Springs for Bilstein 5100
Discussion in '1st Gen Tundras (2000-2006)' started by Jeff53, Jan 12, 2024.
  1. Jan 12, 2024 at 6:59 AM
    Jeff53
    Jeff53 [OP] New Member
    Jeff
    Winchester, VA
    2005 SR5 AC Salsa Red Pearl
    I purchased new Bilstein 5100s for my 2005 Tundra AC, TRD Off-Road. I'm probably going to wait until spring to put them on at this point. I have new OEM top hats for them, also. I was planning on running the 5100s on 2nd or 3rd setting. My question concerns the springs. My current springs seem to be fine with about 177,000 miles on them. What are the opinions on continuing to use them or, since they need to be disassembled anyway, purchasing new springs? If I did go new, I'l probably just stick with the stock spring rate rather than going for lifting springs, as I just want to level, vice lift. Thanks.
  2. Jan 12, 2024 at 7:11 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    My stance on the subject is that coil springs last a LONG time in most cases. That said, they do tend to show age by way of lower ride height or consistently bouncing off of the bump stops.
    Do I think you're probably fine to reuse? Yes. Do I think it would be worth the ~$100 to replace them with new since you're using new everything else? Also yes.
  3. Jan 12, 2024 at 7:14 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I would agree. If you're already in there, go ahead and spend the little extra for new springs. You'll be glad you did.
    memario1214 likes this.
  4. Jan 12, 2024 at 7:18 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    What is a good, OEM equivalent aftermarket coil?
  5. Jan 12, 2024 at 7:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    As far as height or quality?
  6. Jan 12, 2024 at 7:25 AM
    I had the same question as @The Black Mamba on this, but I also had another question for OP @Jeff53:
    Are you 2WD or 4WD (that's kinda important), and what is your end goal here? If you're 2WD and you get 5100s and run that circlip up to the 3rd ring from bottom, your ass-end is gonna be squatting. 2nd circlip would probably get you just about level, maybe a hair of forward rake. You may even be squatting at 3rd circlip in a 4WD.
  7. Jan 12, 2024 at 7:26 AM
    memario1214
    Colton
    Missoula, MT
    I've personally never gone sourcing for 1st Gen Tundy coils, but I would look for like maybe Moog or Mevotech if sourcing a direct OEM replacement. If someone had the OEM spring number some Google-fu should be able to cross reference pretty quickly.
  8. Jan 12, 2024 at 7:28 AM
    A lot of people will pair OME springs up with 5100s on our 1st gens. The OME 2883 will perk up the front end with a little smidge of lift over a true OEM replacement on most trucks (excluding DC 4WD, which would probably end up like OEM).
    2884 will level most 2WD trucks.
    2885 will level DC 4WD trucks and leave AC 4WD with a little squat.
    (Going from memory here, but that should be accurate)
  9. Jan 12, 2024 at 7:40 AM
    87warrior
    Kansas
    2004 DC 2uz 4x4
    Both height and quality.
    My new truck has one original shock and coil and one aftermarket. I have no idea why the PO did not replace both, but I want to fix that without getting much lift out of new coils. Finding information about stock height coils has been a challenge.
  10. Jan 12, 2024 at 8:33 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    a1 auto, Rock auto and parts geek don't seem to offer a spring separate from the shock. I would just buy the quick struts and call it a day. 2004 TOYOTA TUNDRA 4.7L V8 Shock / Strut & Coil Spring Assembly | RockAuto
  11. Jan 12, 2024 at 8:44 AM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    This summer I threw on some 5100’s #3 setting and reused the oem spring. It sits pretty leveled to me. upload_2024-1-12_9-43-21.jpg
    BroHon and The Black Mamba like this.
  12. Jan 12, 2024 at 8:44 AM
    Usually "it cost more" is the answer to that more than anything when you see that. One blew out, and they opted to replace.
    How much height are you looking to achieve? I'm lifted 2" and it's pretty substantial (link to pics in my signature). I feel like it looks really substantial, visually. And frankly, I feel like it's too much lift. I'd have been just as happy with 1". The kids have a harder time getting in the truck now, and fell out of the truck several times after lifting and adding 1.6" of tire.
    Krewcial likes this.
  13. Jan 12, 2024 at 8:47 AM
    memario1214
    Colton
    Missoula, MT
    I try and impress that a lot when people are looking at lifts. Jumping up in tire sizes is a lot more impactful than people tend to think.
    shifty`[QUOTED] likes this.
  14. Jan 12, 2024 at 8:50 AM
    To your point, I need to go into the megathread and probably bold/underline/highlight that point in the suspension/wheel/tire section. After 1.6" tire and 2" lift, my truck feels 4-5" higher off the ground, honestly. I rarely used the OEM nerf steps prior to lifting. Now I have no choice. :rofl:
  15. Jan 12, 2024 at 9:24 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I have been going back and forth with this for weeks now. I have a 2006 DC 2wd that needs new shocks. I went up from the stock 245’s to 265/70r16’s and I don’t want to lift it but am also concerned the stock springs are sagging a bit. Honestly all I wanted was the bilstein 4600’s and then call it good but it seems all the “mild” leveling kits give way more lift than desired.
    FishNinja likes this.
  16. Jan 12, 2024 at 9:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Enter adjustable coil springs
    KTM_AJ421[QUOTED] likes this.
  17. Jan 12, 2024 at 9:43 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I’m not big on wanting to put preload on a 5100 I want the best ride possible. I’ve been working in St Louis for the last few weeks and the roads here are unbelievably bad. Worst pot holes and road conditions I’ve ever seen.
  18. Jan 12, 2024 at 10:04 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    How about just getting the 6112? I know they are more expensive, but problem solved.
    KNABORES likes this.
  19. Jan 12, 2024 at 12:28 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Suspension lifts has the 4600’s w/ stock springs for $700 or it’s $140 more for the 5100’s and OME springs. I personally would like the slightly beefier shock and springs since for my personal uses of the truck as I do haul pallets of batteries here and there for work.
    If you don’t do serious hauling/towing I think the 4600’s is a perfectly good choice and saves some good $$$
  20. Jan 12, 2024 at 12:39 PM
    Jeff53
    Jeff
    Winchester, VA
    Mine is 4WD. According to a chart I've seen, the lift on a 1st gen 4x4 AC is only 1.1 inches on the 3rd position. The same chart stated "Do Not Use" for positions 4 and 5.
  21. Jan 12, 2024 at 12:58 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    yea I asked them if they were OEM springs and they replied OEM equivalent made by a third party. I’ll most likely go 5100 and OME 2883
    shifty` likes this.
  22. Jan 12, 2024 at 1:03 PM
    I swore someone on here recently said the springs in that 4600 kit were Moog, Mevotech, or similar brand, but maybe I'm wrong. Not that I think it matters. But "OEM-like" is maybe the better term to use. EDIT: Nevermind, there you go, from KJM above me.
    Stock DC and AC numbers should be ballpark 20" front, 21" rear. 1.1" in the front with stock-type springs would put you higher in front. Taking that from another member's stock '04 DC measurements, but also my measurements, which were
    Before --
    Front D: 20.5"
    Front P: 20.75"
    Rear D: 21.75"
    Rear P: 21.5"
    After -- (my front/rear lift info is in my signature on this post, mobile users may need to rotate your phone to landscape mode to see it)
    Front D: 23"
    Front P: 22.75"
    Rear D: 24.25"
    Rear P: 24"
    Given AC and DC appear to have roughly 1" rake front to back, adding 1.1" lift up front may have your front sitting high. And even if it doesn't actually sit higher, the way the fenders are cut, it may appear as though the ass is dragging.
    This sticky thread has some measures from others if you want to compare or search around: https://www.tundras.com/threads/how-big-is-yours-measure-up.46186/
    All I'm saying is, and this is coming from a guy who didn't really dig in hard enough, and thought "Meh, 2 inches isn't much at all!", I'm prepared to get in and crank down my Toytec coilovers a quarter turn or so to bring my front back down a bit.
    I really think the ideal lift for appearance and function on these trucks is more like 1" - 1.25" in front, with .75" - 1" in rear, running a 31.6" tire (265/70r17, or whatever 16" equiv is). And really 1" front lift, .75" in rear is probably the better option for hybrid or mostly on-road use. It's less brutal on suspension, doesn't require adding extra equipment like new control arms (although I'd still install extended sway bar links), and should function like sport-OEM-plus. The added suspension lift and tire lift you'll get should look pretty f'n awesome. But that's purely my opinion, which probably stinks to a lot of ppl.
    Krewcial and 87warrior like this.
  23. Jan 12, 2024 at 4:06 PM
    Krewcial
    Don
    I like the level look. Just need to decide if I want to put the RAS springs on the leaf or airbags with Daystar cradles. Leaning towards RAS on my weekend DIYer first gen though.
  24. Jan 12, 2024 at 9:05 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    885’s broes.
  25. Jan 15, 2024 at 8:45 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I did the exact same thing. Leveled, good ride quality, far better handling than stock struts. 49D7940D-0890-44B5-8E2B-2B3FF167D88D.jpg
    Krewcial[QUOTED] likes this.
  26. Jan 15, 2024 at 6:04 PM
    I’m running 5100s at number 4 setting on my 2000 4wd TRD AC, gasp, I know. Sat perfect and rode firm, but not harsh. Been running them (on my second set) for over 100k miles. No complaints or issues. Stock TRD springs with 270k miles on them. Got some rake now as my rear leafs have some sag in them and I added a topper.
  27. Jan 16, 2024 at 5:52 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I tried the 5100s with stock Trd coils on the third setting and then went to the 5th setting looking for more lift.
    I think they say “do not use” on the top two setting if you have stock uca.
    I have since moved to one 885 springs with the 5100 shocks. The ride is much better. I have the passenger side in setting 1 and the drivers side on setting two.
    I get about the same lift as having the stock coil on setting five.
    KNABORES and Krewcial like this.
  28. Jan 16, 2024 at 10:00 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Regarding OE springs, ran them on 5100s. Billy told me higher clip settings were not supported regardless of UCAs. So on next set swapped to Eibach's at the top setting. The Eibach's are apparently designed to not top out at highest setting with OE springs, so support the taller clip settings). Appear to have gained full advertised lift and equal heights on both sides. I expected this wouldn't happen due to age of the OE springs. But they still seemed to have the juice after almost 247,000 miles. (The rear left is sagging from the gas tank assumably). Am considering dropping the fronts a notch to 2.25" when feel like wrestling springs again, or swapping in lift springs and dropping them all the way down if I'm in there ... or leaving the fronts alone and lifting the rear/sag.
  29. Feb 2, 2024 at 7:15 AM
    Jeff53
    Jeff
    Winchester, VA
    Thanks. This really helps as that is what I'm looking at doing.
  30. Feb 2, 2024 at 7:17 AM
    Jeff53
    Jeff
    Winchester, VA
    Thanks. This helps a lot since I was thinking of using the OEM TRD coils on my and I "only" have 174,000 on them.
