Soon to be 4x4 Sequoia 1st gen
Discussion in 'Sequoia Builds' started by notso, Nov 19, 2023.
  1. Nov 19, 2023 at 3:36 AM
    notso
    notso [OP] New Member
    This is 2WD 2002 Sequoia. My goal is to convert that into 4x4. This is the list of parts I'm currently looking into getting from the junkyard:
    • front locking hubs
    • front CV axles
    • front differential
    • front driveshaft
    • transfer case
      • including transfer case shifter
      • including interior trim around the shifter
    • rear driveshaft
    • instrument cluster (2WD instrument cluster doesn't have 4x4 icon)
    • interior bezel around the radio with 4WD button to engage / disengage
    I am not sure about the transmission. Does 2WD have different transmission than 4WD?
    Do I need any wiring or harnesses? I was told that 2WD version has most or all of the connectors that 4WD needs.
  2. Nov 19, 2023 at 4:04 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    notso[OP] likes this.
  3. Nov 19, 2023 at 6:18 PM
    notso
    Thank you @Mr.bee for sharing that. Which Toyotas are better or worse donors for A340F? On some forums I read that 1996-2000 3rd gen 4Runners are good.
    Anything particular to look for before I spend a day on a junkyard pulling the transmission? Perhaps first drop the pan and inspect it?
    I'll go with j-shift manual transfer case, that's brilliant idea.
  4. Nov 19, 2023 at 6:25 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm not sure what year they fixed the weak OD planetary, but i'd look for an '03-'04 tundra.
    & if i didnt have any of the front drive bits i'd skip the IFS & go solid axle.
    des2mtn likes this.
  5. Nov 28, 2023 at 12:03 AM
    notso
    Ok, I'm currently doing the GX460 front brake update.
    Would anybody confirm or deny fit? Also, what stainless brake lines would you recommend? The vehicle is 2WD currently but planning on going 4WD soon and adding 2-3" lift.
    What brake fluid should I use?
  6. Nov 29, 2023 at 5:22 PM
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia Limited 4x4
    Big mods are coming soon, but not too soon.
  7. Feb 1, 2024 at 12:48 AM
    notso
    I found a transmission locally with those labels:
    30-40 LE 35000 3G040 99KR 06546
    35010 3D830
    I believe it will fit, could you confirm?
