  1. Nov 22, 2023 at 7:09 PM
    Yep that will work
  2. Nov 22, 2023 at 7:11 PM
    Yes. It's a game of seesaw where two jacks are ideal. Floor jack under the diff. Bottle jack from the truck to assist along the way. With a lifted pack you will almost assuredly need to unbolt the lower shock mount. I know I did.
    oscardog86[QUOTED] likes this.
  3. Nov 22, 2023 at 7:11 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Thanks guys for helping me out! Hopefully ill get more progress tomorrow.
    But....
    A: Ill need a friend to come help me lift this heavy ass leafspring in place
    B: Its thanksgiving and have to be at my moms for dinner!
  4. Nov 22, 2023 at 7:21 PM
    Oh, and when I say 'see saw' game ... Doing one at a time, I felt like it was see saw, where the diff was the pivot point. Not really, but it visually looked like it.
    If memory serves ....
    Actually memory failed me, because I remember I wrote this day-of work and it explains exactly how I did it solo, pretty easily : https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1707#post-3334239
    When you finish DO NOT forget, you'll likely be putting more strain on your upper shock bushings. I needed to spin mine down half a dozen threads, they were shrooming hard. Don't forget to tighten u-bolts down equally in criss-cross.
    Sorry if preaching to the choir on this. Figure if nothing else, someone may read it and it'll help. I remember getting that shackle reattached (edit: to the frame) was a bitch until I figured out how to leverage the bottle jack (pun intended). And the front driver pack mount sucks due to gas tank.
  5. Nov 22, 2023 at 7:29 PM
    oscardog86
    Southern California
    @shifty` I think im definitely visually understanding what youre talking about. That is really helpful info, thanks so much!
    Interesting about the upper shock bushings. Never would have even thought to keep an eye on those. Even if you are preaching to the choir with others on here, i definitely have a better understanding now so you shouldnt apologize for spreading useful information!
    shifty` likes this.
  6. Nov 22, 2023 at 8:21 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Unbolt the shocks. It’ll make life easier
  7. Nov 23, 2023 at 4:45 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    Sounds like a good excuse to buy a cheapo parts tumbler/washer!
  8. Nov 23, 2023 at 6:33 AM
    I did all the work solo, while medically not-entirely-well (like 48 hours before tonsillectomy, with an incoming sinus infection). It took me about 75 mins on the 1st side, 60 on the 2nd. YMMV. I started on the passenger side (easier) to get the hang of it and got really hung up because … I didn’t pull the lower shock bolt! And I couldn’t get that extra inch or two I needed to get the shackle bolt out freely, and get the axle tube to drop enough to take the new spring. Anyway, I’m not a big guy, a little over 6ft, around 175# currently. I am strong but not one of those guys who presents as “buff”, I don’t lift weights on any particular regimen, don’t care to make myself look larger. The springs are only 45-70lb/ea so not too bad.
    Before you get started though, make sure you have u-bolts that are a couple inches longer, that’s the only thing that hit me in the ass. Fortunately I had my longer set from the AAL kit.
  9. Nov 23, 2023 at 6:47 AM
    I was worried about the same (old dude brain) which is why I wrote this, in case I needed to do this again, I just forgot I wrote it!!!: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1707#post-3334239
    Oh and on this point, remembering I initially learned from a Navy E2/P3 airplane mechanic, this is one of those places I was told never to re-use bolts due to stretch that inevitably happens naturally during proper torquing on a multi-head bolt. I was also told “in a pinch”, if you can spin the nut freely from top to bottom without any change in resistance you may be good for another torque-down.
    That said, my OEM U-bolts were stouter, heavier than the fatter extended u-bolts Icon sent with my AAL kit. Almost felt like OEM was steel and the Icon bolts were alloy. Super weird.
    NUDRAT and oscardog86[QUOTED] like this.
  10. Nov 23, 2023 at 7:01 AM
    U bolts are a onetime use for sure, but the shackle hardware I don’t see a issue reusing
  11. Nov 23, 2023 at 7:07 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    Happy Thanksgiving, hope you all have much to be thankful for.
    bmf4069, NUDRAT, Tileguy and 4 others like this.
  12. Nov 23, 2023 at 7:18 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I have a bench grinder that's whole purpose is cleaning up hardware. One side has a brass wire brush and the other side is steel. Basically every piece of hardware I touch gets a quick cleanup before reassembly.
    Watch out though. It will suck a small piece right out of your hands, around the guard, and then rocket it into your chest at a mach-FU speed. Safety Squints highly advised.
    bmf4069, NUDRAT, shifty` and 5 others like this.
  13. Nov 23, 2023 at 11:19 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Today I’m making a modification to the hidden snorkel. Mr Mo Tundy, who once hooked 4 trout on a single cast reminded me our trucks defi physics when driving through puddles. Somehow ends with a waterfall on the windshield which got me worried since it draws air in the cowl space. 05992D71-5C5A-4E65-AD72-150FDF61267F.jpg
    bmf4069, txagg, 805Tundra and 6 others like this.
  14. Nov 23, 2023 at 12:16 PM
    Definitely. I might've misunderstood. I think this has been the worst day of this crap I've got.
  15. Nov 23, 2023 at 12:17 PM
    Oh and Happy Thanksgiving ya bastids.
    bmf4069, NUDRAT, artsr2002 and 6 others like this.
  16. Nov 23, 2023 at 1:43 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Took a few tries but feeling like this is the final portion of the hidden snorkel in the cowl. 1583428B-504B-4B77-8134-A643610724D4.jpgGives me an extra 1 3/8” higher intake while keeping the 3” opening and is well above a few places water can drain even if I get massive gush into cowl. CE71146A-6299-46DF-9118-572EF0E5C31A.jpg
    Sewn together with copper wire and hot glued the seams. 1C711546-BBB7-4B69-A2E4-EF04832665EF.jpg
    and she’s back in with enough time to finish b4 dinner. AF46283C-2ECD-437F-98E6-888C0793342B.jpg
    Happy Thanksgiving all. Appreciate all the help I got here when I started working on my truck. Good peoples
    bmf4069, 805Tundra, NUDRAT and 8 others like this.
  17. Nov 23, 2023 at 2:00 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Changed the oil in my new to me truck today. Was looking through some service records from the previous owner and realized the shop that did the last change used 0w20 in it and one of those dollar store looking quick lube oil filters. Got a Toyota filter and some Mobil 1 high mileage and feel better now. Side note: Toyota dealership 5 minutes down the road has oil filters for $6 I wasn’t expecting them to be that cheap. Nice surprise
    bmf4069, NUDRAT, oscardog86 and 3 others like this.
  18. Nov 23, 2023 at 2:31 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Ya I buy them 5 at a time just in case they realize they’re not ripping us off on them lol
    txagg, NUDRAT and oscardog86 like this.
  19. Nov 23, 2023 at 3:40 PM
    I normally get mine $2.50-3.50 each, you can definitely find them cheaper!
    oscardog86 and KTM_AJ421[QUOTED] like this.
  20. Nov 23, 2023 at 5:16 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    During. My 20 year old son learning how to wrench on his truck.
    Aftermath. All new OEM LCA, Ball Joint, Cam Sleves and bolts. Bilstein 5100, Freedom Off Road UCA, new inner outer tie rods, steering rack bushings, extended sway bar end links, new carrier bearing, 1” block in the back.
    Done!! 285/70/17 on Vision Flow. 9” wide , -12 offset.
    456AFD5F-2030-49A3-A016-2CE5EE745B9D.jpg AD993E7E-550C-4CC2-8DF0-0348D830095E.jpg
  21. Nov 23, 2023 at 6:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nice! That's practically a 34" tire. I don't see to many people running those
  22. Nov 23, 2023 at 6:29 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    Original owner!
    Oops sorry 285/70/17 not 75.
    Josh at First Gen Off-road was a load of help planning out the setup.
  23. Nov 23, 2023 at 6:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I like the wheels. What are they?
  24. Nov 23, 2023 at 6:34 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    Original owner!
    Vision Flow 17x9 with -12 offset. Got them with the BFG K02s from Custom Offsets.com.
  25. Nov 23, 2023 at 7:05 PM
    oscardog86
    Southern California
    Got the Archive garage springs installed today. Wasnt too bad by myself actually, but removing the lower shock bolt helped a lot with lifting the new springs in place.
    Ill have to double check my measurements, but it looks like I got atleast a 1 1/2" lift with these springs. Thats compared to the originals with a Wheelers AAL. So it almost looks like I have a bit of rake now, but hard to tell in my driveway. Ill have to take it for a drive and get a better view of it from the side when i can.
    But so far it looks pretty good and im glad I didnt go with the HD springs and get even more lift and rake. Time will tell as they probably will settle a bit too.
    Happy Thanksgiving guys!
    EDIT: Also got the U Bolt flip kit installed as well. Cant wait to go camping now and see how this rear suspension feels!
    bmf4069, SateenC1, shifty` and 10 others like this.
  26. Nov 24, 2023 at 6:30 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Those OEM starfish look mint. I need to refinish my 2 sets :(
  27. Nov 24, 2023 at 12:36 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    They're here! They're here!
    Time to work some OT to pay them off and get some tires. Lol.
    bmf4069, Voss, oscardog86 and 9 others like this.
  28. Nov 24, 2023 at 4:36 PM
    Fever finally blew up then broke overnight. I was out cold from 19h00 - 09h30 and don’t remember a damn bit of it.
    Today was bath time, before it gets all cold and stuff.
  29. Nov 25, 2023 at 5:53 AM
    vst
    vst New Member
    Scott
    2005 DC 4wd
    I need to replace one of my valve cover gaskets it’s leaking where the best place to order from. I’m looking to get the gasket the half moon gaskets and new bolts?
  30. Nov 25, 2023 at 6:02 AM
    Everything you need to know, and links to instructions/tips, part numbers, etc: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    Go OEM on parts for sake of longevity. This is not a fun task you want to be doing again later. I feel like Toyota could've made this easier-to-do, but ... if done right, you shouldn't need to touch for another 10-15 years.
