Yet another P0420 code
Discussion in '1st Gen Tundras (2000-2006)' started by whodatschrome, Dec 9, 2023.
  1. Dec 29, 2023 at 1:15 AM
    #91
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    My experience is saying you pinched a wire during the swap. I just did air filter and my maf wires are hard ( brittle) as crap. And I had a 4-runner that had a crack in main ecu wiring loom. PO took it to four shops and they could not figure it out, threw every part imaginable at it. They gave up, i COMPLETELY unwrapped harness and it was ONE cracked wire causing all the issues. It took a full day of test light volt meter, repeat. But i got a cherry lifted 88 4rnr for a nickel. Did you completely unwrap harness or just chect at neck by harness?
    JakeJake and 455h0le_dachshund like this.
  2. Dec 29, 2023 at 5:32 AM
    #92
    whodatschrome
    whodatschrome [OP] New Member
    North of North Plains, Oregon
    lots of dents
    I’d be after the spacers that have the two bolt toyota flange. I’m coming up fairly empty for anything local. It looks like they’re only available online?
    https://jcarpart.com/products/toyot...sbj2_lfdsPp4C8KezFd1Vkl5bwXeWUDxoC5u8QAvD_BwE
  3. Dec 29, 2023 at 5:40 AM
    #93
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I think with your welding skills you could easily make your own spacers from two extra flanges and tube (plus new gaskets) or weld another bung on top of the existing bung
  4. Dec 29, 2023 at 5:51 AM
    #94
    whodatschrome
    lots of dents
    I did unwrap the harness in a few areas (where i spliced in the 4wd sub harness), but other than that i did not. Anything is possible, as you found out, but i was very carefully to not pinch any wires during the engine swap. The engine harness gets laid on top of the engine during the install, so it’s not like they can get pinched between the firewall while the cherry picker is lowering the block into the engine bay.
  5. Dec 29, 2023 at 5:53 AM
    #95
    whodatschrome
    lots of dents
    totally could, but ugh, totally don’t want to. Maybe i’ll get more motivated to do it. So how long of a spacer would need to be fabbed up?
  6. Dec 29, 2023 at 6:09 AM
    #96
    BluegrapeVr6
    J
    You just screw the fouler on end of 02 sensor. Much easier and cheaper.
  7. Dec 29, 2023 at 6:14 AM
    #97
    whodatschrome
    lots of dents
    My rear sensors are the two bolt flange style. The front are the standard thread in.
    BluegrapeVr6[QUOTED] likes this.
  8. Dec 29, 2023 at 6:17 AM
    #98
    BluegrapeVr6
    J
    Got ya, my bad. That a bummer.
  9. Dec 29, 2023 at 7:58 AM
    #99
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've been wondering if the ECU and the wire harness would accept the new style rear O2 sensor that screws in. That's what my 06 has. But my 03 has the ovals.
    Would be easy to just thread em into my current off brand cats with a fouler/spacer thingy. Or even thread to an oval plate with the fouler/spacer. But sensors are way more expensive than spacers.
  10. Dec 29, 2023 at 8:02 AM
    #100
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  11. Dec 29, 2023 at 4:06 PM
    #101
    whodatschrome
    lots of dents
    right then, i'm planning on making my own flange style o2 spacer for some experimenting. But before i go any further, does anyone know just how far the tip of the o2 sensor needs to be away from the flow of exhaust? Does the tip need to be located just at the very edge of the exhaust tube, or does it need to be further away?...such as more like an inch or so?
    455h0le_dachshund likes this.
  12. Dec 29, 2023 at 8:19 PM
    #102
    whodatschrome
    lots of dents
    Thanks for planting the seed! I was at the gym for quite a few hours this morning thinking about flanges and tubes while working on my MASSIVE gains. I came up with a fairly simple game plan that i was pretty sure would work.
    The oil fouled flanged o2 sensors (that were off of the 2004 broken engine) were drafted to the cause. I cut the sensors out of their flanges, then welded a piece of pipe between the two. It was pretty darn simple. I was hoping to find a piece of stainless tube in my shop, but i didn’t find anything that would work. Zinc plates steel it was.
    43B698DE-30A3-46DF-94A0-BBF8ABCC595D.jpg C236C6CC-C8A4-4140-907A-8307D5F47996.jpg 9AD9A944-57CB-41FC-BDED-22531235021C.jpg 46CCE8A1-C832-43A5-A158-0609DEC4CAE7.jpg FBE63550-D3C9-4D23-91BC-1E1B6798F649.jpg 0E26A662-6C23-4BEA-A65D-0AD613462063.jpg
  13. Dec 29, 2023 at 8:23 PM
    #103
    whodatschrome
    lots of dents
    The spacer adds right about 2” of length. It was raining this evening so i didn’t install the spacer yet. I’ll wait for a break in the rains tomorrow.
    AE6881C3-51FC-4AE5-A45E-4B9205A84EC7.jpg 2B632FC0-C0FF-424A-95CD-8C6F78D2DF5B.jpg EE87FD86-C181-4CCF-95EE-EEEE70FC5912.jpg E29BA7CE-7B9A-4752-AB83-121BDA70F224.jpg
  14. Dec 30, 2023 at 7:40 PM
    #104
    whodatschrome
    lots of dents
    I got the sensor extension installed today. I’ll take the truck for a test drive tomorrow. I don’t have high hopes, so if this doesn’t work, i won’t be disappointed.
  15. Dec 30, 2023 at 9:20 PM
    #105
    whodatschrome
    lots of dents
    Since i already had the truck up on the 2 post lift today, i figured i’d try an experiment and make my own impromptu smoke machine...AND it didn’t work...whatsoever. What i did was jam a shop vac into the tailpipe and positioned the hose to “blow”. I then poured about 1 cup of gas, 1 cup oil, 1 red shop rag, and a pair of torn nitrile surgical gloves all in a metal 5 gallon pail. After lighting it on fire, it produced a fair amount of smoke! I then put the “suck” inlet of the shop vac right next to the smoke. The problem was that since the “blow” side of the hose was stuffed tightly into the tailpipe, then the shop vac couldn’t inhale up any of the smoke. So in concept it could work, but in reality it was a fail. I should have taken a pic of the whole setup, but alas, i didn’t.
  16. Dec 30, 2023 at 9:25 PM
    #106
    Holy cow I bet that smelled worse than a eotten pile of dead ass!
  17. Dec 30, 2023 at 9:33 PM
    #107
    whodatschrome
    lots of dents
    I mean it wasn’t too too bad. At least my shop didn’t stink afterwards...then again i didn’t do it in my shop. My friend is currently in germany with his family (european vacation style). So since he’s gone i did it in his shop. It should air out by the time he gets back home in another week.
    shifty`[QUOTED] likes this.
  18. Dec 30, 2023 at 9:41 PM
    #108
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    :laughing:
  19. Jan 1, 2024 at 8:53 PM
    #109
    whodatschrome
    lots of dents
    An update to this posting here...
    I’ve been driving the truck around for the past few days. I drove about a 50 mile round trip to church and back sunday morning, then drove it another 20 mile round trip to the gym and back today. So far the CEL has stayed off. In the past the CEL would light up after about 15 miles of driving around. Could this simple inexpensive homemade o2 sensor spacer be the miracle i was looking for? I’ll plan to take it in for emissions testing tomorrow or the next day, so stay tuned!
    shifty` and 455h0le_dachshund like this.
  20. Jan 2, 2024 at 7:46 AM
    #110
    The rule of thumb is, "when all else fails, spacer."
    Can you check with the scanner to see the readiness state? If OK, and testing has completed, you're good for emissions.
  21. Jan 2, 2024 at 9:21 AM
    #111
    whodatschrome
    lots of dents
    I just PASSED!!! Thank you all for the guidance on this!
  22. Jan 2, 2024 at 10:49 AM
    #112
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    My gaskets came in yesterday and I installed the spacer today on passenger side sensor. Went to erase the p0430 only to see the p0420 had popped up after the spacer install. Weird.
    So I ordered another spacer. I've got plenty of spare gaskets because I thought I was only ordering two, but I actually ordered two bags of 4 for $4.04. Happy accident I guess. I'll report back if CEL comes back before or after the driver side gets its spacer.
    whodatschrome[OP] and shifty` like this.
  23. Jan 2, 2024 at 8:39 PM
    #113
    BluegrapeVr6
    J
    Thats great news! Happy you are CEL free. Now you can rock the bad cat while you shop for a good deal on new one. Honesty. I would try a hi-flow cat and keep the spacer on truck. Might free up some ponies and you wont be killing the whales.
  24. Jan 2, 2024 at 10:37 PM
    #114
    whodatschrome
    lots of dents
    Whales, snails....it’s not worth it to me to go after a high flow cat. Then again i don’t know how much more one costs than a standard run of the mill cat. I’m totally satisfied with the power of my engine. Yes i have oversized 265/75/16 tires, but since i swapped in 4.10 gears i can light up the tires at will. Buuuuut i do secretly wish that a cracked exhaust manifold was the cause of my p0420 code. Because if it was that, i would have emptied my new chainsaw fund and bought a pair of Dirty Deed’s long tube headers. And if i bought those headers, i would have made an excuse to also buy the rest of his stainless dual exhaust system.
  25. Jan 3, 2024 at 5:59 AM
    #115
    BluegrapeVr6
    J
    Hi flow should be cheaper. Less REM used , i will keep the forum updated on my dirtydeeds review. I cant afford his complete exhaust so it will more be a lth review. I can have a great flowing header back system made, so if the headers make power it will still be a valid test. Id love to know more about our ECU capability to " self-ture" from MAF/upstream o2's ecr
  26. Jan 3, 2024 at 6:02 AM
    #116
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  27. Jan 5, 2024 at 8:12 AM
    #117
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Well you called it, I got a p0156 this morning. I didn't use the bend, but to use the spacer kit on the older oval base sensors, you have to use two pieces between the ovals. ECU doesn't seem to like that. I guess. I'll have to find some one to weld the top oval to the first piece of tube, for a shorter spacer. FML
  28. Jan 5, 2024 at 8:59 AM
    #118
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Congratulations @whodatschrome ! I knew a spacer would do the trick ;)
    whodatschrome[OP] likes this.
  29. Jan 5, 2024 at 9:00 AM
    #119
    DarkMint
    Ben
    Can you unscrew the oval flange and nut and screw it onto the single piece tube instead?
  30. Jan 5, 2024 at 9:06 AM
    #120
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I'm chasing the same thing right now. Shit's annoying
