Adding back up camera to OEM harness
Discussion in '2nd Gen Tundras (2007-2013)' started by Mbril, Dec 19, 2023.
  1. Dec 19, 2023 at 8:25 PM
    Mbril
    Mbril [OP] New Member
    I have a 2010 Base which did not come with JBL or Navigation.
    I am picking up an aftermarket radio with the hopes of hooking up a backup camera.
    My camper shell is a A.R.E walk-in, which means I do not have a tailgate for a handle camera, so I would probably go with a license plate attachment.
    I am curious if any camera will hook to the oem harness present underneath the bed and where would I find the other end behind the dash?
    Any help would be much appreciated!
  2. Dec 20, 2023 at 4:09 PM
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    I’ve only done a handful of backup camera installs, but typically you tap one of the lines going to your brake lights for power, and run the video cable up front to plug into the head unit.
  3. Dec 20, 2023 at 4:14 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    If you search the 2nd gen threads you will find your answer. It’s in here somewhere.
  4. Dec 20, 2023 at 7:39 PM
    Mbril
    Yes most of the install tutorial mentioning tapping in the harness for power. I was hoping to use the backup camera harness so I wouldn’t have to run anything under and inside the truck.
  5. Dec 20, 2023 at 10:40 PM
    Dalandshark
    Northwest
