General Supercharger Thread
  1. Nov 20, 2023 at 4:18 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    It would be plug and play but the break out harness doesn't support Toyota; requires tapping pin 1 of the "GO" pedal.
    I'm adding it to the list of shit I don't need.
    Only gripe is there doesn't seem to be a way to tune it at home.
  2. Nov 20, 2023 at 4:18 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    NICE!
    The only thing I'm not looking forward to will be having to likely install another, slightly shorter serpentine belt. I think I donate more blood to the drain in the shop floor routing belts than anything else.
  3. Nov 20, 2023 at 4:19 PM
    ARES35
    ARES35 New member for life
    Mile high
    Please sign me up sir! :spending:
    Mdl and snivilous[QUOTED][OP] like this.
  4. Nov 20, 2023 at 4:20 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Do you know if your engine was built with larger piston ring gaps to handle more boost? If they were gapped for 15+ PSI boost and If they keep knock under control, they might be fine with 93. E85 would cool things off considerably, but expensive to do on our rigs as would require a standalone ECU like the Motec mentioned.
    Once you start getting up to 20+ PSI though, regardless of ring gap, you're going to need something to cool off the charge, whether it be E85, or Water/Meth, or Nitrous...heat's going to be a problem.
    Saltyhero13, Mdl, VWTim and 1 other person like this.
  5. Nov 20, 2023 at 4:24 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I didn't look around at shorter belts so we'll have to see how that works... Larger pulleys have a lot more circumference change albeit more grip length for the belt so we'll have to see how it plays out. The 77.5mm is about an inch less circumference, and the 70mm is about two inches. I don't know how much belt length engagement there is, would you be able to get a picture of that? There's a Gates 115.0625" belt which is about 1.125" shorter than the stock belt, so that may work for one of those pulleys.
    e30cabrio, Mdl, ARES35 and 1 other person like this.
  6. Nov 20, 2023 at 4:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I'll get that for you tomorrow. :thumbsup:
    Mdl and ARES35 like this.
  7. Nov 20, 2023 at 4:54 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  8. Nov 20, 2023 at 7:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As @armyoffoo stated you can tune for water/methanol injection running 93. Especially if e85 is hard to find. You'll get cooler IAT's. There's the upfront cost but it pays off.
    e30cabrio likes this.
  9. Nov 20, 2023 at 8:27 PM
    Saltyhero13
    This is Nat Speed's hidden E85 Stage 4(their website is still jacked up); may give you some ideas:
    <li>Harrop Engineering TVS2650 supercharger system</li>
    <li>OEM Lexus RC F 84mm throttle body</li>
    <li>Prospeed Autosports 4.50" air-intake system</li>
    <li>ZPE GripTec 75mm supercharger pulley</li>
    <li>Prospeed Autosports ethanol compatible return-style fuel system</li>
    <li>Ti Automotive 450lph in-tank fuel pump</li>
    <li>Prospeed Autosports 750cc/min fuel injectors</li>
    <li>American Racing Headers 1.875" primary ID long-tube headers</li>
    <li>OEM Toyota exhaust manifold gaskets</li>
    <li>NGK LFR6AIX-11 spark plugs</li>
    <li>Genuine OEM Toyota coolant</li>
    <li>Custom Calibration via HP Tuners or VF Tuner</li>
    Some follow on discussion starts about it here:
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-57#post-2714947
  10. Nov 20, 2023 at 8:27 PM
    Saltyhero13
    I thought it was a twofer sale when I saw it in my inbox. So disappointed.
  11. Nov 20, 2023 at 8:30 PM
    Saltyhero13
    Speaking of rings did you ever get the Total Seal rings installed or is that for the built bottom end?
  12. Nov 20, 2023 at 8:38 PM
    Saltyhero13
    Not sure how Nat Speed was doing E85, been a while since I asked about "Stage 4". No Motec was required or at least not listed in their parts list, total package was $20K about $6K over Stage 3 (basically headers + Stage 2 + all the PS upgrades + TB)
  13. Nov 20, 2023 at 8:39 PM
    Saltyhero13
  14. Nov 20, 2023 at 8:43 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Nope, still sitting on the shelf with all the other parts...I need to call the engine shop and see about getting on their schedule, and stop procrastinating. I need to get the mains line honed for studs and I bought bigger valves from XAT that I need to get head work done to accommodate, then I'll have them measure clearances and static compression.
    Mdl and Saltyhero13[QUOTED] like this.
  15. Nov 20, 2023 at 8:56 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  16. Nov 20, 2023 at 9:29 PM
    Saltyhero13
    Didn’t know that about the 4x4s, good to know.
    I think he discusses the issue a few posts down on the first page
  17. Nov 20, 2023 at 10:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Few dependent things here. Boost level and octane. You can only run so much boost and timing on pump gas. More octane more timing more power. Or displacement etc
    Mdl likes this.
  18. Nov 21, 2023 at 1:12 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Saltyhero13[QUOTED] likes this.
  19. Nov 21, 2023 at 4:38 AM
    Saltyhero13
    Makes sense. They are both enriching with an alcohol.
    E85 seems like a pain to run especially if there isn't an abundance of stations nearby.
  20. Nov 21, 2023 at 4:47 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    I'd hope so, methanol has an effective octane significantly higher than that of ethanol lol your effective octane rating with a blend of pump gas + methanol would be much higher than with pump gas + E(xx)
    Saltyhero13 likes this.
  21. Nov 21, 2023 at 6:20 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    First tank of gas through the truck since the blower install. Stock Maggie tune on tvs2650. 12.4mpg
    I have been driving 50% normal and 50% buffoon. Not too shabby.
  22. Nov 21, 2023 at 6:25 AM
    nags
    nags New Member
  23. Nov 21, 2023 at 6:40 AM
    mZiggy
    mZiggy Honey badger
    Marc
    That'll go up, or down, rapidly depending on how you end up driving lol
  24. Nov 21, 2023 at 6:45 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  25. Nov 21, 2023 at 6:06 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    FYI, Innovate has 10% off gauges til sunday. PSB-1 for $274
  26. Nov 21, 2023 at 8:13 PM
    blenton
    blenton New Member
    Well, crap…
  27. Nov 21, 2023 at 8:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’ve got a smaller pulley with your name on it lol
  28. Nov 22, 2023 at 11:10 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Andrew from XAT sent me some pics of the short block, I should see it soon. IMG_9049.jpg IMG_9047.jpg
  29. Nov 22, 2023 at 11:17 AM
    nags
    nags New Member
    What all is he doing for you with the build?
    Mdl likes this.
  30. Nov 22, 2023 at 11:21 AM
    Fastlane47
    Maryland
    2018 Platinum
    Forged bottom end, upgrade oil pump, dampener, balance everything.
    M3Tundra-JK, Mdl, V10Ace and 6 others like this.
