General Supercharger Thread
  1. Dec 14, 2023 at 11:13 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Mdl and Saltyhero13 like this.
  2. Dec 14, 2023 at 11:38 AM
    blenton
    blenton New Member
    Why, hello there. It’s my pleasure to make your acquaintance.
  3. Dec 14, 2023 at 11:44 AM
    blenton
    blenton New Member
    Just read through the install manual - they recommend inspecting and replacing spark plugs every 10k miles. Anybody doing that? That seems a little excessive...
    Black@Blue19 likes this.
  4. Dec 14, 2023 at 11:45 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Way cool!!! Going to watch this one!!! Best of luck!!:)
    blenton[QUOTED] likes this.
  5. Dec 14, 2023 at 11:48 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    That DT dyno is from back in 2008 or 2009… I don’t think there was much in the way of tuning available back then. Just the TRD Supercharger flash at the dealer… anyone else remember?
  6. Dec 14, 2023 at 12:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can pnly comment that VFTuner wasn't available then. What about BullyDog?
  7. Dec 14, 2023 at 12:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No
  8. Dec 14, 2023 at 12:03 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Check the parts bags make sure everything’s there according to the install manual. We had a missing fitting on the old man’s according to the shop.
    Not sure if that’s true or not but doesn’t hurt to confirm before the install. I didn’t have any issues on parts outside of making certain items work with my trucks setup. I’ll send your pulley out tomorrow!
    HulkSmurf14 likes this.
  9. Dec 14, 2023 at 12:03 PM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Awesome thanks! Yeah I assume my bearings are fine as only have about 30K on my non supercharged *yet* truck. I purchased shims from nitro and I'm not re gearing at this time since all I have are 33" tires. I sourced a new gasket for the diff and will fab up some angle iron to mount the diff to while I torque down everything and check backlash before I stab it back in. Or that's the thought process.
    Mdl and Fastlane47[QUOTED] like this.
  10. Dec 14, 2023 at 12:22 PM
    blenton
    blenton New Member
    Bullydog was 2015 IIRC, but 99% sure it wasn’t before 2013.
    Thanks! Will do - I barely had time to rip open the blower and make sure it was there before I had to head out again.
  11. Dec 14, 2023 at 12:25 PM
    blenton
    blenton New Member
    When I helped a buddy install my Auburn at 80k mikes, he was able to reuse the original bearings AND shims. He said they sometimes have issues getting the bearings off the old carrier, but mine looked almost new at 80k. I was surprised. He was almost as surprised that the original shims worked correctly for setup. That was almost 120k miles ago and no issues.
    When I get the Grip pro installed, I will prolly replace the bearings just because.
    Fastlane47 and jhrrld[QUOTED] like this.
  12. Dec 14, 2023 at 1:02 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    no
    I'm 50k miles.
    Mdl and Silver17 like this.
  13. Dec 14, 2023 at 1:45 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Damn you got 50k on the Harrop already? I’m curious who has the most miles on their Harrop, as they’ve been out the 2nd longest. Knock on wood it’s the only brand I’ve not seen a reported failed coupler on yet. Im curious if the coupler change is as easy as I think it should be.
    Mdl and reywcms like this.
  14. Dec 14, 2023 at 2:16 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I have 30k on mine too, but they are press on bearings.
    jhrrld[QUOTED] and Mdl like this.
  15. Dec 14, 2023 at 2:57 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    86k miles on truck, I installed it at 25k miles
    Mdl and Silver17[QUOTED] like this.
  16. Dec 14, 2023 at 5:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @blenton Bullydog GT came out in Sept 2013.
    Saltyhero13, Wynnded and blenton like this.
  17. Dec 14, 2023 at 8:31 PM
    AZTundra
    Paul
    Phoenix, AZ
    1UP, Winks4x4Toy, Wynnded and 6 others like this.
  18. Dec 14, 2023 at 9:04 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Nice! Add it to the list. Even adding a shorter belt with that heavier spring and arm is good peace of mind.
    Winks4x4Toy, Mdl and M3Tundra-JK like this.
  19. Dec 14, 2023 at 9:09 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    HulkSmurf14, snivilous[OP] and Mdl like this.
  20. Dec 14, 2023 at 11:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I re-used my bearings at 60k. I got 110k on them now with the Auburn. Although Auburn didn't last...bearings still going strong!
  21. Dec 15, 2023 at 4:58 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    I have a tool to remove them, planning on reusing those, I thought you were talking about replacing the wheel bearings on the axle itself. Cary on!
    Fastlane47[QUOTED] and Mdl like this.
  22. Dec 15, 2023 at 12:26 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Needing some help with installing AEM Wideband gauge on Cravenspeed mount. Did the plastic bezel around the gauge have to be modified? Seems like it has to be modified. Any insight would be great.
    ARES35 likes this.
  23. Dec 15, 2023 at 12:29 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    no.
    just the gauge pod is moved back with some washer type spacers
  24. Dec 15, 2023 at 12:40 PM
    Grenades4Bacon
    Grenades4Bacon New Member
    2019 Tundra
    No, but I thought about it too. I didn't like how the gauges sat so close. I'm now playing with this setup, and will probably glam it up with hiding the threaded bolts behind some sort of black sleeve. Or just paint it.
    [​IMG][​IMG]
  25. Dec 15, 2023 at 12:51 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Good deal. How did the gauge itself mount to the inside of the pod? I may be missing something easy
  26. Dec 15, 2023 at 12:55 PM
    Grenades4Bacon
    2019 Tundra
    I haven't gotten that far yet, as of now they're just sitting in there... but, it's a tight enough fit that they stay. I'm not really sure how I'm going to secure them in there. Part of me is thinking glue, or make-up some mechanical clamp using the studs in the back.
    nchlsbr[QUOTED] likes this.
  27. Dec 15, 2023 at 1:06 PM
    Silver17
    Eastern PA
    Just get yourself some nylon spacers. I don’t remember where I got these, or if I also needed longer bolts with them but it did the trick.
  28. Dec 15, 2023 at 1:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Most hardware stores have the spacers in the specialty fastener area.
  29. Dec 15, 2023 at 1:17 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I didn’t mod mine and they’ve held fine. Just added spacers like mentioned
  30. Dec 15, 2023 at 1:19 PM
    Grenades4Bacon
    2019 Tundra
    Yeah, couldn't find any at my store for whatever reason. anyhow, these are good ideas. was also thinking about 3d printing some. That would also allow for some extra strength/stability to be added.
    nchlsbr and Mdl[QUOTED] like this.
