General Supercharger Thread
  1. Dec 27, 2023 at 12:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Excuse me for cross posting but as @armyoffoo posted on the Throttle body thread. We need you to contact HPt to have them program "reset all adaptive and possibly throttle body reset" for the Toyota platform.
    Thanks
    reywcms, VWTim, ARES35 and 3 others like this.
  2. Dec 27, 2023 at 3:07 PM
    ARES35
    ARES35 New member for life
    Mile high
    Well if this is the case a duel feed rail and tuning adjustments almost seems crucial in supercharged form. Is this done because of the one feed into the first rail and then over to the second rail and pressure loss getting to the last cylinder? Is cylinder 4/6 also adding/taking fuel? This is so odd to me.
    Mdl likes this.
  3. Dec 27, 2023 at 3:25 PM
    ARES35
    Mile high
    I'm going have to say sounds like @snivilous is the resident tuner, and quite honestly I'd trust him to tune me over others after speaking to them....... Hopefully he won't mind me bothering him to maybe get me setup right if he's not to busy:D:hattip:
  4. Dec 27, 2023 at 3:29 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I don't know, above my pay grade. Those are the only cylinders I see any difference on. Timing I have absolutely no idea. Fueling is interesting that cylinder 5 is getting leaned out and cylinder 3 that's right next to it is getting extra fueling, and the same amount at that almost like cylinder 5 excess fueling is being handed off to cylinder 3. And the TRD tune concluding that doesn't matter enough so just eliminates all those variables is interesting too, though I would assume it's for simplicities sake and they're just removing variables to make tuning more straightforward and the cylinders (with the TRD tune) were getting so much extra fueling it made up for the individual offsets the stock tune uses?
  5. Dec 27, 2023 at 3:32 PM
    snivilous
    SW UT
    Tuner might be reaching :rofl: I'm just here to help, and I like doing stuff myself instead of trusting others :D but I'd be more than happy to help, or if you make your own tune I'll answer whatever I can
  6. Dec 27, 2023 at 3:37 PM
    ARES35
    Mile high
    @snivilous the HP VCM editor is only accessible by a registered shop correct? This is one thing I do not like with HP. I know I comparing apple to oranges here but at least Cobb tuning ATR allowed the end user to edit their tune and see and adjust everything in the tables.... Damn HP all I can do is datalog. Wish there was a way to at least look at the tables/plots as data. :(
  7. Dec 27, 2023 at 3:41 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    One of the reasons went with a larger system with dual feed to each rail. Think it was @Silver17 posted the Matt Smith discussion on it some cylinder 5 correlations of its increase of issues.
  8. Dec 27, 2023 at 3:41 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Just spit-balling, but maybe it has something to do with the stock intake runners, VCIS and how the airflow makes it to the cylinders vs. the supercharger pushing air more or less evenly across the runners?
    snivilous[QUOTED][OP], ARES35 and Mdl like this.
  9. Dec 27, 2023 at 3:41 PM
    ARES35
    Mile high
    I call BS man!:D I see on your website tuning is coming! If you could please schedule me in for what availability works best for you I would really appreciate it. Plan now is jumping on getting the fuel rail changed over, bigger injectors and dropping the tank and getting rid of the FFV pump.
  10. Dec 27, 2023 at 4:23 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    FFV pump is a good pump, it's the relay/controller that needs to be bypassed.
    ARES35[QUOTED] likes this.
  11. Dec 27, 2023 at 4:29 PM
    ARES35
    Mile high
    I've been searching for specs and LPH on the flex fuel pump to no avail. Also have the Magnuson fuel pump that comes with the non flex fuel...... But of course I'm not seeing any markings for LPH.
  12. Dec 27, 2023 at 4:43 PM
    ARES35
    Mile high
    Here is the non FFV fuel pump supplied with the Magnuson 2650 kit. I've crossed referenced but haven't found the specs on flow yet....
    Saltyhero13 likes this.
  13. Dec 28, 2023 at 9:26 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have no clue on FFV pump specs but can say it looks identical to the Walbro 450 (I posted a pic side by side when I was having my pump issues)
  14. Dec 28, 2023 at 10:00 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ARES35 @e30cabrio
    4Firemandam used the FFV fuel pump to hit 566hp. He did utilize the kenn bell boost a pump. So he gave it up to 16volts? I forgot but didnt @ViktorG fuel video show the FFV flow? You try to search 4firemandan ffv pump upgrade. I have a few of his posts saved as I modeled my system after his but didn't see any flow data.
    ViktorG and ARES35 like this.
  15. Dec 28, 2023 at 10:16 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Check out Kenne Bell's documentation, they don't recommend running the BAP on some Walbro pumps. Running the 267 at higher voltage leads to pump failure, they suggested upgrading the power wiring to dedicated wiring for the pump switched with a relay using the original fuel pump power wire as the trigger.
    They informed me of this after I inquired about getting one of their universal kits.
    https://kennebell.net/docs/fuel-pump-tech/
    https://kennebell.net/wp-content/uploads/2022/03/Fuel-Pump-Tech-1.pdf
    ARES35, Mdl and Saltyhero13 like this.
  16. Dec 28, 2023 at 10:50 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I wasn't suggesting using the boost a pump as that is like a band aide. Just that 4firemandan used the ffv pump for his system as they are looking for flow data.
    ARES35 and armyoffoo like this.
  17. Dec 28, 2023 at 2:05 PM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I used the stock FFV pump on my setup with 650cc injectors and the 80mm pulley and made 512 safely. No issues yet.
  18. Dec 28, 2023 at 2:35 PM
    ARES35
    Mile high
    Well shoot then. I'm not sure why some of these shops required that I upgraded the FFV pump before they would tune me. I'll just stick strictly to the forums for information from here on out tired of the run around.
  19. Dec 28, 2023 at 2:39 PM
    ARES35
    Mile high
    After touching base with @snivilous I've decided to scratch this worthless ass HP RTD/remote tuning and go MPVI 3. I'm not looking to break the stock block power record by no means. Just good usable power at elevation.
    Saltyhero13, Wynnded, Mdl and 3 others like this.
  20. Dec 28, 2023 at 2:56 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    What’s weird is if you search for a replacement FFV pump on RockAuto, autozone, etc. and then look at the flow specs, most are around 44gph which is about 165LPH (not gonna cut it). I have to assume those listed specs are just wrong?
    Mdl and ARES35 like this.
  21. Dec 28, 2023 at 3:10 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I have not flow tested a FFV pump because flex Tundras are not sold in Canada.
    However, someone did send me a FFV pump from their truck last year, so if I ever get time I could do it.
    Anecdotally, they are supposed to flow in the high 300 lph range iirc, for some reason number 375 is floating around my head.
    ssmokedz, e30cabrio, Wynnded and 9 others like this.
  22. Dec 28, 2023 at 4:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks @ViktorG for replying. I wasn't sure if you tested it or was in the data you sent me years ago! Haha time flies...
  23. Dec 28, 2023 at 8:09 PM
    ARES35
    Mile high
    Was fumbling around on HP tuners site and tried the upgrade option on the rebranded MPVI/RTD-3 Magnuson supplies, for the MPVI3. Does not work, magnusons got it on lock down real good. Not surprising but disappointing lol. MPVI-3 in route. Does anyone know if the MPVI-3 can read the base map from the RTD-3 tune? I'm going to assume thats a big no haha
    Mdl, reywcms and snivilous[OP] like this.
  24. Dec 28, 2023 at 8:51 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Probably not but it should generate a basic trd tune that will enable the ecu to be written to. I read in the past some had to contact hpt and they helped with a basic tune for your VIN.
  25. Dec 28, 2023 at 9:08 PM
    ARES35
    Mile high
    Thanks Mdl! I will need a basic tune to build from that's for sure. Especially with the stock RTD tune being locked out:facepalm:. It would be nice to see their mapping for informational purposes but it is what it is.
    Mdl[QUOTED] likes this.
  26. Dec 28, 2023 at 9:10 PM
    snivilous
    SW UT
    It will download a tune from the HPT servers based on your ECU ID, even if you flashed the tune from Magnuson it would still download the same file. I wouldn't be worried, it should be smooth since your truck isn't brand new.
  27. Dec 29, 2023 at 2:54 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  28. Dec 29, 2023 at 4:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Good stuff to keep our bases covered.
    Winks4x4Toy likes this.
  29. Dec 30, 2023 at 12:12 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Fuel rail possibility? This is a low pressure rail from the 2008 - 2014 IS-F 2UR-GSE 5.0L V8. All the other UR engines have stamped steel. Injector spacing is of course spot on. Mounting looks different from the stamped 3UR-FE rail, but shouldn’t be a problem to adapt. The fuel damper is the traditional style, and each rail receives its own, so two total for our V8. Left and right rails are the same casting, but have bosses machined for each side. Opening up the second boss on each rail will allow multiple feed locations and/or cross overs. Each rail also has an M14 bolt plugging the end. The ID of the rail is 11.75mm or .462”, which is a tad larger than common 8AN type rails. 7CA5EC71-387F-4D31-9762-746F106E4269.jpg E6BCB620-AB86-4D9A-A93F-47BD2F9DE2E3.jpg D7B6827D-D45C-42C7-9B59-DF842AD090EB.jpg
  30. Dec 30, 2023 at 12:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! Now I can try to have a true -8an supply other than Prospeed if it can be had for less$
    ARES35 likes this.
