Suggestions for best wireless charger
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Jan 6, 2022.
  1. Jan 24, 2022 at 7:33 PM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Yeah, I was thinking of trying some of those adhesive bumpers.
    I’ve done a pretty deep dive on this and I think it is mainly due to the iphone 12/13 “camera bump” that ever so slightly lifts the body of the phone away from the coil of the wireless charger. This camera bump also causes issues with magnetic mounts. So not sure if the bumpers/a way to keep the phone from sliding will make a difference.
    Sparks parts lists a disclaimer/warning on the product page but I went ahead and ordered anyways
    This is also not unique to this specific charger. iPhone 12/13 users are having the same issue with the OEM chargers of multiple makes/models, especially the horizontal enclosed tray design.
    I’ve pretty much given up on it, and am hoping the Apple finds a way to make the camera lenses more flush in the next models.
    I’m honestly thinking of going a pseudo-DIY method at this point. Shelled out for the actual Apple MagSafe charger and am planning to mount that in the Vehicle OCD center console tray and feed the cord to the 12v source there. Phone will be inside the center console, but my wireless CarPlay dongle (carlinkit 3.0) has been working pretty well so far.
    The OEM charging pad looks great, definitely annoying to have to turn it off when not in use, but hopeful that it will be useful in the future…
  2. Apr 17, 2022 at 8:57 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Does anyone know if the s21 ultra will charge with this wireless charger?
  3. Oct 14, 2022 at 6:21 AM
    Klempenski
    Klempenski New Member
    Clinton
    2019 Gray Tundra TRD Sport CrewMax 4x4
    Working on it
    Just found this thread after searching for a MagSafe compatible wireless charging tray. I’ve fought with this for a while now. Got the OEM tray charger almost immediately after purchasing in 2019 when I had a non MagSafe iPhone with wireless charging. The tray worked great with or without a case, phone moving around, etc. Then I got a 12 Pro Max and the problems started. I’ve tried everything to get this to work. I’m 100% convinced it’s MagSafe causing the problems. If anyone has a recommendation, please share.
  4. Dec 2, 2022 at 9:11 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  5. Dec 2, 2022 at 1:13 PM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    It’s a love hate relationship, I have the iPhone 14pro max, the cameras are bigger and stick out more so doesn’t have flush contact with the charger. Might be selling mine.
  6. Dec 2, 2022 at 1:38 PM
    M3Tundra-JK
    Scott
    2005 GX470
    That's where I'm leaning against this as well. I WANT IT, don't need it. I also have a Pixel 6 Pro with basically the same camera bulge, plus a wallet phone case. If my phone were any bigger, it wouldn't fit in that space at all
  7. Dec 4, 2022 at 6:36 PM
    LevelUp
    LevelUp New Member
    2016 DCLB SR5 w/ TRD OR in MGM
    OEM LED headlights, interior ambient lighting, running boards, Firestone airbags, misc led swaps, started blacking out phase and chrome delete, Diamondback HD w/ Yakima Overhaul HD (on the way)
  8. Dec 4, 2022 at 7:06 PM
    LevelUp
    LevelUp New Member
    I have a couple questions regarding this wireless charger maybe someone can help. It looks like it comes with a wire and small harness that ties into the rear center console (backseat) 12v cig port wire (pics, not mine).
    Question 1- Consider the style of hook up, Does installing the wireless charger render the rear 12v cig port useless?
    Question 2- If it doesn’t, and the rear cig port still works as normal, can you use the wireless charger and rear 12v cig port simultaneously? Thanks.
  9. Dec 5, 2022 at 1:12 PM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    In an answer to your questions.
    1. No it does not render the 12V port useless.
    2. Yes you can use both at the same time. I have had one phone charging on the wireless charger and two phones plugged into the 12V port with no issues.
    LevelUp[QUOTED] likes this.
  10. Dec 5, 2022 at 1:54 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  11. Dec 5, 2022 at 9:53 PM
    LevelUp
    LevelUp New Member
    Thank you kindly
  12. Dec 10, 2022 at 3:37 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Me too. But you should know in the dark it is rather bright.
    M3Tundra-JK and LevelUp[QUOTED] like this.
  13. Dec 13, 2022 at 10:11 AM
    Gmt22
    Gmt22 New Member
    2021 x series tundra
    The issue is with the phone itself not working with certain chargers. This is the same as when an iPhone won't charge with a non Toyota cable. The cable is still good, but the phone is not allowing it. That is the same issue here. The technology in the phone doesn't want to allow it to charge.this is what sparks parts just told me.
  14. Jan 12, 2024 at 8:33 PM
    bchaase
    bchaase New Member
    Daphne,Alabama
    2015 WHITE TUNDRA TRD PRO
    LOOKING FOR IDEAS
    Anyone know where the fuse is for the back of the center console's socket/12v cig port ??
  15. Jan 12, 2024 at 8:42 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    There should be a power outlet fuse in the under-dash fuse box..
  16. Jan 12, 2024 at 8:51 PM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    I added the wireless charger to the top of my center console and piggybacked it off the 12v socket.
    The pigtail has a fuse but it isn't shorted
    I've checked every fuse under the dash drivers side
    Neither the charger nor the socket are getting powa
    And both were working for months
  17. Jan 13, 2024 at 3:51 AM
    ChrisLopez
    Christian
    Chicago,Illinois
  18. Jan 13, 2024 at 3:53 AM
    ChrisLopez
    Christian
    Chicago,Illinois
    sounds like it has to be a fuse. Did you try replacing the fuse for the outlets even though it doesn’t look to be shorted? I would also check fuses on the engine bay compartment if you haven’t done so
  19. Jan 13, 2024 at 7:01 AM
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    It's crazy
    I've literally checked every single flipping fuse in all 3 fuse box locations and not one has been shorted/burned
    Every single one is perfectly fine
    Going to take apart the console again in a bit and check all the wiring. Perhaps a rat has chewed something off
  20. Jan 13, 2024 at 12:33 PM
    #50
    1lowlife
    DADA
    2014 MGM DC SR5
    Are the front dash sockets getting power?
  21. Jan 13, 2024 at 4:33 PM
    #51
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Yes
  22. Jan 13, 2024 at 5:23 PM
    #52
    1lowlife
    DADA
    2014 MGM DC SR5
    That's odd.
    Maybe you have a bad connection in the adapter for the charger.
    It plugs into the existing wiring for the rear outlet.
    Pull the console back off and check those connections..
    Maybe even check the OEM plug for voltage and then the adapter end that plugs into the outlet..
    Also, make sure the ground is good.
    bchaase[QUOTED] likes this.
  23. Jan 13, 2024 at 7:12 PM
    #53
    bchaase
    bchaase New Member
    Daphne,Alabama
    LOOKING FOR IDEAS
    Will do at a later date
    Was busy installing a new HU thanks to @TRDFerguson
    1lowlife[QUOTED] and TRDFerguson like this.
  24. Jan 14, 2024 at 12:21 AM
    #54
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You’ll likely have to test continuity at each fuse that supplies the console; many have had similar instances where the fuses looked fine but when testing continuity found that they were blown
  25. Jun 21, 2024 at 5:42 AM
    #55
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I was so ready to order my charger from Toyota but it if does not work on the iPhone15 I don't want to waste my money. Has anyone used it with the iPhone 15? I have the Iphone 15 max
