4.7 oil pump removal help
Discussion in '1st Gen Tundras (2000-2006)' started by charleyr0806, Dec 3, 2023.
  1. Dec 3, 2023 at 6:23 AM
    charleyr0806
    charleyr0806 [OP] New Member
    Charley
    2008 tundra 4x4
    None
    I have an 08 with the 4.7. I have done the timing belt a few times so I’m familiar with breaking it down. This time I’m working on a leaking oil pump which is a larger job than I thought but here we are. I have the oil pan off and everything loose but it seems to be bound up and won’t slide forward. Any thoughts?
  2. Dec 3, 2023 at 6:43 AM
  3. Dec 3, 2023 at 7:12 AM
    bfunke
    bfunke Tundra Curmudgeon
    Both pans must be removed on the 2UZ to remove the oil pickup tube which is attached to the back of the pump by two studs. Is your leak from the crank seal or possible from the tensioner pulley bolt which will leak if not properly sealed?
    FirstGenVol and shifty` like this.
  4. Dec 3, 2023 at 8:01 AM
    Ah, I remember this bit about some large washer there, that was missing for one user, because it ended up as a 'leftover' part or something. I want to say that was @Mr Badwrench.
  5. Dec 3, 2023 at 9:38 AM
    charleyr0806
    Charley
    2008 tundra 4x4
    None
    I’ve gotten both pans off and removed the pick up tube. I removed the main seal around the crank but can’t get the pump to break free. Shouldn’t it slide forward after breaking the seal?
