22 Platinum..awful knocking noise when hitting bumps
Discussion in '3rd Gen Tundras (2022+)' started by Crableg85, Jul 12, 2022.
  1. Nov 19, 2022 at 11:44 AM
    Casshed
    Casshed New Member
    I have a 22 Tundra Limited with the off road package, no air suspension and I hear a knocking noise from the rear passenger area as well. Dealership blamed it on the truck cover so I took it off but still have the noise. Didn’t start until about 5000 miles in and seems to have progressively got worse. It almost sounds like it’s coming from the b pillar or maybe even the ceiling. I do have the panoramic sunroof, you can hear it the most in the driver seat. Only happens when going over bumps at slow speeds, varies from a rattle to a slow knocking noise when going over speed bumps. Tailgate and truck bed can get some rattling noise but this is definitely in the interior as I hear different noises from the truck bed while driving with the rear window down. Is this similar to the knocking noise people are describing here? I’m about to trade the truck in at this point given all these issues I’ve had.
    Tundrastruck91 likes this.
  2. Nov 19, 2022 at 2:45 PM
    Fido96
    Fido96 New Member
    22 Platinum
    Still have the same sound. I have the auto side steps. They seem secure but I noticed the other day when it was folding in it made a slightly similar sound. I’m going to spend some time focusing on that over the holiday.
  3. Nov 19, 2022 at 3:53 PM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    Does it sound like this?
    limited Iforce max no air suspension build mid June.
    Dealership gave me the same BS couldn’t replicate the noise even though I gave them a usb with like 20 videos, my guess is the cab mounts but they wouldn’t even check them, I have a deposit on a 2023 limited to trade this one in.
    https://youtube.com/shorts/iBo_PwrS5xM?feature=share
  4. Jun 1, 2023 at 11:55 AM
    CBiscuit
    CBiscuit New Member
    Anyone come up with what the actual source is for this noise? Or a solution?
  5. Jun 1, 2023 at 12:25 PM
    swageit
    swageit New Member
    Mark
    2018 Tundra Limited Double Cab
    It’s the upper rear hydraulic cab mount.
  6. Jun 1, 2023 at 12:39 PM
    CBiscuit
    CBiscuit New Member
    Are they faulty or just a bad design? Any known fixes?
  7. Jun 1, 2023 at 12:53 PM
    swageit
    swageit New Member
    Mark
    Not sure. I now have a second one that went bad.
  8. Jun 1, 2023 at 8:20 PM
    Tundrafarm
    I replaced both upper and lower hydraulic mounts on both sides on mine, I can definitely say that the rear driver side noise is gone but the passenger rear side came back after 3 days.
    After complaining to the dealership 3 times they said is normal noise for trucks, it is not normal but there’s little to no help from the dealership or corporate opening a case 3 times got me no where since corporate believes more on what the dealership tells them.
  9. Jun 2, 2023 at 5:07 AM
    Supertech1
    Supertech1 New Member
    Could the non-hydraulic mounts be used as a replacement? If so, what’s the performance difference?
    My ‘22 SR5 was very quiet over low speed bumps. ‘23 TRD Pro was initially, but developed a clunk over same bumps. I’ve been thinking it was tailgate, but ruled that out.
  10. Jun 2, 2023 at 6:47 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    my truck does this as well, dealership says its normal or one of my "aftermarket" parts
  11. Jun 2, 2023 at 8:25 AM
    Tundrafarm
    that’s what I’m planning to do next when I get some free time to do it, I’ll report back when it’s done.
  12. Jun 3, 2023 at 1:47 AM
    chastings1954
    chastings1954 New Member
    charles
    capstone
    I had the same noise on my 20 Tacoma Pro. Drives me nuts. After all was said and done, I found the front pass side bed bolt to frame was letting the bed flex up and down. It's a shoulder bolt that was tight but had slack that caused the noise. I put a shim in and tightened down and have been a happy camper ever since. I found the slack by picking up on the bed corner by hand and could see it move an 1/8 or so.
    graf_von_tundra likes this.
  13. Dec 14, 2023 at 9:08 AM
    aleayala18
    aleayala18 New Member
    Alejandro
    2024 PLATINUM TUNDRA
    275/65R20 BF GOODRICH ALL TERRAINS
    Did anyone solve this? Im having the Exact same issue and have no idea where the knocking is coming from. Any help would be appreciated.
