Green Thunder Oil Analysis Thread...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blue Thunder, Aug 31, 2021.
  1. Sep 30, 2022 at 11:04 AM
    Blue Thunder
    Blue Thunder [OP] Smooth in the Cruise
    Washington
    No dumb questions here! That’s the manual mode when you move the shifter to the left from D.
    Initially I thought that was only for manual shifting, but if you move the lever over and don’t shift the truck will just used gears 1-4.
    As to your second question I typically use tow/haul mode but not always. I find Toyota’s version of tow/haul to be very annoying…and least for my situation
  2. Sep 30, 2022 at 11:06 AM
    fireman_pete
    fireman_pete New Member
    Pete
    2021 SR5 Trail Edition
    Ok, got it. I use the manual shifting all the time going downhill, but never thought of using it besides that. I will be towing tomorrow, and will definitely try it. Thanks!
  3. Sep 30, 2022 at 11:07 AM
    Blue Thunder
    Washington
    Anytime, glad to help.
    I don’t know what weight you are towing but it made a huge difference in my transmission temps.
  4. Sep 30, 2022 at 11:09 AM
    fireman_pete
    Pete
    My trailer weighs about 6500#. Most of my towing with this trailer is short distances (less than 60 miles). It is a BBQ trailer for our catering business.
  5. Sep 30, 2022 at 11:11 AM
    Blue Thunder
    Washington
    Oh sweet momma. Post a pic!
  6. Oct 16, 2022 at 8:03 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Yeah, so as an example, if you put it in "S4" it'll drive and upshift as normal just like in "D" but it locks out 5th & 6th (which are both overdrive gears)
    In my '00 there was an "OD on/off" button, I always turned OD off when towing so it'd only go to 3rd.
    I've always heard not to tow in overdrive as the OD gears are inherently weaker than the rest.
    I actually found in the SIX HUNDRED AND SEVENTY TWO page manual o_O for my '19 I just got where it says "Always use Tow/Haul when towing or hauling (okay, makes sense) and to tow in "S4".
    I'll probably let it have 5th on the flats if it'll hold speed and stay locked up, but I know our Toyota's don't mind singin' along at 2800-3K all day long so I'd prefer that over too much shifting.
    Blue Thunder[OP] likes this.
  7. Oct 16, 2022 at 11:29 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Thanks for posting your transmission fluid analysis. Definitely a worthwhile contribution in midst of the proverbial shitstorm that the transmission cooler conversation can devolve into.
    Oey12 and Blue Thunder[OP] like this.
  8. Nov 1, 2022 at 8:40 AM
    Blue Thunder
    Washington
    You are welcome. One of my favorite quotes is “In God I trust, all others bring facts and data”.
    To be fair, all the data shows is my use doesn’t require a cooler. Everyone else has to extrapolate…but that’s exactly what we all do on forums. We are all different and I respect other’s decisions on the topic. But the issue is a bit one-sided so balance is good.
  9. Dec 7, 2022 at 7:08 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Thought I’d add my tranny report. My use case is nearly identical to Green Thunder’s in post 18. I note nearly identical temps under similar conditions and I monitor it regularly. I had the dealer do the complete flush/exchange they offer. I was concerned the cleaner was put in before the sample was taken, which is why they mentioned it. This is the first change at 52k. I’ll probably do another in 30k and if the metals drop into the normal range as expected, conclude I don’t need the dedicated tranny cooler added on.
  10. Dec 7, 2022 at 7:24 PM
    Blue Thunder
    Washington
    Wow, our tests are pretty close. Thanks for attaching your results. More data is always good.
  11. Dec 7, 2022 at 7:40 PM
    Pmac
    Pmac New Member
    I thought it added some good info. Especially considering our uses and temps are nearly identical. I’d really like to see 3-4 more reports from folks with similar usage. Would help validate the no cooler needed decision. I’m not going to decide for sure until my next report, but I don’t think I’ll need the cooler.
  12. Feb 23, 2023 at 5:46 PM
    Blue Thunder
    Washington
    Added my 2nd Schaeffer's report...
    Henry1jg and 20GR8 Super like this.
  13. Aug 8, 2023 at 7:03 PM
    Blue Thunder
    Washington
    Just updated the first post with my 3rd and final sample of Schaeffer's 9000 0W-20 oil.
  14. Nov 18, 2023 at 11:17 AM
    Pmac
    Pmac New Member
    After doing some off-roading in July, 90 degrees temps, beginning to lean towards a cooler. The reason is there are lots of places I’d like to be in 4Hi, but I can’t do that and keep tranny temps reasonable. The alternate is to be in 4Lo all the time and deal with slower speeds, or constant stops to shift in and out of 4Lo to 2WD.
  15. Nov 18, 2023 at 1:26 PM
    Blue Thunder
    Washington
    Yeah, I agree...trail running needs speeds higher than 4lo but running in 4Hi adds the temps. What temperatures were you seeing?
  16. Nov 19, 2023 at 7:40 PM
    Pmac
    Pmac New Member
    I stopped using 4Hi when I saw them heading past 240. Stopped and dropped it into 4Lo or 2WD. Then temp quickly went down below 220. July heat in SE OR.
