Wiring Harness Eaten
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraFrank4x4, Aug 2, 2022.
  1. Aug 2, 2022 at 7:05 PM
    TundraFrank4x4
    TundraFrank4x4 [OP] New Member
    They ate it up pretty Good. Built a big nest under the hood of my 2014 Tundra. Multiple wires with no idea which colors go with which with multiple of each color wire. Am I screwed here or what?
    Oh, I only have full coverage, not comprehensive insurance. Thanks in advance for any guidance.
  2. Aug 2, 2022 at 7:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Unfortunately that looks to be beyond a backyard repair in my opinion, I would definitely go for a new harness in this situation. Good luck.
  3. Aug 2, 2022 at 8:04 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Wow - I hate that! I agree that it looks like a full harness replacement.
  4. Aug 2, 2022 at 10:44 PM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    I feel your pain!!!
    Had this happen to me 4 times in 2 years at my place of work. I have a 2017.
    If you have comprehensive insurance coverage, most insurance company's will cover with your deductible.
    Mine happened on the passenger side by the fire wall. I started popping my hood after trying all sorts of remedies to deter these pests.
    Also mine were attacked by squirrels 3 times and one rat.
  5. Nov 16, 2023 at 7:30 AM
    fabricater1
    fabricater1 New Member
    IMG_3075.jpg This is the same place mine was chewed up but not quite as many wires broke. How did you repair it and how much did it cost? Who did you have do the work?
    Pmbd1594 likes this.
  6. Nov 16, 2023 at 8:27 AM
    Bammer
    Monroe, CT
    Little bastards @!
  7. Nov 16, 2023 at 2:30 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Just peel the (not so protective) wire loom back more to expose the wire colors. Then just go to town patching them back together. Start from the center of the wire bunch and work your way outwards.
  8. Nov 16, 2023 at 4:11 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Scourge of the earth!!! I spray mint and I have those electronic dealys going 24/7.
    I do not know if they work but my lizards have hauled butt, and no insects in the windows
  9. Dec 22, 2023 at 1:49 PM
    Pmbd1594
    Pmbd1594 New Member
    2001 Tundra V8 limited 4WD
    None
  10. Dec 22, 2023 at 1:52 PM
    Pmbd1594
    Pmbd1594 New Member
    None
    I have been looking at the Tundra wiring harness thread with interest. This afternoon my 2001 Tundra would turn over but not run. On opening the hood a squirrel popped up surprised! A harness branch on the left side was chewed totally off with wires shreds everywhere. I drove it yesterday but it did hesitate on start up. I’ll try to strip the main harness back and splice a new connection piece in. Do those rodent deterrent bags work?
  11. Dec 23, 2023 at 5:58 AM
    JohnWhicker
    JohnWhicker New Member
    Fox pee will do the trick. Find it and spray it
  12. Dec 23, 2023 at 6:48 AM
    Retroboy1989
    Northern Utah
    Ive never heard about this happening in northern Utah. Is this a regional thing somehow?
  13. Dec 23, 2023 at 8:28 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Try wrapping aluminum window screen around the wires, it work for me when I used to park outside.
  14. Dec 23, 2023 at 9:25 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Will the fox pee smell go into the cab with blower on ??
  15. Dec 23, 2023 at 10:05 AM
    Wsteven
    Wsteven New Member
    2007 White SR5 Single Cab
    I have repaired wiring harness that were chewed up like the pictures a couple of times now and it can be done but it is a slow process because I prefer to solder everything back together and use heat shrink tubing because butt splices are OK if it is just a very few wires but when it is many it gets messy and always start in innermost wires and work your way out Paying very close attention to the wire color markings.
  16. Dec 23, 2023 at 10:43 AM
    JohnWhicker
    Nope, can't really smell it at all. Apply every few months or so
  17. Jan 4, 2024 at 4:27 PM
    Pmbd1594
    Pmbd1594 New Member
    None
    A good friend who has a number of old cars recommends a mixture of 91% rubbing Alcohol, candle oil essence; and a herb like cayenne pepper. Put it in a spray bottle and spray all harnesses. I'm trying it so we'll see....
  18. Jan 4, 2024 at 4:34 PM
    Black@Blue19
    Ken
    SE Texas
    Hope the little ???://—??!!!()!!!!!’ DIE a slow painful death with wire piercing their intestines!!! Vermin death to them a 10,000 times!!!!:)
    Hope you get it all worked out. I spray peppermint in the engine compartment a few times every couple months or so.
  19. Jan 4, 2024 at 6:55 PM
    agrestic1
    2016 CrewMax
  20. Jan 5, 2024 at 7:16 AM
    pursuit2550
    pursuit2550 New Member
    This is why I keep the green rat poison blocks in my engine bay. Works like a charm.
  21. Jan 5, 2024 at 7:46 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have had catastrophic results with poison and urge caution. You can not control where the little bastards are going to die. If it happens deep inside your dashboard or somewhere in the air ducts you will not realize it until it has started to rot. Then you get to disassemble everything trying to find the mess and finally you get to try to get rid of the odor. Ask me how I know, lol
    AZBoatHauler and j-utah like this.
