Looking to see if I can fit 305/55/20
Discussion in '1st Gen Tundras (2000-2006)' started by Mhagha, Jan 24, 2023.
  1. Jan 25, 2023 at 12:44 PM
    Mhagha
    Mhagha [OP] New Member
    @KNABORES.
    That actually helped me understand it better. I was thinking smaller rim, More room.It’s a bit difficult to understand all the wheel sizing scenarios.
    I guess I will have to put some sort lift to have the 305/55/20s. I did redo my front suspension with a lot help from all you guys especially @Shifty. Upper, lower control arms,ball joints, high angle axles,struts billstein 5100, stabilizer links,tie rod ends, rack piñon bushings…. So I will try and find old posts but I’m guessing to achieve this…. Up front I can add 2-3”spacers to struts. AAL or blocks to rear depends where Front sits. Ok thanks!!!
    @FirstGenVol
    What I like is the 305/55/20 look.
    I have 7” from fender trim to top tire in rear and I have 7 and 1/2” up front fender trim to top tire. 265/70/16. Is orig tire size truck came with. Actually have 245/70/16 on it now
  2. Jan 25, 2023 at 4:17 PM
    If you have the 5100’s in the front of your truck, you’re in luck. They are adjustable. You can set them for up to 2.5” of lift. They have to be removed from the truck and the spring removed in order to readjust the lower spring seat position. You’ll have to get an alignment afterwords. You’ll have to put better clamps on your CV boots. Lots of threads in here and on the internet in general describing how it’s done.
    Mhagha[QUOTED][OP] likes this.
  3. Jan 25, 2023 at 9:26 PM
    You're gonna rub bad if you don't get the right offset wheel. I'm almost positive there was someone on here who had that same setup. Maybe search 20 inch in the search.
    Mhagha[OP] likes this.
  4. Nov 15, 2023 at 3:52 PM
    Mhagha
    Hello everyone,
    Figure I post an update with the wheels. Thanks again to everyone for the help…. I have def achieved the look I was going for(305/55/20s)
    Looking to do some paint work now….
  5. Nov 15, 2023 at 8:12 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    What lift did you end up going with?
  6. Nov 16, 2023 at 3:15 AM
    Mhagha
    I used a 3 inch AEP leveling kit. I don’t go off road… and I use my truck for a 10 min ride each way to work.
  7. Nov 16, 2023 at 6:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I'm happy you were able to achieve the look you were going for :thumbsup:
    Tlar25 and whodatschrome like this.
  8. Nov 17, 2023 at 4:35 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Keep an eye on your axle boots; that's a big spacer - geometry gets a little whacked. Ask me how I know...
    Looks great!
  9. Nov 17, 2023 at 5:12 PM
    Mhagha
    Thanks. I installed high angle axles as well. So hopefully no head aches
    abcinv likes this.
  10. Nov 17, 2023 at 5:16 PM
    What brand? Someone on here picked up the NAPA ones and they were essentially the same, possible shorter than OEM, and didn't seem to have any more articulation. OEM are bulletproof. You just need to re-clamp the boots once you go over 2ish inches.
    Diablo169 and The Black Mamba like this.
  11. Nov 17, 2023 at 5:20 PM
    Mhagha
    I honestly don’t remember. It was soo long ago. I do believe I bought them from Rock Auto
  12. Nov 17, 2023 at 5:25 PM
    abcinv
    Tommy
    NW Georgia
    My re-clamp didn't last long on mine though it was probably installer (me) error..
  13. Nov 17, 2023 at 5:26 PM
    Mhagha
    In case anyone wants to know. No rubbing with new wheels and I didn’t need to trim anything.
    Weagle, KNABORES and abcinv like this.
  14. Nov 17, 2023 at 5:45 PM
    I cleaned up the little bit of sling present, and haven't seen any since. But I have some worm-gear clamps waiting to go on if I see any significant slinging again.
  15. Jan 12, 2024 at 8:09 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    so you raised it 3 inches. I believe I saw that in a later post
    what about backspacing and/or offset on your wheels?
