  1. Dec 29, 2023 at 9:45 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I wouldn't worry about it. I try to let my truck come off of high idle before taking off, but sometimes its not feasible. Send it.
  2. Dec 29, 2023 at 10:22 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I hear you. It definitely won’t be every time. I can make time though if it makes more than a negligible difference (which I’m guessing it doesn’t)
    TILLY[QUOTED] likes this.
  3. Dec 29, 2023 at 10:30 PM
    TILLY
    Massachusetts
    It probably doesn't matter. Its just a habit for some of us. :)
    Cl8NL[QUOTED] likes this.
  4. Dec 30, 2023 at 3:13 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Pulled the trigger and got one! I used the eBay link that @Hammerdog shared and got $47 off. $200 to my door!
  5. Dec 30, 2023 at 4:35 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Please share how the install goes! I have the same shields installed.
    HulkSmurf14[QUOTED] likes this.
  6. Dec 30, 2023 at 6:53 AM
    Cthulhu
    Ironman 4x4 Raid rear bumper. Will do a write-up elsewhere on install tips; this didn’t “fight” me as much as the front bumper, and the recovery points on this bumper did not crack and peel when tightened.
    Tapped into the reverse wiring for the inner pods, brake light wiring for the outer pods, and angled them down a bit so they’re not too offensively bright.
  7. Dec 30, 2023 at 10:07 AM
    brkncly
    brkncly New Member
    Oregon
    So where was the other place that you bought it from?
  8. Dec 30, 2023 at 10:15 AM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Just added my TRD rear sway bar kit. Truck spends 99% of its time on the road other than trips out onto the beach in the summer and fall for striper fishing. Big improvement in body roll and a 1 hour job.
    coldcanuk, TreeCat, Nbab23 and 21 others like this.
  9. Dec 30, 2023 at 4:11 PM
    Cthulhu
    Received the front bumper within 3 days, rear about 8 days (different warehouses).
  10. Dec 30, 2023 at 4:26 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Installed Diode Dynamic SS2 ditch lights today. I used brackets from CBI and had a hell of a time trying to keep the hood aligned. IMG_2387.jpg
  11. Dec 30, 2023 at 5:16 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Decided to do something different. I bought a set of Westcott Design reservoir bracket. Spray painted the two holding screws, and put heat shrink around the clamps.
    Driver rear side.
  12. Dec 30, 2023 at 5:49 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hood alignment issues due to the bracket or just from removing the screws???
  13. Dec 30, 2023 at 6:05 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Curious if the mounting of the resevior in that configuration has any benefits compared to the instructions? (Those are 5160s right?)
    HulkSmurf14 likes this.
  14. Dec 30, 2023 at 6:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Orientation won’t effect anything of the resi.
  15. Dec 30, 2023 at 7:11 PM
    Quicksand_Tundra
    Jon
    Hello,
    Yes, these are the 5160 set. The shock should still work regardless how it’s mounted. Would have been nice if Bilstein had an option to setup this way.
    Vr0ck[QUOTED] likes this.
  16. Dec 30, 2023 at 7:40 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Holy crap, this is what I was thinking about doing with my 5160s. The Tacomas and the 4Runner has separate mounts instead of the piggy backs.
    Those were drilled directly into the plastic wheel well? How is it even holding up?
  17. Dec 30, 2023 at 9:55 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Nbab23, Tundra-XP, koditten and 12 others like this.
  18. Dec 31, 2023 at 12:13 AM
    Quicksand_Tundra
    Jon
    Yeah, behind the plastic well is metal frame. It holds up very snug but don’t over turn it or you’ll strip the thread.
    bulldog93 and pvn.beluga[QUOTED] like this.
  19. Dec 31, 2023 at 4:23 AM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Initially it was due to loosening the hinge bolts. Now I’m thinking my issue is the passenger side bracket is making contact with the seal on that side. Going to loosen it and try again.
  20. Dec 31, 2023 at 7:02 AM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    So it seems the CBI brackets are notorious for contacting the hood cowl. Yay me. I trimmed some of the rubber seal that was between the cowl and the bracket ands that helped however the bracket still touches the cowl pushing it down and the hood up. IMG_2394.jpg IMG_2397.jpg
  21. Dec 31, 2023 at 7:38 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Same happens with my CaliRaised brackets. I just fold them over and eventually they molded.
  22. Dec 31, 2023 at 9:42 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Alpharex LUXX black and red
    ATXHusker, Nbab23, Tundra-XP and 18 others like this.
  23. Dec 31, 2023 at 11:42 AM
    Tripleconpanna
    I had heard there was minor issues w/CBI, so I ended up going w/the Ragos... Haven't installed yet, so we'll see...
  24. Dec 31, 2023 at 12:50 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Let us know if you have any issues. Thanks
  25. Dec 31, 2023 at 1:05 PM
    Phrog Driver
    Phrog Driver New Member
    2021 Silver Sky Crew Max TRD Off Road
    Auto window switch and chalk bag 32oz drink holder (Farm Girl was very happy about that one). Fun stuff. About a half hour's work all in on a gorgeous day. Retained the original window switch in my junk bag per recommendations on here, in case the new one fails. Thanks for the ideas guys. Happy New Years!
  26. Dec 31, 2023 at 1:18 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    :eek: Auto window switch!? Is there a write up about this? Link please
    Tripleconpanna and CaptRussia253 like this.
  27. Dec 31, 2023 at 1:20 PM
    RobertD
    Robert
    DFW, Texas
    TreeCat, bulldog93, Henry1jg and 3 others like this.
  28. Dec 31, 2023 at 1:23 PM
    TacomaTRD4x402
    Southern California
    Tripleconpanna and Phrog Driver like this.
  29. Dec 31, 2023 at 1:27 PM
    Phrog Driver
    Yup, thing that took the longest was disconecting the old switch from the harness. Just be gentle so you don't break anything.
  30. Dec 31, 2023 at 1:36 PM
    TacomaTRD4x402
    Southern California
    Okay thanks! Just ordered mine
