Are you tired of wind noise in your Tundra? Solution provided
Discussion in '3rd Gen Tundras (2022+)' started by txtundra311, May 17, 2023.
  1. Nov 3, 2023 at 4:58 PM
    Okotoks Tundra
    Okotoks Tundra New Member
    Not present on my 2024 sr5 trd off road. Dealer also said no recall or notes about it. Not sure I want to tackle the door removal and install my self quite yet. Will aee how it goes.
    rwsessions likes this.
  2. Nov 12, 2023 at 7:07 PM
    Galoong
    Galoong New Member
    '22 Tundra Limited SB Blueprint
    Truck2Go SyneticUSA retractable bed cover.
    I've got a July 22 build Limited with lots of wind noises and door seal pops when making turns at off/on highway ramps and/or during high wind situation. The wind noise doesn't bother me as much as the popping noise. When the popping happens, I'll pull tight on the inside upper part of my door inwards, the popping subsides, but once I let go the popping continues. Took it to the dealer multiple times and they say they can't duplicate the issue, I call BS. Anyone else have this issue? In addition, the driver side window makes this clicking noise like electricity touching metal or wires hitting against door frame, clicking noises. It goes away for a few seconds after the passenger side window is opened then closed, but it comes back. Dealer also can't duplicate. Anyone with similar or same issue and got it resolved?
  3. Nov 12, 2023 at 7:11 PM
    Breathing Borla
    AZ
    in the past with some older tundras I’ve had and I get the “we can’t duplicate”, I figured out how to make it happen and under what conditions, then ask for a mechanic ride along , then say here dude listen to this and show him yourself
    I did this as early as my 2000 tundra and the brake caliper that was torching brakes since the 4 piston caliber had the pistons too close to one another and they were cooking the brakes , we road around and the brakes pulsed and I said there you go dude feel that in the floor board .
    Mattedfred, Kap1 and Galoong[QUOTED] like this.
  4. Nov 12, 2023 at 7:16 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Sorry to hear about these issues, it must be very frustrating...
    There's all sorts of noises, clicks, whistles that people reported for the 22-23 tundras. The only ones I'm aware were somewhat effective repairs by the dealer is replacing the rubber window runner piece... Which helps with whistling.
    I haven't really heard any solution for what you're describing.
    Why don't you ride with the dealer to show it to them? That's always an option.
    Trd Jon had issues with door rattling on his 2022 and now 2023 wind noise and door rattling .
    https://youtu.be/6KjzMWFzkTE?si=hKLphv0KGKClj6bz
    Galoong[QUOTED] likes this.
  5. Nov 12, 2023 at 7:21 PM
    Galoong
    Galoong New Member
    I have a recall that need to be taken care of, I'll ask for a ride along during my next appointment. Thanks!
  6. Nov 13, 2023 at 7:03 AM
    TapEx
    TapEx New Member
    Following threads like this. The window noise issue is the issue that prevents me from getting a Tundra. I don't think there are enough feedback from 2024 model year to conclude if this issue has been resolved.
    Mattedfred likes this.
  7. Nov 13, 2023 at 7:04 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    LOL, I used to ride motorcycles. You have no clue about wind noise.
    See how that works?
  8. Nov 13, 2023 at 7:05 AM
    DIYReid
    DIYReid New Member
    KC
    I'd recommend test driving one. Wind noise is relevant to what you're ok with. My Tacoma had a ton of wind and road noise and the Tundra is a TON quieter.
    PNW Tundra Mike likes this.
  9. Nov 13, 2023 at 7:06 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I tried that but whistling noise was not being picked up by my phones microphone.
    Wind noise is also subjective... And it's impossible to record it with the phone as microphone isn't sensitive enough... And you can't tell how loud the noise is and if it's normal or not.
    Plus, dealership isn't going to try very hard... They're motivated to actually find and fix your issue (which doesn't have a fix). Their goal is to get rid of you one way or another, so lots of times they won't be able to reproduce the issue unless it's very obvious.
    If you tape up the seals and figure out yourself where the noise is coming from, and send photos to the advisor, then you're increasing your chances of getting the issue fixed on your first visit as mechanic will know exactly where the wind is leaking in from. Doesn't mean they'll have a fix...
  10. Nov 13, 2023 at 7:07 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Test drive one to see if it has wind noise or not. I test drove 2024 and it was very very quiet
    TapEx[QUOTED] likes this.
  11. Nov 13, 2023 at 8:58 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    Lol I use to ride dirt bikes you have zero clue about wind noise!
  12. Nov 14, 2023 at 8:46 AM
    DIYReid
    DIYReid New Member
    KC
    LOL I used to ride big wheels, you have no clue about wind noise!
    earlwright239, pwpblue and Mattedfred like this.
  13. Nov 14, 2023 at 8:47 AM
    DIYReid
    DIYReid New Member
    KC
    Just confirmed, my 24 Limited has the weather striping already installed.
    TapEx likes this.
  14. Nov 14, 2023 at 9:18 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I'm waiting for someone to say they flew to the moon on a rocket... And nobody has any clue about wind noise!
    earlwright239 likes this.
  15. Nov 14, 2023 at 9:33 AM
    blenton
    blenton New Member
    pwpblue likes this.
  16. Nov 14, 2023 at 10:51 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  17. Nov 14, 2023 at 11:32 AM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    To be fair, you'd only have wind noise for a couple of minutes.
    earlwright239 and pwpblue like this.
  18. Nov 14, 2023 at 12:19 PM
    DIYReid
    DIYReid New Member
    KC
    There's no wind up there.
  19. Nov 14, 2023 at 3:33 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Tough crowd...
  20. Dec 23, 2023 at 6:01 PM
    #50
    MoonRocks
    MoonRocks New Member
    Michael
    California
    ‘24 LUNAR ROCK LIMITED TRD OR 4x4
    2024 here. Wind noise indeed on the highway. So annoying.
    Kap1 likes this.
  21. Dec 23, 2023 at 7:05 PM
    #51
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Solar wind;)
  22. Dec 24, 2023 at 11:27 AM
    #52
    SE-TX_Toyo
    SE-TX_Toyo New Member
    Ed
    2024 Tundra SR5 Crewmax 5.5ft bed TRD Offroad Non-Hybrid
    RetraxPro XR Bed Cover 295/70/R18 Nitto Trail Grapplers (no level/no lift/no rubbing)
    My 2024 Tundra SR5 Crewmax TRD Offroad does not have those weatherstrips on the front driver and passenger doors. A bit strange that Toyota would include this for 2023 models and then remove for 2024 models. I have wind noise but I'm yet to determine whether it's from the doors or the mirrors. I figured the mirrors. Only hear it at highway speeds.
  23. Dec 25, 2023 at 7:41 PM
    #53
    TACOGLS
    TACOGLS New Member
    2024 SR5 TRD Sport
    I also have 2024 SR5 TRD sport and it quite until you hit highway speed(60-70 mph) there is significant wind noise over mirror or across driver window. I haven’t seen anyone say the added weatherstrip to door actually helps? It is odd and lame of Toyota not to add to all trims. I also have a weird motor vibration (felt thru steering) between 72-74mph almost like torsion happening, pulling and releasing sensation. It is not wheel balancing issue…
  24. Dec 25, 2023 at 8:32 PM
    #54
    HLR_NM
    HLR_NM New Member
    Harry
    My 23 Limited OR doesn’t have the door seals. I don’t have terrible wind noise but there’s a bit at 80+ so I ordered the seals to see if it helps - can’t hurt!
    .. and the seals are backordered :rofl:
  25. Feb 1, 2024 at 2:03 PM
    #55
    Okotoks Tundra
    Haven’t eliminated wind noise. But this got rid of the whistle. Going to put thin 3m over the seem. Or ideal as will resist folding in mirrors but ok for now. I wonder if wedging some moto foam in the gap would work as well.
  26. Feb 1, 2024 at 4:55 PM
    #56
    Okotoks Tundra
    Yup all those. The foot well vent passenger side makes a whistle. I like the truck but the amount of fit and finish issues is annoying. The thing seat side plastic which passes the actual seat, the plastic door sills, non adjustable rear seat belt height, non flat floor, no tray liners, over bearing electric Nannies etc. o garage door opener on sr5 off road
    Hopefully in long run better then the ford I was looking at but initially a bit disappointed.
  27. Feb 1, 2024 at 8:39 PM
    #57
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    if the volume up down notice startles you I think you startle a little too easily. Ha ha.
    Black widow TRD and Mattedfred like this.
  28. Feb 1, 2024 at 8:56 PM
    #58
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
  29. Feb 1, 2024 at 10:07 PM
    #59
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    pffftt.
  30. Feb 19, 2024 at 3:12 PM
    #60
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    My wife has been complaining about wind noise and I hear it a bit too, but I was thinking it was due to my having Goodyear window vent/shades installed. Never had a problem with WeatherTech window vents on my Tacoma. ???
