General Supercharger Thread
  1. Nov 17, 2023 at 9:20 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    helidave, ARES35, HulkSmurf14 and 2 others like this.
  2. Nov 17, 2023 at 7:30 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    $20 at harbor freight and you'll walk out with three different methods :D
  3. Nov 17, 2023 at 8:58 PM
    Saltyhero13
    Which one gives me the mad max look?
  4. Nov 17, 2023 at 9:00 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    An axe.
  5. Nov 18, 2023 at 4:14 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    So if you are running the 18 psi cap would the red coolant be better than the pink for cooling
    Mdl[QUOTED] likes this.
  6. Nov 18, 2023 at 5:26 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yes... absorbs more heat
    Mdl likes this.
  7. Nov 18, 2023 at 5:27 AM
    19PlatinumCrew
    Dave
    50 50 mix with distilled water
    Mdl likes this.
  8. Nov 18, 2023 at 5:29 AM
    HulkSmurf14
    2014 Tundra Limited
    Better red than dead
  9. Nov 18, 2023 at 5:40 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Also the throttle body bypass mod helps in temps I saw a difference in normal operating temperature.
  10. Nov 18, 2023 at 5:49 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ll be honest I don’t know why red would absorb more heat unless it actually has a higher specific heat than the pink which I have not found published for either anywhere. All I have really found is the pink is friendlier to aluminum than the red and has a longer service life. I don’t know the reasoning behind Matt suggesting the red was better for heat absorption.
    https://garagedreams.net/products/toyota-red-vs-pink-coolant-which-is-better
  11. Nov 18, 2023 at 5:50 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    A higher ratio of water will move more heat, 60/40 or even 70/30. Keep it above the freezing point and inspect coolant condition more often.
    A degas/expansion tank will also help keep the coolant doing what it should.
    Saltyhero13, Mdl and Silver17 like this.
  12. Nov 18, 2023 at 5:55 AM
    19PlatinumCrew
    Dave
    I would think most people would run the pink with the higher psi cap just because it's easier than draining the system. I might change it at 30k but was wondering if it was a better choice over the pink coolant, what are you running
    Mdl likes this.
  13. Nov 18, 2023 at 6:05 AM
    Silver17
    Eastern PA
    I still have the pink. I’d switch to red if I actually understood the science behind why it might be better. Like Jowett said, one thing that will definitely help is running a higher distilled water to coolant percentage which will increase the specific heat of the mixture and therefore it’s ability to absorb heat.
  14. Nov 18, 2023 at 6:10 AM
    19PlatinumCrew
    Dave
    I've noticed that my water temp is higher with the Supercharger, it sits at 203...before it was always 200 or below,TB bypass help any in that regard
    Mdl likes this.
  15. Nov 18, 2023 at 6:16 AM
    Silver17
    Eastern PA
    I could see the TB bypass helping lower IATs, I actually did measure a difference in IATs after doing that mod. I would think it wouldn’t do anything for coolant temp though. If anything the coolant was probably rejecting a very small amount of heat into the air passing through the throttle body. In other words, I could see having a negligible amount more heat rejection with the TB not bypassed than bypassed. But who knows!
    Saltyhero13 likes this.
  16. Nov 18, 2023 at 6:25 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Toyota used to install small reverse thermostats on the throttle body coolant warming circuit. They shut down coolant flow over a certain temperature in order to reduce over heating of the throttle body when conditions are favorable for it. 1st gen Tundras have them.
    M3Tundra-JK, Saltyhero13, Mdl and 3 others like this.
  17. Nov 18, 2023 at 6:38 AM
    HulkSmurf14
    2014 Tundra Limited
    My mechanics state the red stuff is a superior coolant...yes, it requires being changed every 30k miles or every two years versus pink stating 10 years or 100k miles. He mentioned they switched to pink for EPA requirements and red protects the coolant systems parts better and though it may not "cool" better on its own, it making the coolant system happier is an indirect reasoning to why it may cool better...
    Sheesh, what's in this coffee I'm drinking?!
  18. Nov 18, 2023 at 6:43 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    My truck ran 198-201 all the time. Now 194-198 after tb bypass this was before the new blower and water wetter etc
  19. Nov 18, 2023 at 7:02 AM
    Silver17
    Eastern PA
    Maybe @ViktorG has thoughts on red vs pink coolant.
  20. Nov 18, 2023 at 9:43 AM
    e30cabrio
    I always loop one of the hoses to the other fitting when I get a new vehicle. (did the BMW last week when the intake was swapped)
    HulkSmurf14 likes this.
  21. Nov 18, 2023 at 12:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Just wanted to update with my final gauge pod setup. I've been trying a few ideas and haven't been happy with the look/fitment until now. Originally I tried the Mustang vent pod ring from Glow Shift. While that one did fit into the Tundra vent it was not a solid mount even after trying a few different ways to secure it I was never really happy with it. Next up I went with the Cravenspeen flexpod mount. My plan was to just utilize one pod since the Innovate PSB-1 does both AFR and Boost in the same gauge. My issue with this mount was just the location of the gauge. I felt like I was just settling on this because the vent mount idea sort of fell through and let me down.
    After searching high and low I came across a posting on Etsy for a vent mount gauge pod for the 2016 - 2023 Tacoma. Based on the pictures included in the posting the Tacoma vent itself looked identical to the Tundra. The seller has many pod mounts for different models, but nothing listed for the Tundra. I gave it a try for $35 and the pod arrived today. It fits into the Tundra trim with a perfect fit. The 3D printed pod has the same tabs as the OEM Tundra vent and it clips into the dash trim just like it was meant to be there. The pod fit the Innovate gauge with no modifications whatsoever and is rock solid. The only item that will need to be addressed is the gauge bracket which needs to be trimmed a little since it's too long.
    I've sent an email to the Esty seller notifying them that this gauge will also fit the 2014 - 2021 Tundra in addition to the 2016 - 2023 Tacoma that is listed on their site. Below is the link to the item if anyone is interested. I can't recall who else was running the vent pod from GlowShift, but I'd seriously recommend swapping to this mount if you are unhappy with the fitment.
    2016-2023 Toyota Tacoma Vent Pod N300 3rd Generation - Etsy
    **Cravenspeed Flexpod is available if anyone is interested.
    EDIT: Cravenspeed Flexpod has been sold.
  22. Nov 18, 2023 at 12:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Badass.. and I just bought one too as a just in case...haha looks outstanding!! Have you thrown it in yet?!
    M3Tundra-JK, Mdl and AZTundra like this.
  23. Nov 18, 2023 at 12:43 PM
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    What if you have the 160 thermostat in? How would that play a role with mixing the 18psi thermostat and the red coolant? What’s the “cooler” set up between the three variables?
    Mdl likes this.
  24. Nov 18, 2023 at 12:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    I installed the MAP sensor and ran some of the wiring to get power and the dimmer connections over to the vent. I was waiting for the vent pod to arrive before fully hooking it all up. I still need to find time to get the bung welded in. I'm going to have Performance Muffler do the bung, but they are only open Mon-Fri so it might take a little time before I can accommodate that with my work schedule.
    ARES35 and HulkSmurf14[QUOTED] like this.
  25. Nov 18, 2023 at 12:51 PM
    AZTundra
    Paul
    Phoenix, AZ
    Seller is quick with the update. They responded to my review and already updated the title to include the Tundra!
  26. Nov 18, 2023 at 5:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The higher psi cap is just raising the boiling point of the coolant. Helps prevent hot spots in cylinders and any chance of air pockets from boiling. The lower t-stat is just moving your water to cool at a lower temp and doesn't affect the boiling point. As stated earlier by jowett having a higher content of water aids in cooling at a 70/30 to 60/40 ratio. We're not raising it a lot from 15 to 18psi but you should have decent hoses, water pump and radiator ad we are increasing the pressure.
    ARES35 likes this.
  27. Nov 18, 2023 at 5:47 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    about the same as mine. 200-203 pre blower, now 194-196. I also replaced tstat and water pump tho. Not sure if that’s having an impact.
    ARES35 likes this.
  28. Nov 18, 2023 at 5:59 PM
    snivilous
    SW UT
    Can someone post a picture of their Magnuson 2650 engine bay so I can update the first page. And if there's any special info or links to things that should be there, post that too :D
    ARES35, Mdl and HulkSmurf14 like this.
  29. Nov 18, 2023 at 6:46 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
  30. Nov 18, 2023 at 7:07 PM
    AZTundra
    Paul
    Phoenix, AZ
    Borrowed this picture from one of @ARES35 posts. I picked up 2 ft of vacuum line today from Ace Hardware so I can move the Map Sensor father away from the blower. Is there any reason I can't drill into the firewall and mount the Innovate Map Sensor here? Anything to be cautious of when drilling there? I can't imagine anything would be right behind the firewall there, but ya never know...
    e30cabrio, reywcms and ARES35 like this.
