4WD not working. Vacuum lines trimmed, plugs cleaned
Discussion in '1st Gen Tundras (2000-2006)' started by Stopithurts77, Jan 11, 2024.
  1. Jan 11, 2024 at 8:37 AM
    Stopithurts77
    Stopithurts77 [OP] New Member
    Curious for any input on why my four-wheel-drive is not working. I’ve trimmed vacuum lines. I’ve cleaned plugs and just curious as to what I need to do next…
    2002 Tundra 4.7
  2. Jan 11, 2024 at 8:45 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    1st - Welcome to the forum
    2nd - You should use the search function on the top right corner of the screen and do a forum sweep under the 1st gen section for others with similar symptoms, causes and fixes
    3rd - update your post with more info. Exact concern, symptoms, ect...
    EDIT: 4th - Read though THIS
    bfunke likes this.
