  1. Dec 9, 2023 at 7:04 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I had sourced mine from @831Tun. Hit him up!
    These are the parts that I got to piece it together. Exactly same setup as @reywcms
    bulldog93 likes this.
  2. Dec 9, 2023 at 7:24 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Thank you! I have the rest in a cart, I just couldn't find that final part. I'll message him now.
  3. Dec 9, 2023 at 9:29 AM
    a_double
    a_double New Member
    Where did you end up routing the power cable?
  4. Dec 9, 2023 at 10:32 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    How deep is the oil in the catch can?
    Mine also catches a ton, it was just about full after 3600 miles!
  5. Dec 9, 2023 at 11:01 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Tesla charging mount for my DMX1057xr
  6. Dec 9, 2023 at 11:11 AM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    Well I added some couplers to the bottom of some of the 10-24 bolts on the Rago dash mount to act as feet,thing moves quite a bit, for those saying it’s “rock solid” I call BS lol my phone bounces quite a bit.
    not sure if it will help at all.
    mgm16trdpro, Cthulhu and bulldog93 like this.
  7. Dec 9, 2023 at 11:45 AM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Installed my newly painted oem tow hooks and a wash and coating of Chemical Guys Hyper Slick Ceramic Coating.
    Nbab23, TreeCat, mgm16trdpro and 10 others like this.
  8. Dec 9, 2023 at 11:59 AM
    ShawnTRD
    ShawnTRD New Member
    Shawn
    New OEM Beam wipers
  9. Dec 9, 2023 at 12:12 PM
    AggiePhil
    College Station, TX
    “Beam wipers?”
  10. Dec 9, 2023 at 12:31 PM
    Under the headliner and down behind the pillar trim.
    a_double[QUOTED] and Xcumminsguy like this.
  11. Dec 9, 2023 at 12:54 PM
    Wallygator
    Just asking cuz I don't know, ....is this necessary on a 2020 or did they fix this issue?
    Vr0ck likes this.
  12. Dec 9, 2023 at 2:52 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I added a vertical arm to help support the phone arm. Definitely helps
  13. Dec 9, 2023 at 3:28 PM
    dan8906
    dan8906 New Member
    Daniel
    Do you have a picture of your set up?
  14. Dec 9, 2023 at 3:50 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Needed it when I wheel over the big hits thing would move a lot.
  15. Dec 9, 2023 at 4:11 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Insulated the side walls of the topo topper and installed another lightbar on the roof.
    upload_2023-12-9_18-11-20.jpgupload_2023-12-9_18-11-20.jpgupload_2023-12-9_18-11-20.jpgupload_2023-12-9_18-11-20.jpg
  16. Dec 9, 2023 at 4:19 PM
    dan8906
    dan8906 New Member
    Daniel
    Did you buy that somewhere?
  17. Dec 9, 2023 at 4:33 PM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    Just a shite day all around. Big snow storm moving in tonight and I finally got a new spark plug and coil for the ATV so went to install them. Install was a PITA, and when done, still wouldn't start. Said to hell with it and loaded the ATV on a trailer to take it to a shop. During that process, I set a padlock on the rear bumper for the hitch and forgot about it when I lowered the tailgate. Nice dent...
    Then, I noticed that my canopy was no longer flush with the bed...
    That explains why my homemade pool noodle canopy/cab gasket was no longer sealing. So, loosened up the bolts, moved it forward to where it should be, and tightened it down. Now my gasket doesn't fit, so will have to start over with smaller diameter pool noodles.
  18. Dec 9, 2023 at 4:50 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Sounds like a shite day. :( I’ll get better! :thumbsup:
  19. Dec 9, 2023 at 4:51 PM
    Vizsla
    Vizsla 2 = 2.5
    Not really sure why anyone would do this, looks absolutely awful, so they are perfect imo..Yellow powder coated lug nuts. This is how I explained it to the wife, race trucks have yellow lug nuts, we should also.:notsure: Have the same wheels in black, gonna switch soon but that won’t help much.o_O
  20. Dec 9, 2023 at 4:52 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    It’s just a coupler arm that typically goes over the ball. Added some friction tape to the claw part to further keep the vibration down. Bolts up to the same holes on the Rago mount
  21. Dec 9, 2023 at 4:53 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    LOL! I added red vinyl to a spoke. Learned this on race cars to locate valve stems. Old lady said the same thing to me. Didn’t make it a month lol
  22. Dec 9, 2023 at 5:45 PM
    dan8906
    dan8906 New Member
    Daniel
    Right on, I made a prototype out of pvc. Gave it a test rip around the block seems 100 times better. Gonna run it like that for a bit and if it is in fact good, I will make it out of something solid. I appreciate the idea. IMG_6216.jpg
  23. Dec 9, 2023 at 5:52 PM
    ShawnTRD
    ShawnTRD New Member
    Shawn
  24. Dec 9, 2023 at 6:26 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Added my TRD grille badge just now. I'm estimating about a 5HP increase :D
  25. Dec 9, 2023 at 6:37 PM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Camp w 6 dads & 7 kids. Wild times & beautiful canyons. Queen valley / superstitions AZ
    Ebrperk, Nbab23, myt1 and 46 others like this.
  26. Dec 9, 2023 at 6:55 PM
    centex
    centex New Member
    Way superior to regular wipers. I won’t buy traditional frames anymore except for my classics and only for those because they get driven so little I’m not spending the money.
  27. Dec 9, 2023 at 7:24 PM
    RobertD
    Robert
    DFW, Texas
    Hey Rey, silly question. I know you have a different air box. But do you think the Stillen intake shroud could be integrated into the Tundras stock air box? It's had to tell if it will interfere with the lid or the front mounting foot.
    reywcms[QUOTED] likes this.
  28. Dec 9, 2023 at 7:27 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Negative, unfortunately it would hit the lid. I explored this with the magnuson airbox which is very similar to a stock unit.
  29. Dec 9, 2023 at 7:35 PM
    RobertD
    Robert
    DFW, Texas
    Thanks, that is what I was thinking....
    reywcms[QUOTED] and RainMan_PNW like this.
  30. Dec 9, 2023 at 10:37 PM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    New wheel day here! Finally got rid of the stocks.
    Decided to drive over to my parents and take a matching photo to the one I originally took of the truck the day I got it. Not a ton has changed but I’d definitely say she is slowly looking better ;)
