Help needed :2016 Tundra would not start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Winloz, Jan 20, 2019.
  1. Jan 20, 2019 at 2:45 PM
    Winloz
    Winloz [OP] New Member
    Good day All. I have a 2016 Toyota Tundra extended cabin. A week ago I parked it after arriving from work. The following morning it would not start. The engine turns when you turn the key to “start.” It was then towed to the dealership. After diagnosing it they said that they were getting a code P0230 and the problem was the fuel pump. They replaced it. Several days later, they said the pump did not resolve the issue and were still getting the same code, which according to them meant the vehicle’s wire harness had to be replaced. I inquired as to repairing the faulty harness to which they replied that they did not do repairs on it. The cost will be $6000. This charge is not covered by the insurance or warranty. It truly seems that this dealership does not know what the problem is with my truck and are simply guessing. Needless to say I can’t afford another $6000.00 gamble and had to tow the truck back to my house. I am now paying a car loan for a truck that is sitting in my driveway. I too had to borrow a vehicle to get to work. If anyone can help, I have good knowledge of automobile electrical and can follow diagnostic manuals. I need to find the the electrical component locations, plug connector number locations, and diagnostic troubleshooting?
    Any other ideas will also be appreciated.
    My email address is: winsortlozano@gmail.com
    Thank you
    Winsor
    WrigglingWilly likes this.
  2. Jan 20, 2019 at 2:52 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Sorry to hear this! Did you get it new or used? What part of the country do you live in?
  3. Jan 20, 2019 at 2:53 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Man that really sucks.. hope you get it all figured out though. I know the feeling.
    I had a Volkswagen GTI and the motor blew and wasn’t covered. I was paying a “auto” loan for a giant paper weight for around 7 months before I could shell out 5 grand for it to be rebuilt.
  4. Jan 20, 2019 at 2:57 PM
    WrigglingWilly
    LineX
    Rodents love Toyota wires. Maybe you can find a disconnected bit, and fix it on the cheap.
    driverdog, TheBeast and 15whtrd like this.
  5. Jan 20, 2019 at 3:00 PM
    15whtrd
    15whtrd Mr. Blonde
    Do you have another key that you can try? I’m willing to bet there is probably a chewed wire somewhere. Sometimes even a battery can cause all sorts of issues.
  6. Jan 20, 2019 at 3:02 PM
    WrigglingWilly
    LineX
    All it would take is a poorly installed radio, or Woofer, and bam, issues
    driverdog and 15whtrd[QUOTED] like this.
  7. Jan 20, 2019 at 3:03 PM
    TheBeast
    TheBeast The Beach
    check for signs of rodents under the hood
    WrigglingWilly and driverdog like this.
  8. Jan 20, 2019 at 3:04 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I agree with the rodent theory.
  9. Jan 20, 2019 at 3:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Right!? I’ve heard of a bad tail light causing the truck to go into limp mode.
  10. Jan 20, 2019 at 3:06 PM
    WrigglingWilly
    LineX
    It was Coloniel Muskrat in The Garage with the candlestick...
  11. Jan 20, 2019 at 3:23 PM
    WrigglingWilly
    LineX
    Body shops are great at that stuff. They tend to get to see and get familiar with what is "under the skin"
    driverdog likes this.
  12. Jan 20, 2019 at 3:38 PM
    15whtrd
    15whtrd Mr. Blonde
    This. Any and all mods as well as anything that has been touched.
  13. Jan 20, 2019 at 3:39 PM
    WrigglingWilly
    LineX
    Ya know what? Start taking and posting pictures of your engine bay, undercarraige, and whatnot. Somebody on this forum may see something out of whack that others would miss.
    15whtrd and driverdog like this.
  14. Jan 20, 2019 at 3:41 PM
    Winloz
    Wriggling, I got it about a year ago from the used trucks at the same dealership in Lake City, Florida.
    As for the rodent theory, I am going to rig something so I can lift the truck on some ramps to be able to get under it and try to “follow” the harness going to the fuel pump. I am also going to do the same inside the engine compartment. If I can find wire insulation eaten or missing along the way, it shouldn’t be to hard to miss. Thank you for your posts.
    WrigglingWilly, driverdog and 15whtrd like this.
  15. Jan 20, 2019 at 3:44 PM
    Winloz
    I’ll take some pictures and post tomorrow. Thanks again
  16. Jan 20, 2019 at 3:49 PM
    A blown reverse light fuse will cause a partial limp mode. Happened to me. Engine still ran normally and no shift mode. I'd try a different dealer. The rodent theory is certainly a possibility.
  17. Jan 20, 2019 at 3:58 PM
    It can be a million things at this point.
    Do you hear the fuel pump turning on and off with the key?
    TheBeast likes this.
  18. Jan 20, 2019 at 3:59 PM
    Command the fuel pump on and off by using a scan tool or simply turning the ignition key on and off without starting the engine. If the fuel pump activates and deactivates, then start the vehicle and measure the current on the control (ground) circuit for a couple of minutes. It should be less than an amp and stay less than an amp. If it doesn't then replacing the relay is a good idea at this point. If the fuel pump won't activate and deactivate, then remove the relay and visually check for discoloration due to heat or loose terminals. If okay, install a test light between the control circuit ignition feed and ground driver terminals (If you're not sure, don't attempt). The test light should illuminate when the key is on or the fuel pump is commanded on. If it doesn't, then make sure there is voltage on one side of the coil (switched ignition feed). If voltage is present repair the open or short on the control ground circuit.
  19. Jan 20, 2019 at 4:08 PM
    koditten
    Kirk
    Midland of the Mitten
    Sounds like an immobilizer issue.
    Is the little "key" icon on the dash flashing? If the key is not communicating with the immobilizer ECU, you get no start.
    Engine will turnover great, but won't start.
    A different key may solve the issue.
  20. Jan 20, 2019 at 4:58 PM
    TheBeast
    TheBeast The Beach
    lift the engine cover/foam. sometimes rodents go underneath and you will find traces
  21. Jan 20, 2019 at 10:24 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    I'll second this for same issue.
  22. Jan 20, 2019 at 11:00 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Tell more about the tundra. Gas or FFV? How old is the battery? Did you check fuse or relay?
  23. Jan 20, 2019 at 11:23 PM
    kgb4187
    kgb4187 New Member
    Check under the carpets and everything to see if there's any indication it was in a flood.
  24. Jan 21, 2019 at 2:38 AM
    blanchard7684
    blanchard7684 New Member
    p230 is a fuel pump circuit malf.
    So anything in that circuit from pump to ECU can cause it.
    pump relay
    pump assembly (ruled out)
    wiring issue
    This is not a $6000 problem.
    equin likes this.
  25. Feb 17, 2019 at 9:50 AM
    Punisher17
    Punisher17 New Member
    I'm having a similar issue but with mine I insert key and turn and hear only a click and have to take key out several times until I can get it to start. Any help appreciated.
    I have a feeling something with the immobilizer. I have a 2nd gen but I assume the same system is used on 3rd gens. I've had the problem since I've owned it. I had a new key made and they actually had to recode the computer and keys over because they couldn't get the new one to set with the original keys.
  26. Feb 17, 2019 at 10:38 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    There is also a fuel pump control module mounted in the frame rail beside the fuel tank. I haven’t looked to see if it could be a cause of your fault code, but I’d look into it.
  27. Dec 18, 2023 at 2:31 PM
    Blaine.352
    Blaine.352 New Member
    Anthony
    2016 SR5 Silver Tundra TRD
    Leveling kit
    I also have a 2016 Toyota tundra. I was rewriting a wiring harness to led lights and now I’m not getting any power to the fuel pump control module. It’s reading 0.1-0.3 volts when I go to crank at the fuel pump module. I’ve checked all the fuses and relays there good and I’ve tried to do an ecu reset and everything. I disconnected the wires from the fuel pump control module. What should I test next?
  28. Dec 19, 2023 at 8:13 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've seen this problem before. The tech sees the code and replaces the fuel pump and still has the issue. An assumption was made because there is no fuel pressure. The pump seldom fails on the non fuel flex Tundras. The problem is likely a bad connection between the fuel pump module and the fuel pump. There is a short two wire harness that runs from the module to the pump and the issue is usually at the connectors. It's very easy to test. Go back to the dealer and have them fix it no charge. They guessed at the pump and obviously it wasn't the issue. Have them test for power and ground at the fuel pump module then at the fuel pump.
