Adding Tow Mirrors to a 2014 SR5
Discussion in 'Towing & Hauling' started by Bang Bang, Feb 1, 2014.
  1. Feb 1, 2014 at 8:11 AM
    Bang Bang
    Bang Bang [OP] Age is a state of mind.
    New Orleans
    '14 Magnetic Grey Metallic SR5 CM 5.7 LA Edition
    There is lots of talk on some of the other Tundra forums about what functions work and what functions don't if you add the aftermarket tow mirrors. It's all about what functions you have now. Here is what I can tell you from my personal experience this morning. If you have an SR5 (or other model I'm sure) with power adjust (not power fold) and heat and you add the tow mirrors from 1A Auto (as well as others I am sure) that have the turn signals and running lights in them, you will retain the power adjust and heat as well as add the turn signals and running lights WITH NO OTHER MODIFICATIONS. Just plug them in and you are good. And this is the way this truck should have come from the factory.
    I didn't take pictures but it is a very easy install. It's also easy to break some of the clips on the door panel so be careful. If you search youtube, there are several videos that show how to install them. I broke both of the "push-button" style clips in the upper corners of the door panels. No big deal as I can get replacements on those. However, I also broke one of the clips on the little triangle piece in the corner of the driver door. When you pull off the triangle pieces, start on the outside (part farthest from the truck). The bottom has one of the yellow plastic clips that you won't break. The top has one of those white plastic clips that has "fins" on it and you're not gonna break that one either. The one to worry about is the one that is on the bottom closest to the dash. Once you get the other 2 loose, pull straight back and you'll be ok. If you pull to the side like I did, you will break the plastic tab on the back side of the triangle. I am gluing it back together but will be buying a replacement because I know when I go to swap my speakers it is going to break again and I'll never hear the end of it if someone finds out. :crapstorm:
    Take your time and it's an easy swap. Going for a test drive now. :thumbsup:
    XSPX B345t likes this.
  2. Feb 1, 2014 at 9:45 AM
    Thanks! Once we create a DIY sub-section we will add this over there.
  3. Feb 1, 2014 at 10:49 AM
    Bang Bang
    New Orleans
    Here's a picture of the piece I broke. It's around $20 from the dealer to replace. This is the one without the speaker in it.
    Also, one of the finished product.
    MotoTundra, George14 and Bob like this.
  4. Feb 1, 2014 at 11:43 AM
    Looks good...
    Bang Bang[OP] likes this.
  5. Mar 8, 2015 at 7:57 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    They look great!
  6. May 12, 2015 at 8:14 PM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    Can you share how much the mirrors cost?
  7. May 12, 2015 at 10:16 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Factory set goes for about $600/set, aftermarket copies can be had for about $100/side.
  8. May 13, 2015 at 2:59 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Sparks has them (Toyota to mirrors) for $407. 1A Auto has them $246.45. I went with the Toyota tow mirrors because some people reported vibration with non-Toyota mirrors.
    Installation for Toyota mirrors is exactly same as 1A Auto. I love the running light and signal light.
  9. May 13, 2015 at 3:42 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Thanks so much for the replies.
  10. May 13, 2015 at 3:44 AM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    One more thing - if you're adding these to an SR5 (2015) will the mirrors power fold?
  11. May 13, 2015 at 4:13 AM
    chphilo
    Western PA
    These mirrors are not power folding ones. Power folding mirrors are about twice as expensive, and as far as I know, it's plug and play only for those Tundras that came with the power fold option.
    Relentless likes this.
  12. May 13, 2015 at 8:57 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I installed a limited sport mirror with power fold, puddle light, heat and turn signal on my 2012 RW.
    The functions that worked were power adjust, heat and turn signal.
    The power fold and puddle light did not work. With some additional wiring and upgraded switch you can get these to function. I will be adding a how to at some point for this one.
    geno0506 likes this.
  13. May 13, 2015 at 9:34 AM
    RoVASr5
    RoVASr5 New Member
    Daniel
    Lynchburg, VA
    '14 Tundra CM MGM
    Gibson Metal Mulisha Exhaust BDS Suspension Lift - 7 Inch Icon Dynamic 2.5 coilover reservoirs 18 "Moto Metal 18x9 +18 37x12.5R18 Federal Couragia MTs DV8 Front Bumper
    Interesting information on the tow mirrors, thank you for sharing! Was uncertain on buying them, however after reading this, I'm definitely getting them. Not buying aftermarket, I'm going straight for OEM from Toyota.
  14. May 13, 2015 at 12:09 PM
    XSPX B345t
    XSPX B345t New Member
    Aj
    2014 Black XSP-X
    How was the test drive?? I was thinking about getting them from 1aauto also, did you have any vibration or abnormal wind noise from these mirrors because they aren't (Toyota OEM) mirrors?
    obviously you'll get different wind noise from these because they stick out farther, and I don't see how TRD Sparks sells OEM** tow mirrors for this truck because the 2014's DONT come with tow mirrors.
    seems like extra money you spend on something that's SO CALLED OEM. Just saying guy's, seems a little sketchy :ohsnap:
  15. May 27, 2015 at 12:09 PM
    Ron Burgundy
    Ron Burgundy New Member
    Ronald
    Houston tx
    2015 Black crewmax 4x4
    @Bang Bang are your toe mirror oem or from A1? If it's from A1 how is the vibration on it when at high speed? Thanks
  16. May 31, 2015 at 3:35 PM
    pacman_gptx
    pacman_gptx New Member
    Paco
    2012 5.7L Magnetic Grey Metallic Crewmax SR5 Texas Edition
    Interior LEDs, Cargo/Reverse LEDs, Foot Well LEDs, McGard Tailgate Anti-Theft, Pilot Stubby Antenna
    @Bang Bang I would also like to know about vibration and noise with the 1AAuto tow mirrors, I was looking these up after watching an install video. The price sounds great compared to OEM.
    @XSPX B345t I'm pretty sure what they mean by OEM is that it's a genuine Toyota part not a third party manufacturer like the 1AAuto mirrors. I know that's not what OEM stands for but its a loose term in this case.
  17. Jun 11, 2016 at 8:51 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    So if I buy the tow mirrors I will have turn signal and heat option? I have the sr5 with power adjust and heated option.
  18. Jun 11, 2016 at 9:39 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    If your truck has the tow package from the factory, then yes.
  19. Jun 11, 2016 at 10:37 AM
    chphilo
    Western PA
    Plus you will also get the running light.
  20. Jun 13, 2016 at 6:35 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Nice thanks ordering them now lol
  21. Jul 31, 2016 at 9:13 PM
    Itsthamrmr
    Itsthamrmr New Member
    2014 White Tundra Crewmax
    @Roman are you selling the tow mirrors as well?
  22. Aug 1, 2016 at 3:35 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Sure am.
    Non-power folding
    http://parts.toyotaofcoolsprings.com/oe-toyota/879100c221
    http://parts.toyotaofcoolsprings.com/oe-toyota/879400c221
    Power folding
    http://parts.toyotaofcoolsprings.com/oe-toyota/879100c281
    http://parts.toyotaofcoolsprings.com/oe-toyota/879400c281
    Keep in mind, adding the power folding tow mirrors if your truck does not already have that option involves adding a switch and wiring everything up. It's pretty difficult, if you haven't done wiring before.
    Ryan Mc. likes this.
  23. Aug 2, 2016 at 10:41 AM
    az5point7
    az5point7 New Member
    V
    Northern AZ
    2016 Tundra Limited
    i would loose the BSM indicator in the mirror when swapping to the tow mirrors, correct?
  24. Aug 2, 2016 at 11:27 AM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    HOLY CRAP!!! These are Hella cheaper than the ones I've seen. I've seen aftermarket run for $280 (pair) and junk yards want $400 for the OEM pair. I'd much rather pay this for OEM NEW.
    Questions for @Roman : I have an SR5, manual folding regular mirrors, will these fit and function like stock, with blinkers, heating, power glass? Also, IF I were to buy through you, roughly how much to ship to socal? Here is a CVS pharmacy's address next to me for reference: 14220 Schleisman Rd, Eastvale, CA 92880
  25. Aug 2, 2016 at 2:59 PM
    Roman
    Roman
    Franklin, TN
    Correct.
    Yep, everything will still work just fine. The only thing that is lost is the Blind Spot Monitors, if you have them.
    If you want a shipping quote, simply add the two mirrors to your cart on our site, and input your zip code for a shipping quote. Also, use the discount code SHIP20 to save 20% on the shipping. :)
    Ryan Mc.[QUOTED] likes this.
  26. Aug 3, 2016 at 4:43 AM
    MillsTRD14
    MillsTRD14 New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    Go to LKQ for Factory Tundra mirrors , less than $300 for factory mirrors
  27. Sep 29, 2016 at 9:24 AM
    purpdust
    purpdust New Member
    2015 Tundra CM Platinum
    OME 2.5" Suspension ARB Front Bumper w/ Warn Winch ARB Air Lock Diff Rear
    Could you take the BSM indicator out of the current mirrors and relocate them to the new mirrors? I assume it is just an LED behind the glass. Mark a spot on the new glass and attach the LED?
  28. Nov 12, 2016 at 10:51 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    found really good video on u tube on how to rewire to have power folding mirrors. It doesn't look to hard you have to replace power mirror switch and pull 2 wires for each door to a modular connector. It does look time consuming but doable. Just don't know about spending close to 1000 dollars to have power folding mirrors
  29. Dec 15, 2016 at 9:15 PM
    geno0506
    geno0506 New Member
    Michael
    Can I add these mirrors to my 2017 SR5 Tundra, I want the puddle light to be used as well s the turn and power adjust, is it really plug n play type and the additional wiring and upgrade switch, all that I can maybe buy from cool springs from Roman!
    Thanks
  30. Dec 15, 2016 at 10:06 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    If I didn't have bsm I'd do this. But, the bsm can be really helpful to keep from crushing little cars hiding on the right side.
    Jsena and 040Tundra like this.
