, artsr2002 and 9 others like this.
  18. Jan 18, 2024 at 9:53 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Good repair. I know that shifty would suggest to clean out the evaporator while you are in there. He actually has a write up with pics somewhere on here, but I can't locate it. Anyway, good work.
    EDIT: Found it. Posting for future. https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1571#post-3126837
    BroHon, shifty` and CodyP[QUOTED] like this.
  19. Jan 18, 2024 at 9:54 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Took a photo of my 2006 double cab next to a 07 double cab today. I could have bought either, but chose the 1st gen for a larger back seat and almost the same size bed. Plus, it looks better IMHO
    Also the new Bedrug from an access cab is working out good for my double cab. still looking for a true double cab bedrug. If you have a lead, let me know :)
  20. Jan 18, 2024 at 9:55 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    did you find a home for you rubber mat?
  21. Jan 18, 2024 at 9:56 AM
    dirtnsmores
    Southern CA
    yessir! @HBTundra grabbed it yesterday
  22. Jan 18, 2024 at 9:58 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Fantastic!
  23. Jan 18, 2024 at 10:05 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It’s on my list but not when the weather is this cold.
  24. Jan 18, 2024 at 10:15 AM
    Dakillacore
    Georgia
    I think the first gen is the best looking IMO, and I like how spacious the interior is VS the cockpit feel in a lot of the newer models.
  25. Jan 18, 2024 at 10:46 AM
    dirtnsmores
    Southern CA
    that Fumoto... is it in danger of being broken off when offroading or is it pretty well protected? I read on another forum offroaders shouldn't install them for that reason. but not specific to any truck
  26. Jan 18, 2024 at 10:52 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If you have a skid plate should be no issue. They've also got short valves that aren't much bigger than a standard plug.
  27. Jan 18, 2024 at 10:53 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had to do this on my 03 about 2 years ago. Love those easy cheap fixes.
    CodyP[QUOTED] likes this.
  28. Jan 18, 2024 at 12:07 PM
    Jasons2006Tundra
    Jasons2006Tundra New Member
    2006 Tundra DC SR5 4wd 4.7 TRD
    The Fumoto drain valve is great, I put them on both my FGT and Taco and wife's Subarooooo. No issues with them sticking out to far to risk breaking off.
  29. Jan 18, 2024 at 12:14 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Ive had a Fumoto valve for a couple years now. Its pretty well protected under my SkidRow skidplate and havent had a single issue with it. Makes oil changes so much easier as i bought the version that accepts PVC tubing so i can drain the oil without spilling on my skid plate.
  30. Jan 18, 2024 at 1:24 PM
    I've got a Fumoto via secret santa. My lazy ass still hasn't installed it yet. One year and counting ....
    I need to do an OC soon, actually.
    455h0le_dachshund likes this.
