Vent window pivot arms...??
Discussion in '1st Gen Tundras (2000-2006)' started by AWilliams, Dec 12, 2023.
  1. Dec 12, 2023 at 1:18 PM
    AWilliams
    AWilliams [OP] New Member
    Got some replacement vent window arms for my 03 AC. from Scamazon. Had to drill them out, no biggie, but I noticed they don't snug up against the rubber gasket real tight. When you start to close it, it snugs up good then as you lock it down it backs off about 1/8" creating a small gap. If it keeps the rain out and doesn't whistle, it's cool with me. Haven't driven it yet since the swap. Is that normal? They were cheap enough if I need to get different ones that actually compress the rubber gasket I'll get them. Thanks
  2. Dec 12, 2023 at 1:24 PM
    Post pics so we can see if you mounted them correctly. They should look like this…
  3. Dec 12, 2023 at 1:27 PM
    AWilliams
    I did...otherwise they wouldn't close...I know this because I DID flip the first one around and would not come close to closing. I'm only talking about less than 1/8" gap glass to gasket. I think I remember seeing a post here about it that they would sometimes do this when were replaced.
    Jack McCarthy likes this.
  4. Dec 12, 2023 at 1:30 PM
    I’m not sure what to tell you. I didn’t have any issues with mine. Although I didn’t have to drill them out; just used a pin punch to get them in there.
  5. Dec 12, 2023 at 1:31 PM
    AWilliams
    They work...don't get me wrong...just doesn't smush the glass tight like OEM.
    FirstGenVol likes this.
  6. Dec 12, 2023 at 1:32 PM
    coTony
    Tony
    Montrose, CO
    On my first Tundra was a 1st Gen and had the hinge problem. When I got the replacements my issue was the same as yours. The more I looked at things I seen the rubber gasket was pretty worn out so I replaced them and it closed just fine. Just what I went through
    AWilliams[OP] likes this.
  7. Dec 12, 2023 at 1:35 PM
    AWilliams
    @Jack McCarthy ...per your pic, is that the ridge I'm seeing on the right side? I noticed one side had a definative ridge when the OEM did not.
  8. Dec 12, 2023 at 1:46 PM
    Ridge is on the back side of the flat spot you see below…
  9. Dec 12, 2023 at 1:54 PM
    AWilliams
    Checking when I get home...thx
  10. Dec 12, 2023 at 2:35 PM
    Too funny. I just ordered OEM replacement latches (the whole assembly) today because I'm a fucking idiot, and bought the silver ones off scAmazon when there was nothing wrong with my old ones, and this was the end result.
    It was possibly one of the stupidest things I've done on my truck. The ones off scAmazon were identical to OEM as you can see. I assumed they would be some kind of upgrade, a "wind noise fix" like I've bought for some of my GM trucks in the past. They offered nothing meaningful except pain.
    Here's an info dump on the parts if you ever choose to refresh your latches, but always check your part numbers at EPC-DATA or Amayama before ordering.
    I'm still kicking myself over this, and probably will be indefinitely. My only saving grace is, I've been wanting to pull my rear door panels off to grease latches, tape down a couple of wires, and sound deaden a few more things. Now I'll get to do just that.
  11. Dec 12, 2023 at 2:40 PM
    AWilliams
    I remember seeing your post on this...I was so careful tapping them out. I used some penetration lube, gave it a minute and got them out no problem...both of mine broke so I decide to replace. Any comment on them not squishing all the way down when locked in place? Thx
  12. Dec 12, 2023 at 2:58 PM
    I did notice they don't leave a gap, but don't seem to engage as much as the old ones. Bill was on to something above with regard to orientation. The pic of my broken one shows the way it should go. But mine may be different from yours if you don't have the spine on one side and ridge on the other. I stacked mine on top of the OEM one, and the footprint/shape was identical. The hole was slightly smaller tolerance on the silver scAmazon model.
    And yeah, The tension pin on my driver's side one was being stubborn as hell, and no amount of lube was helping. Tried squeezing while pushing, squeezing while tapping, just total no-go for me. But my scAmazon kit didn't come with new pins, I had to re-use OEM which may've been the issue.
    AWilliams[QUOTED][OP] likes this.
  13. Dec 12, 2023 at 3:53 PM
    AWilliams
    Looks right to me ..
  14. Dec 12, 2023 at 4:29 PM
    That looks right to me.
  15. Dec 12, 2023 at 4:41 PM
    AWilliams
    Thx guys... I'll drive it and wash it to see if it whistles or leaks.
  16. Dec 12, 2023 at 4:46 PM
    FWIW, even with my barely used factory arms, with it fully closed, I can still pull/push the window in a solid half inch or so.
  17. Dec 13, 2023 at 5:59 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Can you simply bend the longer metal bracket (that's bolted to the door) a little bit in order for the latch to suck closer to the rubber?
    BroHon and JakeJake like this.
  18. Dec 14, 2023 at 5:42 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I am going back to OEM
  19. Dec 14, 2023 at 11:24 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I had a whistle, took the inner panel off, and the window, bent them back where they belonged, problem solved. 30min job.
    whodatschrome[QUOTED] likes this.
  20. Dec 14, 2023 at 12:46 PM
    AWilliams
  21. Dec 14, 2023 at 12:48 PM
    He once owned a whistle. He took the inner panel off with a whistle, and the window bent back to where it belonged, problem solved. 30 man job. :anonymous:
    Evil666Joe likes this.
  22. Dec 14, 2023 at 12:50 PM
    AWilliams
    I understood that...my comment was more of "mind blown...you've got my attention...I'm listening..is there more?"...lol
    My odd sense of humor is one of my many gifts to this community ..lol
  23. Dec 14, 2023 at 12:51 PM
    Nah, I was feeling left a bit hanging myself, hence my basically gibberish response.
  24. Dec 14, 2023 at 12:59 PM
    AWilliams
  25. Dec 14, 2023 at 3:56 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :rofl: :poking:
    I took a dead blow hammer to where the window hinges mount. Don't remember exactly which direction I went.
    Take a close look at how it seats, you will figure it out. My question was always how the heck did that get bent w/o breaking the window...
    edit: I'm pretty sure it was OUT, because the hinge side was clamping down so tight the latch side couldn't make contact with the window seal. Hahaha, my original post was pretty void of usable info... whoooops :bananadead::facepalm:
    whodatschrome and shifty` like this.
  26. Dec 14, 2023 at 4:20 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    When you do SO much shit to your truck... you start to forget wtf you did, how, and why sometimes.
    I do remember hammering much harder than I wanted to though.
    Get inside with a light and really study how its currently seating, like is it Super tight (seal smushed) in any area?
  27. Dec 14, 2023 at 4:34 PM
    AWilliams
    Thanks for the pic and description...when I close the latch glass it just barely makes contact with the glass. The OEM seemed to make much more contact/tension. I'll look into it
