22 SR5 OEM wheels did not fit 23 SR . HANDS ARE IN THE AIR!
Discussion in '3rd Gen Tundras (2022+)' started by tater256, Dec 29, 2023.
  1. Dec 29, 2023 at 6:31 PM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    If at first you don't succeed, try try again. Maybe you just didn't have the lugs aligned.
  2. Dec 29, 2023 at 6:36 PM
    tater256
    tater256 [OP] New Member
    Rocket City , AL
    Option 3 means my old tire shop took new ownership and hired a dummy. I will report back.
    LarryDangerfield likes this.
  3. Dec 29, 2023 at 6:50 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I assumed you did the test fitting...thats not the case?
  4. Dec 29, 2023 at 7:43 PM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Yes sir. Thanks. Got a decent deal on eBay. Stock steelies make the truck look like utter cheap ass sh*%
  5. Dec 29, 2023 at 8:03 PM
    tuns_o_fun
    tuns_o_fun New Member
    JR
    23 SR5 Off Road
    Last Saturday, I took these wheels off my 23’ SR5 TRD OR and they are sitting in my garage.
    303Gen3 and b6graham like this.
  6. Dec 30, 2023 at 8:56 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think the Taco wheels have a 106mm center hole and the Tundra wheels are around 95mm. I think the Taco wheels have a more negative offset as well? Also, I am pretty sure that the Taco didn't have those wheels as an option.
    I got the same wheels with my 22 Limited TRD OR. You will need the lugnuts that match the wheels, the cone/taper shaped lugnuts that come with steel wheels won't work with these wheels.
    I don't see any reason why they won't fit over the brakes. You should be able to fit 17 inch wheels on your Tundra.
    Can you take a picture or 2 of the clearance issue and the brake and hub. Try to measure the hub bore and hub as well. These wheels will be hubcentric so they should fit snug on the hubs.
  7. Dec 30, 2023 at 1:14 PM
    tater256
    Rocket City , AL
    Thanks for the heads up on the lugs. I didn't get time to mess with it and take pics. I might look at the gorilla black lugs now.
  8. Dec 30, 2023 at 2:23 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    I got my lugs from the dealer - some may want to mess around with non-oem for lugs but I would not suggest it. Can't remember off hand what I paid for them but piece of mind is worth every penny when it comes to tires/rims/.... last thing you need is for something to go bad cause that won't turn out well for anyone. JMO.
    Mattedfred likes this.
