  1. Nov 26, 2023 at 7:55 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    That’s awesome. Now, let’s see a video of it in action!
  2. Nov 27, 2023 at 6:58 AM
    riding4life162
    riding4life162 New Member
    Let’s see…. This week I have:
    1) replaced all the bolts for the factory skid plate that were rusted on, rounded off, broken and missing; yes there are 5 bolts and all met one of these categories (45 minutes and $6)
    2) Changed my oil valvolene synthetic 0w-20 and Toyota oil filter (30 minutes and $90)
    3) Put in a new windshield wiper spray motor. (30 minutes and $31.50)
    4) washes truck (30 minutes and $5
  3. Nov 27, 2023 at 7:04 AM
    rphass17
    rphass17 New Member
    The 30min wash time and $5.00 isn't adding up correctly in my head.
  4. Nov 27, 2023 at 7:34 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Oh man, did you pull out the exhaust? I pulled it out the front without removing the exhaust when I did it, screw those heat shields though, especially the one that bolts at the tippy top, with like 3cm of space, LOL.....
    tyr0981 and Mountun Goat like this.
  5. Nov 27, 2023 at 8:26 AM
    RideredDriveyota
    RideredDriveyota New Member
    Thornton CO
    2007 Silver Tundra SR5
    3/1 pro comp lift level kit Freedom offroad UCA's Remote start Ultra motorsports wheels Cherry bomb glasspack exhaust HID headlights Rear bumper leds
    How did the led reverse lights work out for you at night?
  6. Nov 27, 2023 at 9:14 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Bought a new grille surround and TRD Pro style grille. Doesn't look too bad with the surround being black and not color matched.
    dp0031, aelarson, biebs96 and 12 others like this.
  7. Nov 27, 2023 at 4:33 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I pulled the starter out by undoing the motor mount bolt and jacking the motor up an inch or two to make room. I live in the rust belt. Taking the exhaust off would've been more misery.
  8. Nov 27, 2023 at 5:28 PM
    blackdemon_tt
    Rust belt, man I rest my case... Only spent about 6 months combined in OKC.
    Tripleconpanna likes this.
  9. Nov 28, 2023 at 5:28 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    More daily adventures with rust. While I was swapping out the starter, I noticed my brake pads were thin.
    Had to cut all the caliper pins. Thanks rust.
    Also, squealers fell off. No wonder I heard no noises.
    Got a little too comfortable with the truck being a tank. All the repairs came in at once.
  10. Nov 28, 2023 at 5:40 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I remember being told one of the very first things to do was to anti-seize those dang pins. Glad you caught the pads in time.
  11. Nov 28, 2023 at 6:17 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    4 years later & that damn shield is still sitting on my work bench :rofl: No way I was reinstalling that p.o.s.
  12. Nov 28, 2023 at 7:31 AM
    blackdemon_tt
    LMAO.... I trimmed that corner tbh, I think I posted in another site that I got a new one, since some people would lose their marbles, but I was like scratch that I got it back in minus that corner. Come to think of it, it sits right on the starter, since I used an impact to remove that rounded out bolt with the corner of heat shield still attached.
  13. Nov 28, 2023 at 7:38 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Sounds like nice set up :thumbsup: I ran those Focals in my 4R and hope to get a set for the truck soon.
    PolishedTRD[QUOTED] likes this.
  14. Nov 28, 2023 at 7:44 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Fuuuuuuuuu...
    HVAC stuck on defrost. When I turn the truck off/on I can hear the servo turning and creaking. I'm guessing either something is stuck, or the pivot arm is stripped. And of course it decided it is time to do this when it is 27 degrees and I am not in a position where I have a spot to work on it in a garage.
  15. Nov 28, 2023 at 2:54 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I just went through the exact same thing a couple of months ago. Had to replace the dual motor servo on the driver side. Kind of labor intensive. Took me about 15 hours off and on over 3 days. The YouTube vids helped, but mine wouldn’t snap in to place like the guys on the video said. Ended up taking apart one of the motors to align the big box quarter moon gear. Mine was stuck in defrost too and my panel had a 30 second delay when I started truck as well as the creaking before it stopped working. I got 2 different estimates, the cheapest one was around $2K. The replacement part is less than $150. Just need A LOT OF PATIENCE! PM me if you need more info. Good Luck!!
  16. Nov 29, 2023 at 4:00 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I have the same issue. Were the estimates from a dealership or a garage?
  17. Nov 29, 2023 at 4:03 PM
    Danny3737
    Both were about the same. They didn’t want to do it the way it was done the YouTube videos. They said the dash needed to be removed. Before figuring out the trick, I understand why
  18. Nov 29, 2023 at 4:14 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    Where did you both of them? Need to do this myself.
  19. Nov 29, 2023 at 4:26 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
  20. Nov 29, 2023 at 4:31 PM
    HoodRiverTundra
    HoodRiverTundra New Member
    Riley
    Hood River, OR
    2011 TRD Crewmax
    ICON Stage 2, Roadmaster Active Suspension, 46 Gal TransferFlow Tank, 295/70/18 WildPeaks
    x2 These look great
  21. Nov 29, 2023 at 4:32 PM
    Danny3737
  22. Nov 29, 2023 at 5:05 PM
    PolishedTRD
    CO
    The Pro style grille insert was purchased from NP Motorsports and the surround from this seller on eBay (same brand here on scAmazon but more expensive).
    And a FYI - I've bought 2 grilles from 2 different manufacturers, within the past year, and neither one comes as close to the bumper as OEM. Their shape is almost like a hybrid between the Sequoia and Tundra. I personally don't have a problem with the gap between grille and bumper but I know some do. I also had bad luck with this brand as it's very brittle, if it doesn't already arrive broken.
  23. Nov 29, 2023 at 7:01 PM
    Skew12
    Skew12 New Member
    thanks bud. That gap doesn’t bother me.
  24. Nov 30, 2023 at 8:48 AM
    Windsor
    Homeless in Oregon
    Some.
    Here are my symptoms.
    Creaking when I turn the ignition on and about 20 seconds after I turn it off.
    About 30 second delay on control/fan power.
    Only airflow is to the defrost vent with no noticeable flow to floor or dash vents.
    Servo controls functioning for recirculation, driver ac/cold/hot, passenger sync/cold/hot. The only one not working is vent selection.
  25. Nov 30, 2023 at 9:12 AM
    Danny3737
    You described exactly what I went through. Mine was the dual motor servo on the drivers side. There are a few videos on replacing it. I used A little bit of each one to get it done. If you want to talk, send me a PM and I’ll give you my number. It’s easier to explain over the phone. Like I said, I spent at least 15 hours off and on and off and on, etc, etc. I almost gave up 3 times to have the dealer do it. Once you figure out the few tricks you have to do, it isn’t that bad. It’s the laying on you back on the floorboard trying to position everything that’s the hardest part. It also helps if you have one of those cheap little horoscopes that connect to your phone so you can see that the servo is correctly in place. You will need to have a lot of patience.
  26. Nov 30, 2023 at 7:49 PM
    rphass17
    rphass17 New Member
    Finally got new tires for winter just after the second snow. 285/70r17 load range C Falken Wildpeaks. Also dressed up my center caps with some foil tape and new TRD decals.
  27. Nov 30, 2023 at 9:56 PM
    1015K9
    1015K9 Austin
    Temecula, California
    2013 Rock Warrior
    Foil tape! Please tell me more.
  28. Nov 30, 2023 at 9:57 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Foil tape! Genius.
  29. Dec 1, 2023 at 4:47 AM
    rphass17
    rphass17 New Member
  30. Dec 1, 2023 at 4:07 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Took advantage of the Toyota BF sale and replaced my clicky blower motor. 2 yrs of listening to it get louder and louder.
