First Gen AC Rear Seat Delete
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Dec 26, 2020.
  1. Apr 3, 2021 at 9:28 AM
    #61
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    GREAT BUILD, inspiring to those few that are in the AC Delete Club :wave:
    :help: How much noico did you buy and from where? I am @ that step...
    Voss[QUOTED][OP] likes this.
  2. Apr 3, 2021 at 10:41 AM
    #62
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I bought the 36 sq ft of the Kilmat 80 mil stuff from Am a Zon. I still have plenty of left over (maybe 3/4 of the box) after doing just the back wall. I intended to do the door panels and whatever I had left to cover but haven't yet, not sure if I will. If you just want to cover the back wall like I did, 18 sq ft should be plenty and is about $30.
    Darkness, Voss[OP] and jimf909 like this.
  3. Apr 3, 2021 at 11:14 AM
    #63
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Thanks. Got the 36sqft Noico box on Amazon. Had plenty left over.
    Darkness likes this.
  4. Jun 16, 2021 at 11:17 AM
    #64
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I was hoping I could remove just the bottom part of the seats. Once the seat is out, is there a way to separate the back from the butts?
  5. Jun 16, 2021 at 11:57 AM
    #65
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On the access cab, yes. In fact you can leave the backrest in place and remove the seat part. There is a plastic trim on the outside ends where the hinges are, remove that and you'll find the bolts to remove and swing the seats out.
    On double cab I wouldn't know, probably but I can't confirm it.
  6. Jun 16, 2021 at 12:02 PM
    #66
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    There's nothing the back seats of DCs latch onto. Everything is on the seat bottom.
    The back can be folded forward in half, then the whole seat can be folded against the back of the front seats.
  7. Jun 16, 2021 at 12:09 PM
    #67
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nothing some ratchet straps wouldn't fix :D
    Voss[OP] likes this.
  8. Jun 18, 2021 at 9:40 PM
    #68
    TRDGen
    TRDGen Schnooogins
    Travis
    Awesome! Thanx
    Darkness[QUOTED] likes this.
  9. Dec 20, 2021 at 11:02 AM
    #69
    TheQuietWhiner
    TheQuietWhiner New Member
    Landon
    Denver, CO
    I put new gas in the other day.
    Long time creeper and first time poster here. Finally joined and am looking forward to this being the next project.
    shifty`, Voss[OP], bmf4069 and 2 others like this.
  10. Aug 17, 2022 at 11:08 AM
    #70
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Keep this thread alive, I started to delete mine.
  11. Oct 19, 2023 at 7:01 AM
    #71
    Unmbra_SCI
    Unmbra_SCI New Member
    Joe
    First gen Tundra
    Started my seat delete. Here’s some progress pictures.
    I decided to go with one big pocket rather than 3, though I am considering changing my mind.
    Going to to pull the whole thing out again tonight and bed line it.
  12. Oct 19, 2023 at 7:23 AM
    #72
    This may qualify in the top 10 of all 1st posts :rofl:
    Welcome to the forum, what's the end plan here? Will the storage compartments remain accessible? I would take a minute to get some heavy-mil NOICO sound deadening mat off the scAmazon and deaden that back wall before getting too deep into it, it'll make a world of difference in noise reduction now the seats and padding aren't going to be around to mask things.
    Voss[OP] and Galladanb like this.
  13. Oct 19, 2023 at 7:35 AM
    #73
    Unmbra_SCI
    Joe
    First gen Tundra
    Meh I decided to just try the sponge and leave the factory material under the ply wood. It’s already as quite or quieter than stock. Will be basically the same lay out as OP when finished. Next layer of ply wood will go on top of that framing forming a small pocket in the back.
    I’ll put in a big base with storage pockets in the floor very similar to OP. Main goal is a nice big spot for a dog bed. When off-road my dog slid off the seat and got stuck in the foot space lol.
    Voss[OP] and shifty`[QUOTED] like this.
  14. Oct 19, 2023 at 10:50 AM
    #74
    The only proper rear seat delete:
  15. Oct 19, 2023 at 10:51 AM
    #75
    Unmbra_SCI
    Joe
    First gen Tundra
    Haha yeah that’s pretty slick. Where would my dogs sit though?
    Voss[OP] and bmf4069[QUOTED] like this.
  16. Oct 19, 2023 at 10:53 AM
    #76
    Isn't that what the ports on the box are for, pup storage? :rofl:
    (I'm kidding, and also have a ~60lb Plott that would never fit)
  17. Oct 21, 2023 at 9:35 PM
    #77
    Unmbra_SCI
    Joe
    First gen Tundra
    Getting pretty close to done here. Just sprayed it with bed liner. I might not bother trimming in the top part. I feel like it will just reduce the opening of the pocket I installed that holds my fly rod tubes and my net perfectly.
    just gotta finish off the compartment lids.
  18. Oct 22, 2023 at 6:42 AM
    #78
    That would look really sweet, almost OEM+ if you took a roundover bit to the corners! So far, I love this, looks better than what I've seen from others.
    Galladanb likes this.
  19. Oct 22, 2023 at 2:19 PM
    #79
    Galladanb
    Galladanb New Member
    Southeastern Tennessee
    2002 AC Sr5
    Tempting…
    y’all make it look so easy!
    very nice!
  20. Oct 22, 2023 at 5:56 PM
    #80
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It’s hilarious how it looks like he has so much room back there now.
  21. Oct 23, 2023 at 7:53 AM
    #81
    You'd be amazed how much you can haul back there without the seat. I don't even like having the seat back there now. Even for hauling groceries it's easier to lay everything on the floor than the seat.
  22. Oct 23, 2023 at 9:00 AM
    #82
    I realize the OEM setup has a jumpseat-style function, but I feel like someone needs to design a fold-down jumpseat for these trucks that nicely trims out/covers the rear wall and folds down to maximize storage. The OEM seats create a ton of bulk and eat space due to the thick bottoms.
    JasonC. likes this.
  23. Oct 23, 2023 at 9:07 AM
    #83
  24. Nov 5, 2023 at 6:36 AM
    #84
    Richid
    Richid New Member
    I removed mine and used a piece of ABS that I used a heat gun to form to the back wall. Added some poly foam and a fabric cover. Then covered the floor with a rubber mat. Much more room for doggos.
    Voss[OP] and Unmbra_SCI like this.
  25. Nov 5, 2023 at 10:01 PM
    #85
    Unmbra_SCI
    Joe
    First gen Tundra
    Show us some pics bud!
    Voss[OP] and shifty` like this.
  26. Nov 19, 2023 at 8:19 PM
    #86
    Voss
    2003 AC TRD 4x4
    Nice
    des2mtn likes this.
  27. Nov 21, 2023 at 5:41 AM
    #87
    Danzig
    Danzig New Member
    06 tundra
    What a good idea this looks amazing.
