Rear Diff maintenance?
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Oct 8, 2022.
  1. Oct 27, 2022 at 1:45 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I don't drive in deep water, but I did install an elevated breather that runs the check valve up to one of the bed stiffener rails!
    300BLK likes this.
  2. Oct 29, 2022 at 7:39 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Be sure to remove the fill plug first!
    Rob's Inferno, awq735[OP] and WILLINH like this.
  3. Oct 29, 2022 at 7:55 AM
    blanchard7684
    blanchard7684 New Member
    Toyota diff maintenance is so ridiculously easy it should be done for sport.
  4. Nov 23, 2023 at 3:00 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Can anyone confirm the direction of the aluminum crush washers for the differential bolts?
  5. Nov 23, 2023 at 6:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The top cone should technically be up against the head of the bolt but I've never seen it matter before
    Wallygator and bulldog93 like this.
  6. Nov 24, 2023 at 3:09 AM
    Spyker
    So the ‘curved’ portion of the gasket towards the diff?
  7. Nov 24, 2023 at 6:26 AM
    MadMaxCanon
    Narrow to bolt and wider to diff
    bulldog93 likes this.
  8. Nov 24, 2023 at 6:37 AM
    Markysharky
    Markysharky New Member
    Tundras tend to have the drain and fill plugs overly tight. So make sure you can break free the fill plug first. The Valvoline squeeze “bags” for gear oil are nice if you don’t have a gear oil pump to get all the fluid in the hole. The plastic containers are hard to get the last bit out. Also a dab of black rtv gasket maker on the threads of the drain and fill plug will ensure it won’t drip and leak for piece of mind.
    Jaypown and Wallygator like this.
  9. Nov 24, 2023 at 7:45 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The transfer case uses a 75w GL-4 oil. The only one I have found is Redline MT-LV.
    Wallygator likes this.
  10. Nov 24, 2023 at 9:03 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Its one of the easiest fluids to change on these trucks and its cheap. Just do it. If you're lifted its even easier. I just roll under on my creeper and can squeeze the Mobil1 bottles in without any trouble. No pumps or tubing needed.
  11. Dec 21, 2023 at 4:51 PM
    mpd13078
    mpd13078 New Member
    Alabama
    2017 Platinum Crewmax 4WD 5.7L
    Stock
  12. Dec 27, 2023 at 9:34 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Just pulled the rear diff plug and found 4 very thin shavings on the drain plug. Can easily bend them, not a stiff piece of metal. Anyone seen this on their drain plug before. Has zero noises and no driving issues at time of change. Truck has 42k miles.
  13. Dec 27, 2023 at 9:48 AM
    AZBoatHauler
    So.Arizona
    It’s been seen on here a few times. Machining debris and the magnet doing its job. Fill it and run it.
    https://www.tundras.com/threads/so-changed-my-diff-oil-and-saw-this.47569/
  14. Dec 27, 2023 at 10:00 AM
    RustyShackle323
    Stewart
    NC
    AZBoatHauler[QUOTED] likes this.
