General Supercharger Thread
  1. Dec 10, 2023 at 3:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No MAP sensor so not sure where the boost psi is coming from and yes the stock O2's only read the lowest to 12.1 to 11.9.
  2. Dec 10, 2023 at 3:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol I’ll be over here on dirty sevens
    Mdl and HulkSmurf14 like this.
  3. Dec 10, 2023 at 3:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    thats calculated definitely wouldn’t say that’s accurate.
  4. Dec 11, 2023 at 7:14 AM
    nags
    nags New Member
    XAT Pulleys and RR Crank Damper going in today. :militarypress:
    ADCreHf249F-N5e5XuZoI8oglazX-DMccyMULQer_32a722da03c54013a1af6ebab6c7ea2dffdf8eb9.jpg
  5. Dec 11, 2023 at 10:05 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I asked radium about the newer pcv cans not collecting much, and they said to pull the hoses off and see if there is oil in the one going to the can and/or the one going back to the engine. Anyone want to be the guinea pig?
    Mdl and Saltyhero13 like this.
  6. Dec 11, 2023 at 10:46 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio for your Aquamist W/M and anyone using a Innovate PSB1 gauge that requires a MAP boost signal. Off of the mechanical to digital MAP sensor wires you can tap into the white wire for a reference signal.
    e30cabrio and ARES35 like this.
  7. Dec 11, 2023 at 10:46 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    I've already done it. There was no schmoo in the can but plenty of it in both hoses. Then I went a step further and disassembled it entirely, to figure out why.
  8. Dec 11, 2023 at 10:54 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You would think the pressure would be enough even for those that have them mounted lower than the pcv valve.
  9. Dec 11, 2023 at 11:06 AM
    PolishedTRD
    CO
    The working principle behind the catch can is that the gasses are drawn from a place of high pressure to low pressure, with a chamber for the condensate to fall out of suspension and accumulate. If the can doesn't have a proper passage for the gasses to cool and accumulate, they'll continue on through the intake, and collect on all the plumbing.
    Saltyhero13 likes this.
  10. Dec 11, 2023 at 11:09 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    so...Gold wrap all catch can piping.
    Winks4x4Toy and Wynnded like this.
  11. Dec 11, 2023 at 11:16 AM
    PolishedTRD
    CO
    I'm no reywcms, but it couldn't hurt...
  12. Dec 11, 2023 at 11:29 AM
    nags
    nags New Member
    Random, but if anyone comes across a set of front seats for a good price.. Let me know.
    reywcms likes this.
  13. Dec 11, 2023 at 12:36 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Machinist said he shipped out the pulleys! I put them live on the website if you guys care to order, but I won't be home until next Monday and can then ship them out that Tuesday.
    And again, keep in mind these are very much prototypes so may not work, I also haven't looked at if/how much smaller belt is needed. If there's an issue I'll gladly refund them.
    https://www.snivspeedshop.com/product/tundra-magnuson-2650-pulleys
  14. Dec 11, 2023 at 12:52 PM
    helidave
    flagstaff
    2015 DC 4x4
    Radium's response to the oil bypassing the can:
    With these trucks having aftermarket superchargers, the air speed is accelerated and may not be allowing the air to slow down enough in the can to condensate and separate. As a next test, you can unscrew the bolt holding the baffle plate on and remove the fluid lock ball from the catch can, then reinstall the baffle plate. Run the truck for a while in that configuration and see if this changes how it operates. This may allow the air speed to slow more and allow the can to function.
    Winks4x4Toy, Saltyhero13, Mdl and 2 others like this.
  15. Dec 11, 2023 at 1:02 PM
    PolishedTRD
    CO
    Thanks for reaching out to them and sharing this! I still argue that regardless of the supercharger, there should have been SOME catch in the can. But for some of us to go 10K miles and nothing, just highlights a poor redesign.
    I've been running it without the baffle/fluid lock ball/plug for a few thousand miles now and it works-ish. I'm working on a modification to fix it for good and will share once I can confirm that it works.
  16. Dec 11, 2023 at 1:09 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You can put one of those cheapo fuel filters inline on the return side to see if anything is getting by. Replace it if/when it gets too dirty.
    PolishedTRD likes this.
  17. Dec 11, 2023 at 1:13 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Gotta have the woah with the go.
  18. Dec 11, 2023 at 1:38 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Taking a stroll down memory lane...here is a picture of the catch can on my 2012 Tacoma with the fuel filter on the return side (replaced every oil change), and the amount of oil it caught between oil changes. This is before installing the supercharger, on a V6.
  19. Dec 11, 2023 at 1:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I like how all your fancy new truck parts are put on display in the kitchen.
  20. Dec 11, 2023 at 1:57 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Best place for it lol
  21. Dec 11, 2023 at 1:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    At least they are clean for the Mrs... it's better than a dirty plunger. Ha
  22. Dec 11, 2023 at 2:11 PM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Rey you gotta connection on the Alcons....really thinking about running them but the cost is crzy
  23. Dec 11, 2023 at 2:22 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No connection unfortunately. The price increased from when we ordered the old man’s also which is annoying.
    Winks4x4Toy likes this.
  24. Dec 11, 2023 at 2:29 PM
    nags
    nags New Member
  25. Dec 11, 2023 at 2:43 PM
    AZTundra
    Paul
    Phoenix, AZ
    Now would be a great time to send off for powdercoat.
    Winks4x4Toy and reywcms[QUOTED] like this.
  26. Dec 11, 2023 at 2:51 PM
    ARES35
    ARES35 New member for life
    Mile high
    Great news on it now sir! :spending::burnrubber:
    snivilous[QUOTED][OP] likes this.
  27. Dec 11, 2023 at 2:58 PM
    helidave
    flagstaff
    2015 DC 4x4
    Keep us updated. I'm going to install mine without the ball right off the bat.
    Mdl and PolishedTRD[QUOTED] like this.
  28. Dec 11, 2023 at 3:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Did that require a belt size change?
    Mdl, nags[QUOTED] and Saltyhero13 like this.
  29. Dec 11, 2023 at 3:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nope stock diameter
    Black@Blue19, Mdl and Wynnded[QUOTED] like this.
  30. Dec 11, 2023 at 3:10 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    "Hunny, thanks for the new plates!"
    "Uhh....."
    Mdl and reywcms like this.
