UPDATED: I am crying on the inside....seriously. Pic.....HVAC core being replaced
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sundog, Jul 14, 2020.
  1. Jan 2, 2024 at 9:00 AM
    jgranato
    jgranato New Member
    @snivilous I am having the same issue in my 07 Tundra (little to no heat on either side...dealer said it is a blend door). How can I manually set the door to AC in summer and Heat in winter?
  2. Jan 2, 2024 at 9:03 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's been awhile since I screwed with it. As janky as it was, I took a piece of wire, like a coat hangar, and as I recall reached up through the passenger footwell and disconnected the floor vent tube and then shoved the wire up inside the climate controls and jammed it around until it started blowing air where I wanted it :rofl: there was no rhyme or reason, just prying on things until the blend door would move into an acceptable position hahaha
  3. Jan 2, 2024 at 9:25 AM
    jgranato
    jgranato New Member
    LOL that is brave...you must have been freezing. Were you able to repeat the process to switch it back when the temp changed? I was thinking about drilling a hole thought the side (hopefully near the end of the blend door) insert wire push for hot pull for cold when the season changes. just need to figure out exactly where to get after it. Thanks for the confidence that a manual shit is actually possible!
  4. Jan 2, 2024 at 9:28 AM
    snivilous
    SW UT
    I just screwed with it enough so that it's eternally on a combination of feet and face essentially. Prior to that the feet didn't get any air at all, so now that it's a 50/50 split it's good enough to live with it. The defrost works fine, in my case it just seems to be the feet blend door doesn't work so by forcing it into a halfway open position I now have defrost, and 50/50 face/feet as my two options haha
  5. Jan 2, 2024 at 10:22 AM
    jgranato
    jgranato New Member
    Ahhh my vent selector works fine. The switch between AC and heat is my issue. Suspect I should be able to do something similar.
  6. Jan 4, 2024 at 12:36 PM
    doggunner
    doggunner New Member
    2014 Tundra Crew max White
    Had this done two winters ago. Then had redone a few weeks later under warranty. I felt so bad for tech. I had heat on one side cold on other side. Not a sqeak since.
  7. Jan 4, 2024 at 2:48 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    damn what was price to do?
  8. Jan 4, 2024 at 3:03 PM
    doggunner
    I think the Part is around $900.00. Two years ago. And it’s a 12 hr job I believe.
  9. Jan 4, 2024 at 3:25 PM
    parkerbows
    Jack
    damn so has to be 3k around
  10. Jan 4, 2024 at 3:33 PM
    doggunner
    I think mine was $2500. 00 more or less
    But I also had 835,000 km on truck at the time so wasn’t too bad.
  11. Jan 4, 2024 at 9:28 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I've never done it but remember watching this video, typically the issue is the blend door and it seems Toyota says the dash needs to come apart but this guy did it without doing that by drilling one hole.
    https://youtu.be/vDb0w_uol-8
  12. Jan 5, 2024 at 9:07 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Glad it worked out!
  13. Jan 5, 2024 at 12:13 PM
    doggunner
    Ya good luck doing that. I would never do that. There was another video guy replaced HVaC unit in parking lot. lol he had parts all over the place
