Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Nov 26, 2023 at 6:17 AM
    #2851
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    TOYOTA MECHANIC: Question for yeah, were can one get the maintenance procedures for our trucks, I have a 23 Tundra Platinum I Force Max. Just the basic stuff, changing fluids in diff's, transfer case, intercooler coolant, inverter coolant, ATF and brake fluid. Thanks in advance
  2. Nov 26, 2023 at 6:44 AM
    #2852
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Really not a technical question but for the time maintenance schedule it should be in your owner's manual "warranty and maintenance". If you need the "how" there is some basic info in the owner's manual. For the more technical stuff you will have to buy a subscription from the Toyota site TIS. I suppose you could probably find a Hansen manual as well but I've personally never been a fan.
    Mike59 likes this.
  3. Nov 26, 2023 at 10:41 AM
    #2853
    machd08
    machd08 New Member
    CLARENCE
    Thx for the info on TIS
    Ruggybuggy[QUOTED] likes this.
  4. Nov 28, 2023 at 9:53 PM
    #2854
    MTBTANDRA801
    MTBTANDRA801 New Member
    Ben
    2018 Limited DC
    King suspension, TRD Exhaust
    Dear Toyota mechanic
    Bought my 2018 from a Toyota Dealership at 118K miles a few months back, and they did some service on it before i bought it (listed in the pictures) just hit 120K and when I bring it for my 5k oil change I also want to have any factory-recommended 120K services completed. It will be the first major service I have had done since owning the truck. My Toyota dealership (a different dealership than where I bought the Truck) wants all the work scheduled in advance, and I hope to not double pay for things I don't need/they were already done 5K miles ago. What would you do in my position? just cross things off the factory-recommended 120K service list from the pictures above and go through with everything else. They also were trying to convince me for a transmission flush, when I have always heard "drain and fill". I'm going to have them look at the brakes and rotors because I am getting some steering wheel vibrations when braking on the freeway. Some of the items listed in the last picture don't exactly line up to the work order like "check and adjust fluid levels".
  5. Nov 29, 2023 at 6:55 AM
    #2855
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Have a look in your owner's manual and it will have the info regarding what service is required at what mileage. Never ask the dealership what they recommend because they will upsell. Transmission service should be done every 6 years or 60,000 miles. Never do a flush on a Toyota transmission. Only do a drain and fill with Toyota WS transmission fluid.
    Do you have the service history of the vehicle? If you don't asked the dealer you bought the truck from for the information. If the truck was serviced at any Toyota dealer the information is available to them.
    As for the brakes, a vibration at highway speed when the brakes are applied is likely from the front rotors need replacing. Brake rotors and brake pads are change together. I would go back to the selling dealer and complain. Most used vehicles have some kind of warranty and you may be able to get the repair done at no cost. It's worth a shot.
    Mdl and Wynnded like this.
  6. Nov 30, 2023 at 12:54 PM
    #2856
    machd08
    machd08 New Member
    CLARENCE
    Got info I needed on torque specs and instructions for the things I can do myself, again thanks for the heads up on TIS.
  7. Nov 30, 2023 at 1:51 PM
    #2857
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No problem and TIS is invaluable. For those that that dont know, you have to pay for the subscription but it's only $25 for two days and you can print off all the info you might need in the future.
    machd08[QUOTED] likes this.
  8. Nov 30, 2023 at 6:37 PM
    #2858
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The LICENSE has a subscription for $25 for 2 days. How do I get the software to be able to use that $25 license?
  9. Nov 30, 2023 at 6:42 PM
    #2859
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I've never paid for a subscription. I have other sources for the info. You don't need any software. You will get a user name and login password to access the TIS info.
  10. Dec 1, 2023 at 4:27 AM
    #2860
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I was thinking of Techstream. I'd like to be able to modify some of the settings mentioned on this site that require Techstream.
  11. Dec 1, 2023 at 6:44 AM
    #2861
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Techstream is a dealer use software. There are sources for it and you can buy it from Amazon and Ebay but most of the software is risky to use because of viruses. Do a search on the forum to find a source for Techstream. You will find it difficult to find a source for Techstream because the forum will not allow anyone to post info about counterfeit software. If you do find a source for Techstream only load it onto a older laptop that is not connected to the internet. You will also need a interface to connect to the truck. Tactrix Openport2.0 is probably the best and cost effective interface but there are counterfeits that only work for a short time. The cheapest is the Mini-VCI J2534 and is sold on Amazon and eBay along with a copy of Techstream. It will give you some data but it's limited in what modules it can access. Also a not so careful user of Techstream can get you into trouble if you access certain utilities and you could end up with a visit to the dealer and a costly repair. If you don't know, don't go.
    Wynnded likes this.
  12. Dec 1, 2023 at 7:16 AM
    #2862
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for the clarification. I found a super cheap Black Friday laptop ($220) to put Techstream on. After initial setup of the laptop (before Techstream is installed), it will never see the internet again.
    And I know enough to avoid messing with settings that are not crystal clear. Thanks for the heads up.
  13. Dec 1, 2023 at 7:54 AM
    #2863
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What do you plan on using for an interface?
  14. Dec 1, 2023 at 8:55 PM
    #2864
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I bought a VXDiag VCX Nano for the interface. It was highly recommended by someone else on this site.
    Ruggybuggy likes this.
  15. Dec 1, 2023 at 9:02 PM
    #2865
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yup, that's a good one.
  16. Dec 2, 2023 at 2:52 PM
    #2866
    machd08
    machd08 New Member
    CLARENCE
    Question, on transfer case fill and drain plug (36136-0C020) removal for fluid change it states to install new drain and fill plugs, does anyone know the reason behind using new ones, not re-use of the ones removed? My dealership parts dept is saying it will take about 2 weeks to get them in low supply. Also anyone know of a suitable sub. Thanks
  17. Dec 2, 2023 at 4:41 PM
    #2867
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I've never heard of replacing the plugs unless they are feckt up (bad threads or stripped head)
    I know it's recommended to replace the washers if they have them
    Ruggybuggy and ATV25 like this.
  18. Dec 2, 2023 at 5:08 PM
    #2868
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why do you need to change the transfer case oil on a ‘23 Tundra? As already asked, why the new drain plugs?
  19. Dec 2, 2023 at 6:49 PM
    #2869
    machd08
    machd08 New Member
    CLARENCE
    I dont yet, but reading through the stuff I printed from TIS, after changing the fluid, it says to install new plugs, I was going to get the plugs to see if I could have them and check them out to see if I could figure out why, I was curious, as working on Aircraft, there are some hardware we don’t reuse, but there are explanations for it.
    Wynnded likes this.
  20. Dec 2, 2023 at 6:59 PM
    #2870
    machd08
    machd08 New Member
    CLARENCE
    That is how it is for the front/rear diff, replace the washers, but reading the sheets I printed from TIS, it says to install new plugs.
    Leo's first[QUOTED] likes this.
  21. Dec 2, 2023 at 7:17 PM
    #2871
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That’s very odd. Does TIS say there is a gasket or is the plug pipe thread like the previous gen?
    Leo's first likes this.
  22. Dec 2, 2023 at 7:33 PM
    #2872
    machd08
    machd08 New Member
    CLARENCE
    I dont know about previous gen, but from how the pictures are, looking at it on the truck, looks to me to be the plug type.
  23. Dec 2, 2023 at 7:45 PM
    #2873
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The reason I mentioned am the previous gen is because they are pipe tread. If the 3rd gen used a pipe thread aluminum plug I could see replacing. If your regular plugs with gasket is made from steel I couldn’t see any reason you would need to replace.
    Wynnded and machd08[QUOTED] like this.
  24. Dec 3, 2023 at 8:59 AM
    #2874
    machd08
    machd08 New Member
    CLARENCE
    Here are the plugs, look aluminum
  25. Dec 3, 2023 at 9:44 AM
    #2875
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's pipe thread. Did you try a magnet to confirm it's aluminum?
  26. Dec 3, 2023 at 10:16 AM
    #2876
    machd08
    machd08 New Member
    CLARENCE
    Nope, didnt think of it, will go check and let you know.
  27. Dec 3, 2023 at 10:25 AM
    #2877
    machd08
    machd08 New Member
    CLARENCE
    It is magnetic, so one would think you can reuse, just wonder why Toyota says to install a new one.
  28. Dec 3, 2023 at 10:45 AM
    #2878
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Theory: Toyota normally installs them so tightly that they usually get messed up upon removal. Replacing them enables the next person to actually remove the plug the following service.:rofl:
  29. Dec 3, 2023 at 12:36 PM
    #2879
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Then I would just reuse the old plugs. It's the exact same design as the previous gen and the plug are reusable. Make sure to use thread sealer on the plugs are don't over tighten (pipe thread).
    Leo's first and machd08[QUOTED] like this.
  30. Dec 3, 2023 at 2:35 PM
    #2880
    bfunke
    bfunke Tundra Curmudgeon
    The problem is people forget these plugs only need to be snug not ugga-dugga tight
    Leo's first, machd08 and Ruggybuggy like this.
