General Supercharger Thread
  1. Jan 7, 2024 at 11:58 AM
    ARES35
    ARES35 New member for life
    Mile high
    Thanks Wynnded but it's all good. I don't need to take time away from your Sunday man! Ill be patient and can wait:D
    Wynnded[QUOTED] likes this.
  2. Jan 7, 2024 at 4:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wynnded and ARES35 like this.
  3. Jan 7, 2024 at 4:26 PM
    ARES35
    Mile high
    Yes sir, 0.131663 is stock truck IC per the injector control. My problem at this point is switching to MPVI-3 and having only the stock truck map. I could probably work off the 1900 TRD tune though but still have no idea of the ICH/ICI/ICIH, pulse width, offsets, corrections etc.... I simply need a new tune.
    Wynnded and Mdl[QUOTED] like this.
  4. Jan 7, 2024 at 4:37 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Start with like .08 for IC, the "high" values just set the same as the normal values. The inverse scales the same as the IC, so I would just multiply/divide by the same ratio to reach 0.08. The pulse width doesn't need changing. Offset you take from the sheet Prospeed gave you where it shows flow rates, it should list injector dead time which is the offset vs volts (make sure the volts are correct). All the other shit you could skip for right now to at least get it running. MAF values if you're using the Magnuson then pull the TRD tune from the HPT forum where I uploaded it or I can send it over and then copy the MAF values.
    armyoffoo, Wynnded and ARES35[QUOTED] like this.
  5. Jan 7, 2024 at 4:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Weeeellllll, that might be a place to start, but @snivilous and I have noticed that that doesn't seem to apply to all vehicles. Mine turns out to be way different and Sniv commented that he was tuning one where the IC was unexpectedly higher than anticipated. @ARES35 has a little more going on because his truck is a FFV. I might hazard a guess that once one tunes the IC, the rest will fall into place via calculation. The Offsets he needs are listed on the paperwork that came with the injectors, toward the bottom. Direct plug-in for those. I don't think Corrections come into play on S/C'd tunes.
    ARES35 and snivilous[OP] like this.
  6. Jan 7, 2024 at 4:42 PM
    ARES35
    Mile high
    Copy that thank you Snivilous! I'll get to it and download via the HP forum asap!
    Mdl likes this.
  7. Jan 7, 2024 at 4:52 PM
    snivilous
    SW UT
    If you copy the TRD file, change the injector values, and maybe put the stock timing values back in (or just run the TRD timing) that will put you on a very good track. The TRD tune is the basis for a lot of what i do, like TRD transmission values slap pretty good as is. Just pull up the TRD in one window and your base tune in another, and just go through each table and copy and paste, then tweak those couples things, and you'll be off to a great start.
  8. Jan 7, 2024 at 4:54 PM
    ARES35
    Mile high
    Understood. In the repository I do see a few of your guys S/C tunes. I see your Tundra stock TRD, and a few FFV S/C tunes. Would I be better off maybe starting with a base FFV?
    Mdl likes this.
  9. Jan 7, 2024 at 5:00 PM
    snivilous
    SW UT
    I'm not aware of FFV TRD files but maybe I'm wrong. I would use mine just since I know it's a clean TRD file.
    For all your FFV values set it to the same as the base value, is there are tables with alcohol amount, go into each alcohol value and set it to the same as everything else, so it shouldn't matter what the ethanol sensor calls out, it always commands the same. This doesn't entirely solve the ethanol issues, but at least there's no question in regards to what you do have control over. An example of that is the injector high constant, just set it as the normal IC so it doesn't matter.
  10. Jan 7, 2024 at 5:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There may not have been a TRD calibration for 2017, whatever year TRD stopped selling the S/Cs they stopped having a calibration. At one point, the entire S/C thing was "not for FFVs".
    Mdl and ARES35 like this.
  11. Jan 7, 2024 at 5:18 PM
    ARES35
    Mile high
    I understand. Have heard that the ethanol % content likes to increase incrementally is my reason for asking. Thank you!
  12. Jan 7, 2024 at 5:30 PM
    ARES35
    Mile high
    @snivilous, is this the correct TRD calibration? I'm just not seeing the ICH/ICI/ICIH like my base FFV map?
    Mdl likes this.
  13. Jan 7, 2024 at 5:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Do this:
  14. Jan 7, 2024 at 5:41 PM
    snivilous
    SW UT
    Yes, you'll have to go through each table specifically and copy the values over since the FFV has more things like you're seeing.
    Mdl and ARES35[QUOTED] like this.
  15. Jan 7, 2024 at 5:54 PM
    ARES35
    Mile high
    That makes sense, I am seeing a multitude of ECM #'s, bottom with explanations with my FFV map. Must be because it's a 17 ECU vs 08 ECU. Sorry to be of a nuisance, just taking in the information until it clicks. This is similar to Cobbs Accesstuner race software but just layed out differently. I especially appreciate your time, @Wynnded and everyone else who's helped my simpleton ass:hattip:
  16. Jan 7, 2024 at 5:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Those are table/map definitions. You'll see them when you hover over a "button" even if you only had one calibration open in the software. Hey, we were all new to this at some point.
    Mdl, snivilous[OP] and ARES35[QUOTED] like this.
  17. Jan 7, 2024 at 6:01 PM
    ARES35
    Mile high
    This needs to be stickied as we used to say on a old ass Mazdaspeed forum! This information great for anyone running 750CC injectors and needs flow rate values! :bowdown:
    Mdl and Land Bruiser like this.
  18. Jan 7, 2024 at 6:07 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If they work, great. They may just serve as a starting point though, time will tell. If you choose to have Sniv remote tune your truck, he may become aware of some need to adjust them slightly. Hopefully they reduce/minimize the richness and misfires that you were seeing before.
    Mdl and snivilous[OP] like this.
  19. Jan 7, 2024 at 6:39 PM
    snivilous
    SW UT
    Keep in mind those aren't end all be all values. Someone with a different intake or wanting to dump more fuel may need to modify those values. The injector constant is not a raw flow rate value, the same way that the MAF values are not a raw grams/second value---instead they are variables in an equation and the relationship to other values is what matters more so than the value itself. My truck right now has a IC of .073 or something, and they are the same injectors that Wynded and you have with a IC of .085, that's quite a bit of difference and both work fine. Use it as a starting point, but don't be married to that IC thinking it has to be that way because of the injector size.
  20. Jan 7, 2024 at 6:47 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @snivilous has had to pound this into my head in more that one discussion! :frusty::rofl:
    Mdl, snivilous[QUOTED][OP] and ARES35 like this.
  21. Jan 7, 2024 at 6:50 PM
    ARES35
    Mile high
    Understood. Since @Wynnded is running a similar set-up/combination blower/injectors and his high elevation this is a good base for someone like me. That makes sense.
  22. Jan 7, 2024 at 6:50 PM
    ARES35
    Mile high
  23. Jan 7, 2024 at 7:25 PM
    snivilous
    SW UT
    And you have to start somewhere, so may as well use those, I completely agree. With any luck you'll never have to tweak the IC. But if you datalog the fuel trims and they're more or less off by 10%, then change the IC. Use the IC as your gross adjustments for fuel trim, and then use the MAF table to adjust individual cells a little here or there.
    Fastlane47, Mdl, armyoffoo and 2 others like this.
  24. Jan 7, 2024 at 8:20 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    one of the reasons that made me return the prospeed injectors and pay the restocking fee. You'd think for the price, they could do a little better on the end product
    Mdl, Wynnded, armyoffoo and 2 others like this.
  25. Jan 7, 2024 at 8:35 PM
    ARES35
    Mile high
    Well having trouble writing the tune from VCM editor. I'm doing something wrong. Device re-synced with credits. Even the VCM information shows MPVI-3 with serial number and credits . Under the license tab in help though the RTD device with credits is only shown. I dunno will have to mess with it after work tomorrow.
  26. Jan 8, 2024 at 3:56 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Parts have come in
    Banks Power Pedal Monster Throttle booster with IDASH
    - banks power IDash 1.8 expansion gauge
    -banks power DUAL gauge pod suction mount for IDASH
    - Banks power Air Mouse
    -banks power IDash 1.8 data monster thread pressure sensor
    -banks power air mouse ambient air density sensor module for IDASH
    Silver17, M3Tundra-JK and ARES35 like this.
  27. Jan 8, 2024 at 6:35 AM
    ARES35
    Mile high
    Figured out how to write! Just had to delete the license.dat file from RTD device and bam! Wrote the tune, started the truck and misfire/surge galore! Lol. Could smell fuel on driver side rail so pulled it, reset and oiled the seals. Re-installed with fingers crossed and boom she started right up and is purring like butter. Got it all done before heading into work this morning:D
  28. Jan 8, 2024 at 4:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Purring like butter :confused::notsure::rofl:
  29. Jan 8, 2024 at 5:09 PM
    ARES35
    Mile high
    You're right, that makes no sense.... my excitement had me saying some dumb shit this morning :laugh:
  30. Jan 8, 2024 at 5:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Haha we know what you meant...smooth like butter. Maybe purring like a cat licking butter. But the engine is running smoothly!
