Very fine metal in my oil
Discussion in '3rd Gen Tundras (2022+)' started by OLV1071571, Dec 27, 2023.
  1. Dec 27, 2023 at 2:12 PM
    OLV1071571
    OLV1071571 [OP] New Member
    2024 Silver Limited CrewMax 5.5ft
    Hey gang,
    Did my first oil change at dealer at 1k miles.
    Second oil change I did 1.2k miles later total 2,200 miles. I noticed very fine metal in my oil pan which after all my years of changing oil I have yet to see. I bought my last 4 vehicles new.
    Lastly, I just pulled the plug and drained about 1/4qt after 50 miles to see if there was any sparkly material.
    Have any of you seen fine metal when changing? Would this still fall under normal for break in? I have attached pics but it may not show clearly.
  2. Dec 27, 2023 at 2:19 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Oh my...
    @Eurodriver
    Spraynard sez, "not OK". If that much made it into your pan, then times 3 (X3) is trapped in your filter pleats.
    cartage1 and Terndrerrr like this.
  3. Dec 27, 2023 at 2:55 PM
    OLV1071571
    I want to say it's normal with new engine break in but I need some other experienced guys with some input.
  4. Dec 27, 2023 at 3:14 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Indeed not. Those particles look (subjectively) large enough to bridge the gap between the rotors of your gerotor oil pump.
    This condition is non-conformant. This assumes those particles were not in the pan prior to you conducting the service.
  5. Dec 27, 2023 at 3:14 PM
    OLV1071571
    The pan was clean. :(
    hagrid likes this.
  6. Dec 27, 2023 at 3:17 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
  7. Dec 27, 2023 at 3:18 PM
    OLV1071571
    I wonder if those fine particles are more common but people don't see them as they usually change their oil when it's brown or much darker.
  8. Dec 27, 2023 at 3:31 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I wish. I'm alarmed at what I'm seeing. And OP is no stranger to evaluating the drained oil of their other vehicles.
    I'll hope for the best whilst preparing for the worst.
  9. Dec 27, 2023 at 3:34 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    First changed mine at 600 miles and again at like 1200. Never saw anything like that.
    Hope it’s ok, OP.
    raylo and OLV1071571[OP] like this.
  10. Dec 27, 2023 at 3:36 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    I changed mine when I got it at 5500 or so, didn’t check the pan but cut the filter open and could not see anything.
    OLV1071571[OP] likes this.
  11. Dec 27, 2023 at 3:39 PM
    Tb2
    Tb2 New Member
    James
    Send an oil sample to blackstone and have it analyzed. I have done that it will tell you if it is normal and/or what itnis
    Wynnded, Jettster, NickBrewer and 2 others like this.
  12. Dec 27, 2023 at 3:52 PM
    At first I thought it was metallic paint job....:eek2:
    Wynnded and Retired...finally like this.
  13. Dec 27, 2023 at 3:54 PM
  14. Dec 27, 2023 at 3:58 PM
    What's the filter look like?
  15. Dec 27, 2023 at 4:08 PM
    OLV1071571
    I haven't cut it open yet.
    Unless the drain bolt is not magnetic I haven't noticed anything on the end of it. Which makes me think these are all aluminum shavings from normal engine break in. I still only have 2,300 miles on it.
  16. Dec 27, 2023 at 4:11 PM
    I would try and filter out the shavings with a coffee filter and find out.
    Black Wolf and Mike59 like this.
  17. Dec 27, 2023 at 4:38 PM
    Hella Krusty
    Hella Krusty New Member
    I wouldnt sweat it. Its a motor, all mechanical, shits gonna wear. If really concerned hack your oil filter in half and see whats going on in there
  18. Dec 27, 2023 at 4:50 PM
    Retired...finally
    Not on my watch sez to Gen 2.5 driver.
    Mike59 likes this.
  19. Dec 27, 2023 at 5:13 PM
    Retired...finally
    The magnetic drain plug will tell you very little. The babbit bearing the engines are so fond of digesting aren't going to hanging around that magnet.
    If you don't have the means to open the filter without introducing any metal into it go find an aircraft mechanic at the local airport and slip the guy a fiver. Chances are after you tell him what you're finding he will be more than glad to help you.
    Today's engines aren't supposed to make anywhere near this amount of metal. My last four cars, a Honda Fit, Element, Fiat 124 and 21 Tundra have had their oil filters inspected after every oil change. All have shown bits of sealant on the first two oil changes but none have caught anything more than a few specks of aluminum measuring no more than 2mm.
    So, what's showing up in the pan is only a fraction of what the filter is catching.
    Mike59 likes this.
  20. Dec 27, 2023 at 5:36 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    With all of the couch engineers on this forum...you should just take it to the dealership and have them preemptively rebuild the motor. :rolleyes:
  21. Dec 27, 2023 at 5:49 PM
    OLV1071571
    I cut the filter open. Couldn't really see any of the fine metal in the pleats until I turned off the shop light and looked at an angle with a flashlight. They were there but it was only by looking closely.
    Just sharing. I am going to do another change in 1k miles and see what comes out.
    raylo likes this.
  22. Dec 27, 2023 at 5:50 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I’ve seen these minute aluminum specs on new cars, trucks, and bikes I’ve owned. I suspect they don’t get circulated and therefore not filtered out and just sit in the bottom of the pan. However they stop after the first few thousand miles. Keep an eye on it.
  23. Dec 27, 2023 at 6:09 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Some (not all) do have some glitter in them for the first 2 oil changes.. would I be concerned yet? No. Trucks under warranty. Next oil change catch a sample and check again. If metals still present, talk to the dealer
  24. Dec 27, 2023 at 6:10 PM
    empty_lord
    05 rollover special
    My mr2 engine after I rebuilt it had little aluminum shavings coming out of the pan for the first 2 oil changes. Even after hot tanking the parts. As long as the filters there it’ll catch it. But some of it stays in the pan.
  25. Dec 27, 2023 at 6:31 PM
    OLV1071571
    Glitter is the right word to describe it. I was looking for that word!!! :)
    Mike59 likes this.
  26. Dec 27, 2023 at 7:12 PM
    Retired...finally
    Forbidden Glitter is the technical term.
    Coal Dragger and tundznoff like this.
  27. Dec 27, 2023 at 8:26 PM
    HLR_NM
    HLR_NM New Member
    Harry
    Set the hook OP, you’ve almost got em :rofl:
  28. Dec 28, 2023 at 4:06 AM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    Idk, if I'm under warranty, I'd be inclined to have the dealership do the oil changes at the required intervals.
    I would also drive that engine as hard as possible so it detonates and turns into kibbles and bits under warranty. That will increase your chances of getting a new engine.
    Mike59 likes this.
  29. Dec 28, 2023 at 4:11 AM
    OLV1071571
    I do have the ext warranty to 10yr 100k which is peace of mind.
  30. Dec 28, 2023 at 5:04 AM
    BaldMenace
    BaldMenace New Member
    2022 Tundra SR5 Double cab
    Send an oil sample to Blackstone labs ...they will tell you exactly what is in your oil
