General Supercharger Thread
  1. Jan 13, 2024 at 8:40 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Is that what it reads even after the truck has been running a while? it will read lean right after startup cause of the air injection.
    Wynnded and snivilous[OP] like this.
  2. Jan 13, 2024 at 8:48 PM
    blenton
    blenton New Member
    No, that’s just startup on a cold motor. I didn’t think about the air injection.
    helidave[QUOTED] likes this.
  3. Jan 13, 2024 at 9:30 PM
    blenton
    blenton New Member
    Looks like the FPR is fixed. Unless what I’m looking at isn’t the FPR… Ignore the dirty valve covers…
  4. Jan 13, 2024 at 9:34 PM
    helidave
    flagstaff
    2015 DC 4x4
    regulator is on the passenger side with a vacuum line from the intake tube
  5. Jan 13, 2024 at 9:42 PM
    blenton
    blenton New Member
    THERE it is! It was hiding… So, that runs right in to the intake, which I’m assuming is only going to show vacuum and not boost since the boost is below the rotors and not in the intake. I ran it to this port pictured, which was originally capped but Whipple supplied a nipple.
    In other good news, I have the O2 sensor a couple of cycles and it’s dropped down in to the 14’s -woohoo! Sorry for all the dramas. You guys are a wealth of info. Now it’s time to button it all back up and drive slow through the blizzard.
  6. Jan 14, 2024 at 3:33 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I have the caltracs. They work
    but… all traction bars work.
    get what looks best!
  7. Jan 14, 2024 at 8:32 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    To boost reference the FPR, the vacuum line needs to connect to a port that sees vacuum/boost. Same port or similar location to your boost gauge sensor. Sorry if that's what you did, wasn't clear to me.
    PolishedTRD, Mdl, HulkSmurf14 and 3 others like this.
  8. Jan 14, 2024 at 9:01 AM
    ARES35
    ARES35 New member for life
    Mile high
    I was gonna say that there is your pulse damper, fuel reg is on pass side with vac line attached at intake.
    blenton[QUOTED] likes this.
  9. Jan 14, 2024 at 10:10 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    nags, PolishedTRD, Mdl and 1 other person like this.
  10. Jan 14, 2024 at 10:11 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Take the end of hose A from the intake tube and T it into hose B. Then you're boost referenced. Don't forget to cap off the nipple at the intake where you've removed hose A. That fubar is reserved for the likes of me. o_O
    PolishedTRD, ARES35, Mdl and 4 others like this.
  11. Jan 14, 2024 at 11:02 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  12. Jan 14, 2024 at 11:07 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    thx Rey
    I talk a big game.
    There is no way in hell I'm taking those leaf springs off again!!!
  13. Jan 15, 2024 at 6:28 AM
    ssmokedz
    Shelton CT
    Me!!!
    Mdl, reywcms and pvn.beluga[QUOTED] like this.
  14. Jan 15, 2024 at 7:53 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    HAHAH I was telling the wife that your Tundra has a supercharger and she gave me a blank stare :( Gotta get her in on one!
    Tripleconpanna and reywcms like this.
  15. Jan 15, 2024 at 8:18 AM
    ssmokedz
    Shelton CT
    I floored it for her when i first got it and all she said was "all that money and that's it?" My heart was broken LOL! In fairness to her she is used to my Camaro and she always gets mad when i open that car up. She says she hates the way it makes her stomach feel. I think more or less it's the banging gears with the 6 speed that gets her. :burnrubber:
  16. Jan 15, 2024 at 8:20 AM
    VWTim
    Corvallis, OR
    FWIW, my Tundra has been parked for 6 days (wife and I both sick with Covid) Decided to see how she likes a 18 deg F cold start. Hit the remote starter, ever-so-slightly slower crank, but fired right up, ran thru startup RPM's, and settled down just like normal.
  17. Jan 15, 2024 at 8:27 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My PSB-1 O2 stopped working (gave an error), the solution was ordering a new one. Not sure what really resolved it but seriously the next start up months ago it started working again.
    Wynnded, Mdl and snivilous[OP] like this.
  18. Jan 15, 2024 at 8:33 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Lucky! Remote started my pig at -11º, went out to find a Christmas tree in my cluster:
    First time I've had codes, aside from O2 sensor problems from my cats being stolen.
  19. Jan 15, 2024 at 8:52 AM
    VWTim
    Corvallis, OR
    That's super frustrating, and REAL cold. Sounds like maybe a connector froze or clockspring doesn't like the cold?
    PolishedTRD[QUOTED] likes this.
  20. Jan 15, 2024 at 9:36 AM
    PolishedTRD
    CO
    I think you’re right with the connectors, as it’s never done this before - albeit I’ve not tried starting it this cold before. I did a zero point calibration just in case.
    The hard start has reappeared and is consistent - it turns over but won’t start until the third attempt. The P0125 & C1201 came back and the idle surges as the engine gets warmer. Driving feels fine - too much snow to give it the beans, but I got up to 4psi and AFRs looked good. Closed loop STFTs and AFRs are great at +/-3% & consistent 14.6, respectively.
    I’m going to mess around with some tables on HPT and see if I can get a handle on it.
    Mdl likes this.
  21. Jan 15, 2024 at 9:57 AM
    helidave
    flagstaff
    2015 DC 4x4
    I had the same P0125 last week when I remote started my truck after a night of single-digit temps. Mine ran fine though and the code hasn't come back since.
    ARES35, PolishedTRD and Mdl like this.
  22. Jan 15, 2024 at 1:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sometimes mine is unresponsive at startup but always eventually comes back to life.
    ARES35 likes this.
  23. Jan 15, 2024 at 1:27 PM
    helidave
    flagstaff
    2015 DC 4x4
    How big of a no-no is it to have the gauge powered on with the engine off? I know it can damage the sensor, but does the damage happen in a minute or an hour? Or is it a crapshoot?
    ARES35 likes this.
  24. Jan 15, 2024 at 1:44 PM
    e30cabrio
    Mine was giving an error the sensor had left the building. I bought one & it self repaired! :p
    ARES35 and Wynnded[QUOTED] like this.
  25. Jan 15, 2024 at 1:44 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I've had mine on for quite awhile without it running, maybe not an hour but probably 15-30 minutes without issue
  26. Jan 15, 2024 at 1:47 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't remember the error that I get, I don't think it's happened recently, or I've just become used to it and haven't been paying attention. @helidave's question does have me wondering if having it on during tune flashes has anything to do with it though.
    helidave likes this.
  27. Jan 15, 2024 at 1:49 PM
    e30cabrio
    Mine comes on with the ignition so it has been on for quite some time. Never paid attention.
    ARES35 and helidave like this.
  28. Jan 15, 2024 at 3:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I wired the accessories coming off the ignition fuse to a switch so I can kill them when tuning or? Also the fuel pump to prevent theft...
    HulkSmurf14, ARES35 and Wynnded like this.
  29. Jan 16, 2024 at 6:00 PM
    ARES35
    Mile high
    Have any of you guys noticed knock when coming out of throttle? Im seeing cells where it'll drop to -4.4 coming out of a WOT run? Also seeing knock on low load situations? Odd thing is my fuel trims are +5/-5.
  30. Jan 16, 2024 at 7:40 PM
    helidave
    flagstaff
    2015 DC 4x4
    yep. I've noticed the same thing.
    ARES35 likes this.
