First Oil Change - Oil Report
Discussion in '3rd Gen Tundras (2022+)' started by radar x50, Jan 15, 2024.
  1. Jan 15, 2024 at 3:29 PM
    radar x50
    radar x50 [OP] New Member
    2023 Tundra Platinum
    When I did the first oil change at 5k miles on my 23 Tundra in December, I sent an oil sample to Blackstone for an oil analysis. I just received the oil report back (4 1/2 weeks later) and Blackstone states the excess metal is typical during the break-in period and will probably wash out with time. I'm going to religiously track these oil analyses as more 3rd gen Tundra owners are reporting V35A engine failures. I opted not to do the TBN/TAN properties testing as I intent to do the oil changes at 5k mile intervals. Sorry for all the redactions.
  2. Jan 15, 2024 at 5:14 PM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    Thanks for that, I wish I had sent my first two changes out. Here’s my 3rd oil change at 15k miles for reference. It should level out for you soon
    Mattedfred and radar x50[OP] like this.
  3. Jan 16, 2024 at 8:50 AM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Did you by chance notice any "glitter" in your oil pan after the first couple of changes?
  4. Jan 16, 2024 at 10:06 AM
    radar x50
    I did not. Did you take a picture?
  5. Jan 16, 2024 at 11:29 AM
    OLV1071571
  6. Jan 16, 2024 at 11:29 AM
    OLV1071571
    I will do another oil change in a total of 3k miles and see what it looks like.
    Mattedfred likes this.
  7. Jan 16, 2024 at 2:21 PM
    radar x50
    Have subsequent oil changes still had this “glitter”?
  8. Jan 16, 2024 at 3:00 PM
    OLV1071571
    The dealer did the first one so I couldn't validate that. I did the second one and saw glitter. After the second one I did drain about a cup out of the pan just to see and there was also some glitter but its a small sample and the bottom of the pan. I am keen to know what the 3rd change will look like. I am only at 3300 miles and will wait another 1-2k to change.
  9. Feb 19, 2024 at 2:56 PM
    OLV1071571
    Update: Just did another oil change at 4,150 miles. The oil had about 1,900 miles on it and honestly looked much darker than I would have thought. I did tow 2 times with about (5k lbs and 8k lbs) about 50 miles total each time.
    Used Pennzoil Platinum 0w-20 with OEM Filter.
    I still had "glitter" but I believe it was less than before. How much less? I don't know. I was just observing what I could at the bottom of the pan. It did seem gritty and I am quite disappointed the OEM filter did not catch all this.
    I cut the filter open and didn't notice any larger specs like I did on the 2nd oil change. The dealer did the first one so who knows what came out.
    So all in all I think the glitter is slowly going away and I am happy about that. Seems like after 4k miles the engine is still being broken in. Moving forward I will switch to either Purolator Boss or WixXP.
  10. Feb 20, 2024 at 6:49 AM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Did my first oil Analysis, did a oil change at 1000, 3,000, and this one at 5713 miles (going on trip so changed it before 3K miles), using Pennzoil Ultra Platinum Full Syn.
    OLV1071571 likes this.
  11. Feb 20, 2024 at 7:32 AM
    OLV1071571
    Would love to see someone's report over the course of 15-20k and see the subsequent changes and drops in metals. Just for comparison. I know others have posted 1 or 2 reports which seems fine. But its good to see validation from other samples taken over time.
  12. Feb 20, 2024 at 7:39 AM
    When you drain an oil pan through the drain bolt, some oil remains along the bottom of the pan. The “glitter” will also stick to the bottom of the pan and not be cleared by merely draining.
    raylo likes this.
  13. Feb 20, 2024 at 8:48 AM
    OLV1071571
    Forgive me but can you point us to that report again?
  14. Feb 20, 2024 at 9:00 AM
    OLV1071571
    Mattedfred[QUOTED] likes this.
  15. Feb 20, 2024 at 11:31 AM
    SDHNTR
    SDHNTR New Member
    Thanks OP! Seems to me like this is further evidence supporting a break in oil change at 2-3K?
  16. Mar 1, 2024 at 6:12 AM
    dJunior
    dJunior New Member
    CT
    All great info and like the commentary Blackstone gives - especially since we have to watch for those potential points of failure. I might make up a google sheet and start a longer-term trend thing as I do my results. (First oil change in a few weeks- 2,000 mi).
  17. Apr 3, 2024 at 3:59 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Got my report back today from 1k mile oil change. Not sure why they made the comment about 3.4 engine. Maybe I wrote the incorrect size on the form…
    Jettster likes this.
  18. Apr 3, 2024 at 6:06 PM
    machd08
    machd08 New Member
    CLARENCE
    Because it is a 3.4 L
  19. Jun 18, 2024 at 8:49 AM
    radar x50
    At least Toyota has submitted a voluntary recall.
  20. Aug 5, 2024 at 6:41 PM
    radar x50
    The 2nd oil change is looking promising as no signs of debris in my oil. Hopefully, I 'm out of the woods. Nevertheless, I had to cancel a road trip to Yellowstone this year because of this recall.
    Kap1 likes this.
  21. Aug 7, 2024 at 4:16 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    First oil report on Celeste:
  22. Aug 7, 2024 at 6:19 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    As much as I'm a huge fan of oil analysis and I've had it save me major repairs, I think these tests are turning out to be pretty dull other than silver which is inconclusive. In my experience, when you have a wear problem you see if far in advance with the analysis a big way. I wonder if the bearing fails somewhat without warning or a lot of wear metals being disbursed? Or, this is a relatively low sample count which is against a fairly low % of units failing? Still, it's odd that we haven't had one test I've seen that lit up the dials.
    Breathing Borla likes this.
  23. Aug 7, 2024 at 6:42 AM
    VCheng
    VCheng New Member
    Upstate NY
    I have driven umpteen vehicles hundreds of thousands of miles and never worried about oil analyses TBH. Regular oil and filter changes with good quality oils is all that I have ever done, but I did this just for my academic interest only. I am going to do a few more just for the heck of it. If my factory installed self-destruct device detonates, I will worry about it if and when it does.
  24. Aug 7, 2024 at 6:51 AM
    BoulderGT3
    Glen
    I agree. I've never used it much for cars. Always and often for boats and generators.
    Also agree on worrying about the engine if and when it does.
    VCheng[QUOTED] likes this.
