General Supercharger Thread
  1. Dec 6, 2023 at 8:55 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
  2. Dec 6, 2023 at 4:56 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My M console came, PSB-1 fits like a glove, need to find more gauges.
    ARES35, ssmokedz and Fastlane47 like this.
  3. Dec 7, 2023 at 8:50 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    For you HP tuner guys: do you actually disconnect and reconnect the battery before re-flashing the truck like the warning that pops up after flashing a tune says?
    mustang67408 likes this.
  4. Dec 7, 2023 at 8:52 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Never done that during my tuning sessions
  5. Dec 7, 2023 at 8:56 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    The only thing with the battery I do is hookup the charger before flashing.
  6. Dec 7, 2023 at 9:03 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Same here.
    snivilous[OP] and HulkSmurf14 like this.
  7. Dec 7, 2023 at 9:06 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I do, it was also in the remote tuning instructions as per DAP. I believe I would flash the file while connected to a battery charger, and then disconnect the battery for 5 minutes after flashing before starting the truck again. Didn’t know it was an option not to!
  8. Dec 7, 2023 at 9:09 AM
    helidave
    flagstaff
    2015 DC 4x4
    I never disconnected the battery between flashes with VF, so I was surprised to see HP saying to do that and I wasn't sure what the purpose was
  9. Dec 7, 2023 at 9:17 AM
    snivilous
    SW UT
    Never once have I done that. And I've flashed tunes back to back in a couple minute span.
  10. Dec 7, 2023 at 10:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This. And full disclosure, I don't use a battery charger anymore either. I'm not going to carry one everywhere I go hunting for an outlet to plug it into as some random highway rest area.
  11. Dec 7, 2023 at 10:47 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    I am definitely the outlier. I have disconnected my battery when the tune has been drastically altered. My thinking is that it thoroughly wipes any long term "learning" that the ECU has done, therefore giving me a more accurate data log. I've found this to be true as it applies to LT fuel trims.
    If its only quick changes, then I DGAF and just keep the battery connected with a 5amp Noco.
    Wynnded likes this.
  12. Dec 7, 2023 at 10:54 AM
    snivilous
    SW UT
    Drive down highway, datalog, pull over, adjust tune, flash, drive back down highway, datalog, pull over, adjust tune, flash.
    But if you brick your ECU it isn't my fault :D
    mustang67408, Mdl, ARES35 and 3 others like this.
  13. Dec 7, 2023 at 10:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    100%
    snivilous[QUOTED][OP] likes this.
  14. Dec 7, 2023 at 11:00 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I recently found out is that some learned values aren't erased when the battery is disconnected, some require manually resetting through techstream (or another device)...not sure which are which though.
  15. Dec 7, 2023 at 11:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm sure that technically, we're all doing something incorrect. :anonymous:
    Mdl, M3Tundra-JK, Saltyhero13 and 2 others like this.
  16. Dec 7, 2023 at 11:11 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm not saying it's incorrect, just clearing up an assumption that I too was making. Spent a lot of time going back and forth with the D2A guy before we realized disconnecting the battery wasn't doing anything for us with regards to the throttle body learning.
  17. Dec 7, 2023 at 11:12 AM
    e30cabrio
    Ask my Wife, I do virtually NOTHING right.
    lol
  18. Dec 7, 2023 at 11:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wasn't referring to what you were saying, sorry. I was speaking more generally about the flashing/tuning.
    armyoffoo[QUOTED] likes this.
  19. Dec 7, 2023 at 11:18 AM
    PolishedTRD
    CO
    Well alrighty! You've saved me from needlessly disconnecting my battery... and setting the fckng clock over and over.
    armyoffoo[QUOTED] and Wynnded like this.
  20. Dec 7, 2023 at 11:20 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was getting way more irritated with losing certain radio settings.
  21. Dec 7, 2023 at 11:24 AM
    nags
    nags New Member
    I never did until I learned the hard way and ended up needing a new ECU.
    Fastlane47 likes this.
  22. Dec 7, 2023 at 11:27 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've bricked mine twice...:eek:
    nags[QUOTED] likes this.
  23. Dec 7, 2023 at 11:33 AM
    snivilous
    SW UT
    What? Really?
  24. Dec 7, 2023 at 11:34 AM
    PolishedTRD
    CO
    WOAH... so what were the circumstances under which y'all bricked them?
  25. Dec 7, 2023 at 11:46 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was using VFT. It was a long time ago and I can't recall the exact circumstances, but I'm sure it was user error on my part. They can be recovered, and mine was on both occasions, but I'm told that it's specific to each ECU version. I'm still using the factory stock ECU. Basically, you'd have to pull the ECU and pry the case off and solder a resistor to specific places on the circuit board that places it into a flashable state when power is reapplied. Then reinstall the ECU, flash a tune, then pull it back out to unsolder the resistor and reassemble. I don't know if this can be done with HPT though.
  26. Dec 7, 2023 at 12:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Thanks for posting this. The instructions I've seen never mentioned temp values as part of procedure. Good to know the complete rundown.
  27. Dec 7, 2023 at 1:33 PM
    snivilous
    SW UT
    I guess today is milling? :D
    mustang67408, Mdl, ARES35 and 8 others like this.
  28. Dec 7, 2023 at 1:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Beautious...
  29. Dec 7, 2023 at 2:59 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  30. Dec 7, 2023 at 5:05 PM
    JustDSM
    JustDSM New Member
    Justin
