  1. Dec 30, 2023 at 3:41 PM
    Damn, super weird being on one end of that spectrum and know I'm sharing it w/38yos :rofl:
    38 seems like half my life ago at this point.
    BroHon likes this.
  2. Dec 30, 2023 at 3:54 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Shifty do know if stock 2005 4wd trd DC suspension will fit a 2006 2wd DC?
  3. Dec 30, 2023 at 4:08 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    When I lived in Maine they showed XXX rated films at the drive in (Ellsworth)
  4. Dec 30, 2023 at 4:09 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It's 7 years out of date. 38+7=45
    shifty`[QUOTED] likes this.
  5. Dec 30, 2023 at 4:10 PM
    Awesome! :thumbsup:
  6. Dec 30, 2023 at 4:14 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    That Kerrygold pure Irish will change a man.
    Finally wrapped up the new air system for the shop today. No more air leaks. bliss.
  7. Dec 30, 2023 at 4:59 PM
    I'm assuming there are some differences with the springs as far as tension/spring rate goes, because the 4WD extra bits are heavier, but I doubt it's going to cause major problems swapping it over.
    I'm basing that on the fact that the guy who bought my OEM wheels recently took my AC 4WD OEM struts, and his friend installed them in his 2WD DC and had no issues to report.
    I mean, we've got some in the fridge. It's all my better 3/4 will eat. Maybe she's not using it right. :rofl:
    JakeJake[QUOTED] likes this.
  8. Dec 30, 2023 at 7:13 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Like some of these oldies your posting up :thumbsup: haha used to crank that one.
    What an awesome pile of parts, she's gonna be riding nice!!
  9. Dec 30, 2023 at 10:33 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Interesting First Gen bit here posted by Bilstein.
    https://www.instagram.com/p/C1f5wcRSuVG/?igsh=MTFwYmw2eTA3b25l
    To summarize in case you can't see the words that go with this, they are going to test the difference in a 1,000,000 mile stock tundra shock and a brand new shock. They haven't done the testing yet
    Here is confirmation that the aftermarket 4600s are not exactly identical to the stock 4600s found on TRD trucks. Slightly stiffer.
    shifty`, BroHon and FirstGenVol like this.
  10. Dec 30, 2023 at 11:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My stock shocks are pretty shot at 145k the rears will bounce a couple times
  11. Dec 31, 2023 at 6:45 AM
    Why would they test an old worn out shock against a new one?
    455h0le_dachshund likes this.
  12. Dec 31, 2023 at 7:02 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    R&D
    shifty` likes this.
  13. Dec 31, 2023 at 8:32 AM
    The next question is WHY would someone would drive a shock to a million miles that wore out 900k miles ago.
  14. Dec 31, 2023 at 8:39 AM
    The same reason people won't replace a timing belt or ball joints for 200k miles.
  15. Dec 31, 2023 at 8:47 AM
    Makes for an uncomfortable ride after they wear out. I can attest to that having done mine at 230k. You can feel a jolt going over any roadwork with a bumpy surface.
  16. Dec 31, 2023 at 8:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Mine are smooth like an 80's cadillac. Just floating.
    Jack McCarthy likes this.
  17. Dec 31, 2023 at 8:58 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    @assassin10000 my 5100's are for the rear & dont have clips or grooves, but the 6112 measurements are gonna have to wait. Battery's dead on my calipers & i havent dug for my precision set yet.
    As a side note, has anyone used cheap spring insulators? Or know if oem insulators are available?
  18. Dec 31, 2023 at 9:36 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Gotcha. I have a rear pair of 5100's on hand. I was hoping you got front 5100's to. I didn't realize you had 6112's coming.
    Measurements would still be cool tho. Whenever you get around to it.
    I picked up the sos front lowering kit and want to see if it'll work with 5100's. I don't want the full front 2" drop, as I have tc rear shackles which lower 3/4".
  19. Dec 31, 2023 at 9:45 AM
    Jmellc
    Jmellc New Member
    2000 Tundra Limited, AC,4.6L
    I think that was the original type wood stove, invented by Benjamin Franklin. Fireplaces were/are charming but lost most of their heat up the chimney.
  20. Dec 31, 2023 at 9:54 AM
    My FIL is a hardcore prepper and sent my wife home with this bag. I wonder how the pouch water tastes. He also included these questionable looking jack stands. Maybe he wants to kill me...
    Mr.bee and Jack McCarthy like this.
  21. Dec 31, 2023 at 9:56 AM
    I put a damper in the chimney so it’s a little better
  22. Dec 31, 2023 at 9:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I been wondering the same thing about the SOS and 5100's, but for more stiffness, not height. I've currently got the 4600's in front and KYBs in the rear. I plan to put a progressive AAL on the rear since it's now SUA. So it won't affect height, just stiffen the rear. When I do, I plan to swap in rear 5100's for their added length, because the bottom rear shock mount on the SOS kit goes on the u-bolt saddles. So an AAL on spring under axle would effectively lower my shock mount.
  23. Dec 31, 2023 at 10:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Issue you'll run into is boards that depth unless you're doing multiple boards per shelf or plywood.
    KYB are fine
    jerryallday and FrenchToasty like this.
  24. Dec 31, 2023 at 1:42 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    IME parents get to a phase where they start emptying the house of stuff they won't be using anymore, but want in reach 'just in case'. IE, they start gifting it to the kids. They're "only" 2 ton stands, but expect you'll get some use out of them before he does.
    Look at it this way - he's clearing out the house - less work for you two eventually.
    When I was down for Christmas Dad told me to take the hammer drill, Sawzall, and the workbench. He built that workbench in the basement in 1964 - that beast is going to the next owners. He's trying to get me to take a big (mahogany?) executive desk with glass over leather top. Beautiful but WTH am I going to do with it, I'm on countdown to dipping into my 401k. I should be in clearing out the house mode.
  25. Dec 31, 2023 at 1:47 PM
    Just don't do poly, I think that's the biggest mistake you can make. KYB and Bilstein are about the only companies in that list I'd consider trusting.
    I used that exact set of jackstands for years to lift all kinds of things. I'd use those over the deathtrap non-locking-ratchet-style jackstands any day. The weak point on those yellow ones is the integrity of the locking pin. But I guarantee you that locking pin won't shear as quickly as a ratchet will fail.[/user]
    NUDRAT[OP] likes this.
  26. Dec 31, 2023 at 2:37 PM
    The Black Mamba
    DFW
    Imma keep it stock
    304k:anonymous:
  27. Dec 31, 2023 at 8:52 PM
    Happy new year, ya salty cods
  28. Dec 31, 2023 at 8:53 PM
    The Black Mamba
    DFW
    Imma keep it stock
  29. Dec 31, 2023 at 8:53 PM
    Dakillacore
    Georgia
    Happy New years, y'all.
    NUDRAT[OP], shifty`, BroHon and 2 others like this.
  30. Dec 31, 2023 at 9:01 PM
    montanalily
    montanalily New Member
    montana
    02 AC V8 4WD
    you could use some moisturizer.
