Rebuilt 2005 GX470 Project - Back in CO!
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Dec 17, 2023 at 6:58 PM
    #301
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    Had to order a tag gun so I could connect the OEM seat heater to the bottom of the new leathers for the front seats.
    + $16
    Also got the GX sitting on wheels again. But still pending shipment of rear sway bar that's on backorder. It sits a little lower in the rear, and that's without the weight of the tailgate. Which is perfect. Because I thought the front was sitting a little high. So now I can lower the front. I was thinking about 275/70/17 which is 32.2" tires. I may even go one size lower, which is still bigger than stock.
  2. Dec 17, 2023 at 7:07 PM
    #302
    M3Tundra-JK
    Scott
    2005 GX470
  3. Dec 18, 2023 at 10:00 AM
    #303
    M3Tundra-JK
    Scott
    2005 GX470
    Researching a little last night and I think I'll be going with 265/70/17 tires, which equals 31.6". Stock tires are currently 265/65/17 or 30.6" Should fill out the wheel well nicely, especially after the suspension settles in.
    The 265/70's SL rated (46lbs) weight 10lbs less per tire than the 275/70s in Load C (57lbs) I was looking at. Quite the difference
    Brownsfanhere likes this.
  4. Dec 19, 2023 at 10:50 PM
    #304
    M3Tundra-JK
    Scott
    2005 GX470
    Been thinking about paint again, and I think I'm going to attempt to paint it myself. Inflatable paint booths are under $500, and spray gun kits around $600-900. Also found a site where I can order the new TRD colors, around $500 a gallon of pre-diluted paint of the higher quality paint. I still need to respray my M3 too, and then I can also throw some paint on my JK.
    https://everestautomotivemarket.com...yota-terra-cotta-3a7-en/?variation_id=1492146
    But I won't be doing any painting for quite some time. Likely over the summer.
  5. Dec 20, 2023 at 8:41 AM
    #305
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    Love the rebuild, it's looking good!
    M3Tundra-JK[OP] likes this.
  6. Dec 20, 2023 at 9:16 AM
    #306
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    So, GX+BMW+JK all in the same color?
    That's some team spirit right there.....j/k
  7. Dec 20, 2023 at 11:00 AM
    #307
    M3Tundra-JK
    Scott
    2005 GX470
    Lol that'd be something! Just drag them all in tow to a car show
  8. Dec 20, 2023 at 11:18 AM
    #308
    Ghost Rider
    Ian
    Cypress, Texas
    You might need more than just "a couple gallons" of paint for that project, just saying.....
  9. Dec 22, 2023 at 2:51 PM
    #309
    M3Tundra-JK
    Scott
    2005 GX470
    Another "milestone". A friend came by and helped get the tailgate back on. Huge relief that it closes correctly, flush with the body! I was a little worried because the damaged tailgate I removed was bowed out at the top left, so there was a considerable gap between the tailgate and roof. I wasn't sure if that was just the tailgate or also the body. Luckily it was just the tailgate! And the color is super close to mine, even though there two different color codes.
  10. Dec 23, 2023 at 12:44 AM
    #310
    M3Tundra-JK
    Scott
    2005 GX470
    I'm leaning towards the Lunar Rock (top middle) color. Paired with the black TRD wheels I have, and swap the chrome window trim for black.
  11. Dec 24, 2023 at 8:04 AM
    #311
    AKSig88
    AKSig88 New Member
    Ann Arbor, MI
    2023 SR5 Tundra
    Always was a fan of Lunar Rock, I think you're headed in the right direction!
  12. Dec 25, 2023 at 5:47 AM
    #312
    hoof hearted
    hoof hearted New Member
    2018 Sequoia Limited 4WD
    You could be the first solar octane GX…
  13. Dec 27, 2023 at 7:47 PM
    #313
    M3Tundra-JK
    Scott
    2005 GX470
    Working nights now, so I spent a day last week insulating the garage a bit. Instantly made a difference of almost 10 degrees warmer. And now my garage heater actually feels like it's working, instead of all the heat escaping upward.
    5 rolls at $50 each
    + $250
  14. Dec 28, 2023 at 7:56 PM
    #314
    M3Tundra-JK
    Scott
    2005 GX470
    Working on the front seats. Got one of the four seat heaters swapped over. Hoping to have the front seats done over the weekend.
  15. Dec 28, 2023 at 8:51 PM
    #315
    M3Tundra-JK
    Scott
    2005 GX470
  16. Dec 29, 2023 at 2:32 AM
    #316
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Nice,,, looks and sounds like you have been busy.
  17. Dec 29, 2023 at 6:09 AM
    #317
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Nice work, I hate working on interiors. lol
  18. Dec 29, 2023 at 9:56 PM
    #318
    M3Tundra-JK
    Scott
    2005 GX470
    Getting it done little bit by bit
  19. Dec 29, 2023 at 10:05 PM
    #319
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Looking good.
  20. Jan 1, 2024 at 12:09 AM
    #320
    M3Tundra-JK
    Scott
    2005 GX470
    Happy new year!
    Replaced the hood struts due to risk of being decapitated...
    + $30
  21. Jan 1, 2024 at 12:12 AM
    #321
    M3Tundra-JK
    Scott
    2005 GX470
    Had to remove some interior parts in order to reconnect the rear wiper fluid line being disconnected. Found that out when I did a test spray and it went all over the cargo floor lol
  22. Jan 9, 2024 at 10:38 PM
    #322
    M3Tundra-JK
    Scott
    2005 GX470
    I threw out the cabin air filter with the sub assembly that it goes in a while back. Finally ordered a new one from Lexus that came with the filter and assembly.
    + $30
    I had ordered a filter from Amazon but when it arrived, it was just the filter. That's when I realized my mistake, but the trash had already been taken out by then
    Fobroader likes this.
  23. Jan 9, 2024 at 10:42 PM
    #323
    M3Tundra-JK
    Scott
    2005 GX470
    And a side note. My new job sucks! I mean, it pays well for what it is but 12 hrs night shift can kick rocks. And its almost a step backwards career wise for me. I have a third interview on Thursday for a Senior Data Center Engineer role. Really hope I get it. It's more like my previous role in that project work will be a big aspect of the job.
    Current job pays less that what I made 6 years ago...New role would be more than I was making at the end of my last gig.
  24. Jan 10, 2024 at 6:10 AM
    #324
    Are you on 3 or 4 12’s?
    How are benefits in comparison to your other job you’re interviewing for?
  25. Jan 10, 2024 at 6:16 AM
    #325
    M3Tundra-JK
    Scott
    2005 GX470
    Shifts alternate between 3 and 4 days. Benefits are slightly better at place I'm interviewing. But new place is also higher up the CO best places to work list.
  26. Jan 10, 2024 at 7:45 AM
    #326
    Gotcha. Just keep benefits, cost of said benefits, commute, and stress in mind.
  27. Jan 10, 2024 at 8:12 AM
    #327
    koditten
    Kirk
    Midland of the Mitten
    I just found this thread!
    I always wondered where other people like me that like to put wrecks together were. Now I know.
    I hope I'm not poaching on your thread, but here is my present project.
    https://youtu.be/iGXLMCHGw0E?si=rGySJh_187QIZ-aT
    Please tell me to get lost if this was inappropriate.
    Thanks
    Kirk
    Mdl, e30cabrio and M3Tundra-JK[OP] like this.
  28. Jan 10, 2024 at 3:38 PM
    #328
    M3Tundra-JK
    Scott
    2005 GX470
    Nice! I kinda wish I had repaired my wrecked Tundra myself, but that was just a huge headache of dealing with insurance that I wanted it gone.
  29. Jan 12, 2024 at 10:39 AM
    #329
    M3Tundra-JK
    Scott
    2005 GX470
    It's supposed to be 0 degrees when I go into work on Sunday night. And the jeep heater only works on the passenger side. In the middle of replacing the blend door on it. So gonna drive the GX instead. Just dropped it off to have the alignment done.
  30. Jan 12, 2024 at 2:42 PM
    #330
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Good luck on the inaugural journey!
    M3Tundra-JK[OP] and e30cabrio like this.
