20K and ATF Degradation @ 65,000
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Nov 7, 2023.
  1. Nov 15, 2023 at 8:30 AM
    #91
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My father ran his distiller unpinned the whole life. No harm to moonshine.
    _none_, blenton, Bammer and 1 other person like this.
  2. Nov 15, 2023 at 8:34 AM
    #92
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Water and ethanol form an azeotrope at a certain concentration. After that you need another method for removing the remainder of the hydrogen hydroxide.
    nobodyintexas[QUOTED] likes this.
  3. Nov 15, 2023 at 9:11 AM
    #93
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Ethanol-schmethanol. Leave it to liver.
    hagrid[QUOTED] likes this.
  4. Nov 15, 2023 at 9:24 AM
    #94
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I’m fairly sure OBD Fusion does some calculation to predict oil temp. My Maestro iDatalink comes up blank on the engine oil temp when I validate the PIDs, so it’s not detecting anything.
  5. Nov 15, 2023 at 9:35 AM
    #95
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Coolant temperature is a standard PID number 4. If iDataLink can't see it, it's a problem with iDataLink. Maybe it is connected to a different CAN? In my non-Toyota car HU is connected to the slow speed CAN-bus that runs auxiliary functions, while critical components like engine are all on the high-speed bus.
    https://en.wikipedia.org/wiki/OBD-II_PIDs
  6. Nov 15, 2023 at 10:46 AM
    #96
    blenton
    blenton New Member
    I though Scientesticle was the proper usage of that term…
  7. Nov 15, 2023 at 10:49 AM
    #97
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I stand corrected.
    blenton[QUOTED] likes this.
  8. Nov 15, 2023 at 1:38 PM
    #98
    Tbrandt
    Tristan
    Kansas City
    I can see coolant temperature, it's the oil temperature that it doesn't read.
