General Supercharger Thread
  1. Jan 4, 2024 at 12:48 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'll see your 14 & "raise" you 2.5! (first positive number the BMW has seen. They have the MAP connected to the BOV vacuum, doesn't seem right.
    Blanks have been ordered to house the sub volume knob & LED/glass break sensor for the alarm.
    ssmokedz, M3Tundra-JK, Mdl and 5 others like this.
  2. Jan 4, 2024 at 1:00 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Are we talkin' steel or fiberglass?
    Too soon?
    Mdl, e30cabrio, Wynnded and 3 others like this.
  3. Jan 4, 2024 at 1:00 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Ha!
    Mdl and Saltyhero13 like this.
  4. Jan 4, 2024 at 1:28 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I rolled into it. Didn’t know I was gonna do a hit till I saw the road was clear
    And
    I realize that 11psi is not due to my zen knowledge of boost as I realize it more an indication of the plethora of restrictions I run
    11psi is just ignorant. In a mature way
    Mdl, Wynnded, PolishedTRD and 3 others like this.
  5. Jan 4, 2024 at 2:36 PM
    e30cabrio
    Doh! I was looking at the left gauge. Lol
    Mdl likes this.
  6. Jan 4, 2024 at 2:38 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    lol. No worries
    I think at 14 psi. I would be a mound of mangled engine parts
  7. Jan 4, 2024 at 4:14 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    1000 more rpm to go!
  8. Jan 4, 2024 at 4:19 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I'm hoping for 16psi with the new set up, fingers crossed.
  9. Jan 4, 2024 at 4:30 PM
    Saltyhero13
    Built short block is good for 1000HP, no?
  10. Jan 4, 2024 at 4:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh yeah. That will beso sweet!
  11. Jan 4, 2024 at 4:35 PM
    Fastlane47
    Maryland
    2018 Platinum
    They said 1200, so I hope, lol.
    nags, nobodyintexas, ARES35 and 5 others like this.
  12. Jan 4, 2024 at 4:49 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sorry if you mentioned it and I missed it, but are you upgrading the blower?
  13. Jan 4, 2024 at 4:52 PM
    Fastlane47
    Maryland
    2018 Platinum
    I'm going to a 2.0 pulley from @snivilous and an ATI crank damper pulley.
    nags, ARES35, HulkSmurf14 and 5 others like this.
  14. Jan 4, 2024 at 4:52 PM
    Saltyhero13
    You'll be fine. 16 PSI wont be anywhere near maxing out your new engine's capacity. I would guess 650-700WHP.
    I think this was shot at 20ish PSI:
    https://youtu.be/q18dzzlHM7Y?si=aIVRI00fwTx9hR8-
  15. Jan 4, 2024 at 4:54 PM
    Fastlane47
    Maryland
    2018 Platinum
    I'm hoping for 650 or so to the wheels, next year a bigger blower.
    ARES35, Wynnded, Mdl and 3 others like this.
  16. Jan 4, 2024 at 5:30 PM
    Saltyhero13
    I think you'll be close if you don't hit your goal. Hard to say with all the variations.
    Using the Holdener formula and not accounting for inefficiencies and parasitic loss you would need to push ~45 PSI (sorry 30 psi) to hit 1000 HP. On a blower set up probably higher PSI to hit 1000. I think the transmission in the video just has a valve body upgrade.
    nobodyintexas, Mdl, ViktorG and 2 others like this.
  17. Jan 4, 2024 at 5:32 PM
    Fastlane47
    Maryland
    2018 Platinum
    I have my VB upgraded, hopefully that helps.
    Mdl, Wynnded and Saltyhero13 like this.
  18. Jan 4, 2024 at 5:37 PM
    Saltyhero13
    Reading the BRX threads on the other tundra forums the transmission is the next weak link. The ProSpeed built turboed Tundra had issues with their built transmission rated for 1000HP, I think they said it wouldn't hold 750. I don't know what the solution is outside a swap. It's a 50/50 on which builder they used.
    Mdl, ViktorG, ARES35 and 2 others like this.
  19. Jan 4, 2024 at 10:24 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    BRX welded the clutches in 5th gear at the drag strip, however a Tundra won't shift into 5th at full throttle until you are going somewhere around 120 mph, so hopefully for most people that gear won't be an issue :)
    I think my truck transmission has held up so far partly because the truck is so light and on small wheels (less load) and I finish the 1/4 mile while still in 4th gear.
    I blew up more that one transmission on my lifted truck and it made a lot less power that the little one, but it weighs almost 50% more and on oversized tires.
  20. Jan 4, 2024 at 10:30 PM
    ViktorG
    Viktor
    Calgary, Canada
    There was a boost gauge attached during that run and you can see the boost on the screen, peaking around 18.5 PSI. It reads a little lower than the gauge in my truck though, so who knows what it actually is.
  21. Jan 5, 2024 at 6:11 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    So, i ran the Holdener formula. and come up with 494WHP....or thereabouts.
    which, if you harken back to my previous dynos, is pert-near right on.
    on the 80mm I did 477whp. the 477 is a smidge outside the formula.
    it would not be a far stretch to surmise the 77.5mm gives me ~20hp over the 80mm.
    Crank HP is now at the "demon core" level. or thereabouts.
  22. Jan 5, 2024 at 7:11 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    It will be neat if the larger Aisin A465/AS6xRC can be adapted. That will hold it.
    Mdl likes this.
  23. Jan 5, 2024 at 7:27 AM
    Saltyhero13
    Yes it would be "off" a tad to account for parasitic loss of the blower; it should deviate more at higher power levels.
    He uses it to estimate blower parasitic loss in a few videos and to estimate how much boost you'll need to hit your target goal. I would repost the video where he talks about it but I've watched about 100 of his videos in the last few weeks. It helps if you know your baseline dyno number too.
  24. Jan 5, 2024 at 7:48 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    My truck made 588WHP on the Harrop 85mm with the 4.5" intake and RCF throttle body, not sure what boost was. After I made some fuel system changes, switched to ARH headers, and installed my IPT valve body ProSpeed said it made over 600WHP, but was dropping fuel pressure at higher RPM. I took it back home for troubleshooting/modification, never got the print out from the 600+ run, and I haven't taken it back.
  25. Jan 5, 2024 at 8:04 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sheewww
  26. Jan 5, 2024 at 8:27 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I've still got the 77.5mm pulley sitting on the shelf...taunting me...but I'm pretty sure that's the catalyst that escalates my engine-building time table.
    ARES35, Mdl, Saltyhero13 and 3 others like this.
  27. Jan 5, 2024 at 8:47 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL exactly- I've been talking to xat already. Built motor will happen next after the big suspension revision happens.
  28. Jan 5, 2024 at 9:15 AM
    Saltyhero13
    Load is an important point to echo but never discussed (in context of longevity). While digging into high compression, high boost setups this theme came up several times, again and again. Lighter vehicles may fare well while heavier vehicles won't.
    How much of a factor it is with a 3 ton baseline :notsure: but 50% reduction is significant in your case and probably why you're close to sub 3 seconds.
    ARES35, Mdl, Silver17 and 3 others like this.
  29. Jan 5, 2024 at 9:27 AM
    ViktorG
    Viktor
    Calgary, Canada
    2.65 seconds on a good day :)
  30. Jan 5, 2024 at 11:19 AM
    Saltyhero13
    :drool:
    Mdl and ViktorG[QUOTED] like this.
